    MMM-OlympicGames
    olympic games2022olympic winter gamesolympiabeijing
    41 Posts 15 Posters 31.0k Views 15 Watching
    • strawberry 3.141S Offline
      In the beginning, I had the same issues with the invalid response. But I never had to click the link in order to fix it, I just started using the fake user agent in the module. Every time I restart the mirror it’s loading the data for me.
      The module is not using an official API. Everything else I found is charging money for it or does not return data.
      I was hoping once the games are starting that some other APIs start spitting out some data, so I could potentially switch.
      I’m open to links from free JSON APIs that would solve your issues.
        Most sport news sites including the official olympic games website still show 0 medals.
          mlhote @KristjanESPERANTO
          @kristjanesperanto Couldyou explain how to upgrade ?
          • KristjanESPERANTOK Offline
            KristjanESPERANTO Module Developer @mlhote
            @mlhote In the meantime it works also with node-fetch v2 for me, so an upgrade seems not to be necessary.
            One assumption is that this occurs when you restart the mirror several times. Then the API is often queried in a short time and therefore you are blocked.
              Link to module https://github.com/fewieden/MMM-OlympicGames
              [1.2.0]
              Added
              • Added another data source, see new config option provider.
              Changed
              • Countries with same medals share the same rank
              [card:fewieden/MMM-OlympicGames]
                SirFM
                I’ve specified the en-US locale but the country names seem to be in Catalan.
                Here is my config file
                                        module: "MMM-OlympicGames",
                                                // all your config options, which are different$
                                                locale: "en_US",
                                                highlight: "CA",
                                                maxRows: "10",
                                                reloadInterval: "3600000",
                                                provider: "nbc"
                ```Edited to fix locale typo
                  sdetweil @SirFM
                  @sirfm I think the option is locale
                  u have local
                  computers are picky
                    SirFM @sdetweil
                    @sdetweil Just saw that after posting and made the correction. Unfortunaly I get the same result with the typo corrected.
                      KristjanESPERANTO Module Developer @SirFM
                      @sirfm locale has to be direcly under config not in the module config: https://github.com/fewieden/MMM-OlympicGames/blob/master/.github/global.png
                        sdetweil @KristjanESPERANTO
                        @kristjanesperanto yes, but that impacts system wide.
                        but looking at the code, you are correct
                          SirFM @sdetweil
                          @sdetweil @KristjanESPERANTO
                          My default locale is “ca-FR”. I don’t mind contributing to a transaltion file if needed.
                            strawberry 3.141 Project Sponsor Module Developer @SirFM
                            @sirfm the locale ca-FR represents Catalan (France) in your case it should be fr-CA for French (Canada).
                            In general, the locale format is mostly language code - region code.
                            There are some labels that could also be translated to french https://github.com/fewieden/MMM-OlympicGames/blob/master/translations/en.json
                              Added
                              • Added option for user to input list of countries to display, see config option countryList.
                              • Added French language translations.
                              Changed
                              • Uniform spelling for MagicMirror²
                              • Upgraded development dependencies
                              • Updated preview images
                                SirFM @strawberry 3.141
                                Is there any way that the module could be used for the Paralympics games?
                                strawberry 3.141S 1 Reply Last reply Reply Quote 1
                                  @sirfm @KristjanESPERANTO I found an API
                                  1.4.0
                                  Added
                                  • Data provider: paralympic
                                  Changed
                                  • Default provider: paralympic
                                  • Default title: Paralympic Winter Games 2022
                                  Link to module: https://github.com/fewieden/MMM-OlympicGames
                                    Fixed
                                    • Data provider: nbc
                                    • Data provider: bloomberg
                                    Removed
                                    • 2 / 3
