    Voice/motion control
    utility
    72 Posts 15 Posters 104.4k Views 14 Watching
      Mitchfarino Module Developer @strawberry 3.141
      @strawberry-3.141 Is there any way of registering without social media?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Mitchfarino
        @Mitchfarino you can also register with github account which is a control version system used for coding, but i’m not using snowboy.kitt.ai. i have my own voice recognition
          @strawberry-3.141 Thanks I’ll look to do that
          Have you shared your solution?
          strawberry 3.141S 1 Reply Last reply Reply Quote 1
            @Mitchfarino it’s just work in progress as i showed here https://forum.magicmirror.builders/topic/222/voice-control but i’m collaborating with @ronny3050 the next days to hopefully get a nice module based on pocketsphinx.
            progress can be watched on my github
              @strawberry-3.141 nice one!
              I’ll wait for that to be released, then I can compare both before committing to one.
              On to building my frame now
                @Mitchfarino well there’s no reason to wait @alexyak 's module is working already so you can build your frame it’s extendable too and it’s just software it could be changed later on if needed
                and i can tell for sure, that it will be much easier to install his module
                  ronny3050 Module Developer
                  Here’s a video showing the current status of the voice command module. I am eager to hear your thoughts on it.
                  Current Features:
                  • Extremely simple for mirror module developers to add their own voice commands for their modules.
                  • Default voice commands: hide or show any module
                  • Multiple commands mapped to one voice command. (for eg. “How old are you?”, “What’s your age?” corresponds to “Age”)
                  Upcoming Features:
                  • More default voice commands: change mirror settings; current time, date and weather; jokes; list all widgets; help;
                  https://youtu.be/zDiNfS7s5h4
                  Thank you!
                    plumcraft
                    Really good job ! Looking forward to test it
                    • T Offline
                      tyho
                      wow looking good! is there an ability to turn on and off the monitor?
                      Is this free speech (dictionary) or only pre-programmed words?
                        Thank you @plumcraft and @tyho!
                        It is a bit of both. The module developer incorporating voice commands for his module will add a list of commands that he needs. For instance, ‘COUNT UNREAD; HOW MANY EMAILS?’. A dictionary is then generated automatically by the voice command module. The mirror will only understand count, unread, count unread, how many emails, emails (un-important words are ignored).
                        @strawberry-3-141 and I have both been working on the module, and I would like to take his suggestion of adding regex matching as well.
                        • 4 / 4
