    MMM-OlympicGames
    olympic games2022olympic winter gamesolympiabeijing
    41 Posts 15 Posters 27.4k Views 15 Watching
      mlhote
      Hello, great job !!!
      I update the module but It’s stay “Loading”
      The log
      0|MagicMirror | [02.02.2022 10:24.38.381] [ERROR]
      0|MagicMirror | Error getting olympic game medals FetchError: invalid json response body at https://www.bloomberg.com/tosv2.html?vid=&uuid=eeef6240-8409-11ec-a0ac-73657468704e&url=L2dyYXBoaWNzL2JlaWppbmctMjAyMi1vbHltcGljcy1kYXRhL2N1cnJlbnQuanNvbg== reason: Unexpected token < in JSON at position 0
      0|MagicMirror | at /home/pi/MagicMirror/modules/MMM-OlympicGames/node_modules/node-fetch/lib/index.js:273:32
      0|MagicMirror | at runMicrotasks (:null:null)
      0|MagicMirror | at processTicksAndRejections (internal/process/task_queues.js:93:5)
      0|MagicMirror | at Class.getCountryMedals (/home/pi/MagicMirror/modules/MMM-OlympicGames/node_helper.js:54:36)
      0|MagicMirror | {
      0|MagicMirror | type: ‘invalid-json’
      0|MagicMirror | }
      What I have to do to repair ?
      Sorry for my poor English
      Mat
      mumblebajM strawberry 3.141S 2 Replies Last reply Reply Quote 0
      • mumblebajM Offline
        mumblebaj Module Developer @mlhote
        @mlhote Did you run npm install in the MMM-OlympicGames folder?
          mlhote
          Yes
          it’s write on the github
            @mlhote I just clicked the link in your Error and it directs to the below.
            It seems to be working fine for me though
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @mlhote
              @mlhote I had the same issue initially, but after telling the API that I’m not a server but actually using the latest version of the Google Chrome browser here it worked for me and I didn’t experience the same issue again.
              Maybe you changed the reload interval to something that is too frequent.
              Can you please show your config of the module?
                mlhote
                Great it’s work
                Thk at everybody
                  mlhote
                  Great it’s work 1 time !!!
                  When i reboot MM, i have to click again on the url…
                  see my config
                  module: ‘MMM-OlympicGames’,
                  position: ‘top_right’,
                  disabled: false,
                  // all your config options, which are different than their default values
                  So the trouble is not fix
                    justdreambig @strawberry 3.141
                    @strawberry-3-141
                    I hope you can help me… This is my first time posting in the message board so please excuse any formatting mistakes.
                    the module is on my MM but just says loading…
                    Here is the error
                    [03.02.2022 12:44.24.245] [ERROR] Error getting olympic game medals FetchError: invalid json response body at https://www.bloomberg.com/tosv2.html?vid=&uuid=12216a4d-8532-11ec-99d5-6f52634e6775&url=L2dyYXBoaWNzL2JlaWppbmctMjAyMi1vbHltcGljcy1kYXRhL2N1cnJlbnQuanNvbg== reason: Unexpected token < in JSON at position 0
                    I have clicked on the link and it takes you to a page that if you hold on the button it unlocks the data. I know someone else was dealing with that so I hope they found and answer
                    Here is some info about what I have done so far
                    MM version MagicMirror: v2.15.0
                    Synology Docker v20.10.3-1239
                    First I cloned the MMM-OlympicGames to my modules folder
                    then added to my config file (see below)
                    ]MM-Olympics.png )
                            module: 'MMM-OlympicGames',
                            position: 'bottom_left',
                    then I ran npm install --production in ~/MagicMirror/modules/MMM-OlympicGames directory.
                    added Locale to the default settings
                    locale: "en-US",
                    then I restarted the MM and it still says loading…
                    I even tried removing it and staring over step by step this morning and still have loading…
                    Any ideas to point me in the right direction would be most helpful. I really like this module and would like to use it
                    • KristjanESPERANTOK Offline
                      KristjanESPERANTO Module Developer @justdreambig
                      I also had the “invalid json response” problem. After I upgraded node-fetch to 3.x, it works fine.
                        In the beginning, I had the same issues with the invalid response. But I never had to click the link in order to fix it, I just started using the fake user agent in the module. Every time I restart the mirror it’s loading the data for me.
                        The module is not using an official API. Everything else I found is charging money for it or does not return data.
                        I was hoping once the games are starting that some other APIs start spitting out some data, so I could potentially switch.
                        I’m open to links from free JSON APIs that would solve your issues.
                          Most sport news sites including the official olympic games website still show 0 medals.
                            mlhote @KristjanESPERANTO
                            @kristjanesperanto Couldyou explain how to upgrade ?
                              KristjanESPERANTO Module Developer @mlhote
                              @mlhote In the meantime it works also with node-fetch v2 for me, so an upgrade seems not to be necessary.
                              One assumption is that this occurs when you restart the mirror several times. Then the API is often queried in a short time and therefore you are blocked.
                                Link to module https://github.com/fewieden/MMM-OlympicGames
                                [1.2.0]
                                Added
                                • Added another data source, see new config option provider.
                                Changed
                                • Countries with same medals share the same rank
                                [card:fewieden/MMM-OlympicGames]
                                  SirFM
                                  I’ve specified the en-US locale but the country names seem to be in Catalan.
                                  Here is my config file
                                                          module: "MMM-OlympicGames",
        // all your config options, which are different$
        locale: "en_US",
        highlight: "CA",
        maxRows: "10",
        reloadInterval: "3600000",
        provider: "nbc"
                                  ```Edited to fix locale typo
                                    sdetweil @SirFM
                                    @sirfm I think the option is locale
                                    u have local
                                    computers are picky
                                      SirFM @sdetweil
                                      @sdetweil Just saw that after posting and made the correction. Unfortunaly I get the same result with the typo corrected.
                                        KristjanESPERANTO Module Developer @SirFM
                                        @sirfm locale has to be direcly under config not in the module config: https://github.com/fewieden/MMM-OlympicGames/blob/master/.github/global.png
                                          sdetweil @KristjanESPERANTO
                                          @kristjanesperanto yes, but that impacts system wide.
                                          but looking at the code, you are correct
                                            SirFM @sdetweil
                                            @sdetweil @KristjanESPERANTO
                                            My default locale is “ca-FR”. I don’t mind contributing to a transaltion file if needed.
                                            • 2 / 3
