    MMM-OlympicGames
    olympic games2022olympic winter gamesolympiabeijing
    41 Posts 15 Posters 31.5k Views 15 Watching
      mlhote @KristjanESPERANTO
      @kristjanesperanto Couldyou explain how to upgrade ?
      KristjanESPERANTOK 1 Reply Last reply
      • KristjanESPERANTOK
        KristjanESPERANTO Module Developer @mlhote
        @mlhote In the meantime it works also with node-fetch v2 for me, so an upgrade seems not to be necessary.
        One assumption is that this occurs when you restart the mirror several times. Then the API is often queried in a short time and therefore you are blocked.
        • strawberry 3.141S
          Link to module https://github.com/fewieden/MMM-OlympicGames
          [1.2.0]
          Added
          • Added another data source, see new config option provider.
          Changed
          • Countries with same medals share the same rank
          [card:fewieden/MMM-OlympicGames]
            SirFM
            I’ve specified the en-US locale but the country names seem to be in Catalan.
            Here is my config file
                                    module: "MMM-OlympicGames",
                                            // all your config options, which are different$
                                            locale: "en_US",
                                            highlight: "CA",
                                            maxRows: "10",
                                            reloadInterval: "3600000",
                                            provider: "nbc"
            ```Edited to fix locale typo
              sdetweil @SirFM
              @sirfm I think the option is locale
              u have local
              computers are picky
                SirFM @sdetweil
                @sdetweil Just saw that after posting and made the correction. Unfortunaly I get the same result with the typo corrected.
                  KristjanESPERANTO Module Developer @SirFM
                  @sirfm locale has to be direcly under config not in the module config: https://github.com/fewieden/MMM-OlympicGames/blob/master/.github/global.png
                    sdetweil @KristjanESPERANTO
                    @kristjanesperanto yes, but that impacts system wide.
                    but looking at the code, you are correct
                      SirFM @sdetweil
                      @sdetweil @KristjanESPERANTO
                      My default locale is “ca-FR”. I don’t mind contributing to a transaltion file if needed.
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @SirFM
                        @sirfm the locale ca-FR represents Catalan (France) in your case it should be fr-CA for French (Canada).
                        In general, the locale format is mostly language code - region code.
                        There are some labels that could also be translated to french https://github.com/fewieden/MMM-OlympicGames/blob/master/translations/en.json
                        • strawberry 3.141S
                          Added
                          • Added option for user to input list of countries to display, see config option countryList.
                          • Added French language translations.
                          Changed
                          • Uniform spelling for MagicMirror²
                          • Upgraded development dependencies
                          • Updated preview images
                            SirFM @strawberry 3.141
                            Is there any way that the module could be used for the Paralympics games?
                            • strawberry 3.141S
                              @sirfm @KristjanESPERANTO I found an API
                              1.4.0
                              Added
                              • Data provider: paralympic
                              Changed
                              • Default provider: paralympic
                              • Default title: Paralympic Winter Games 2022
                              Link to module: https://github.com/fewieden/MMM-OlympicGames
                              • strawberry 3.141S
                                Fixed
                                • Data provider: nbc
                                • Data provider: bloomberg
                                Removed
                                • 2 / 3
