    Voice/motion control
    utility
    72 Posts 15 Posters 106.9k Views 14 Watching
      ronny3050 Module Developer
      I have to second @alexyak and @tyho. Relying on chrome keys is not a good solution, especially when the goal is to interact with mirror through voice completely. Pocketsphinx is a good solution and I am getting it to work on RPi as well.
      • T
        tyho
        Yea i have finaly installed node-pocketsphinx. It needs a lot of dependeties. I start find out now how get a voice command out of it. Are u using node-pocketsphinx as well? Or are u using it standalone? Or maybe the pocketsphinx.js?
        I like to hear if you get something working.
        • T
          tyho
          Ok, I find out that https://syl22-00.github.io/pocketsphinx.js/ is the best bet.
          I have run pocketsphinx before and it’s really fast. So i have no doubt the js port is also good.
          But with my lack of skill i don’t know how to create a module. Who can?
          @michmich and @KirAsh4 you already seen this one?
          KirAsh4K 1 Reply Last reply
            I have tried standalone, but I am currently trying the node version. I’ll let you know once something gets going! Thanks.
            T 1 Reply Last reply
            • KirAsh4K
              KirAsh4 Moderator @tyho
              @tyho, I have not, but then I’m not the one working on voice control. :)
              • T
                tyho @ronny3050
                @ronny3050 i guess you can better try pocketsphinx.js
                • A
                  alexyak
                  OK, I’ve tested the pocketsphinx.js. It’s very unreliable with the minimal setting - too many false positives. The native pocketsphinx installation and configuration is too convoluted with a lot of dependencies.
                  Actually I was able to achieve the best and consistent results with https://snowboy.kitt.ai. There’s a way to create multiple keyword models on their web site and include it with the app. I’ve got this working pretty well in the MM. I should be able to publish the voice control module based on snowboy pretty soon.
                  MitchfarinoM 1 Reply Last reply
                  • MitchfarinoM
                    Mitchfarino Module Developer @alexyak
                    @alexyak Looking forward to seeing that!
                    • A
                      alexyak
                      Hey guys, I’ve published the module: https://forum.magicmirror.builders/topic/425/voicecontrol-module
                      Let me know if you have any issues.
                      Enjoy!
                      • MitchfarinoM
                        @alexyak
                        I’m in work at the moment, so can’t look in detail…
                        Are the only commands play/stop music?
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @Mitchfarino
                          @Mitchfarino you can create every command you want by inserting it in the config and create a trained model for it
                          • T
                            tyho
                            @alexyak I will try when i am home. Looking good!
                            • MitchfarinoM
                              Mitchfarino Module Developer @strawberry 3.141
                              @strawberry-3.141 Is there any way of registering without social media?
                              • strawberry 3.141S
                                @Mitchfarino you can also register with github account which is a control version system used for coding, but i’m not using snowboy.kitt.ai. i have my own voice recognition
                                • MitchfarinoM
                                  @strawberry-3.141 Thanks I’ll look to do that
                                  Have you shared your solution?
                                  • strawberry 3.141S
                                    @Mitchfarino it’s just work in progress as i showed here https://forum.magicmirror.builders/topic/222/voice-control but i’m collaborating with @ronny3050 the next days to hopefully get a nice module based on pocketsphinx.
                                    progress can be watched on my github
                                    • MitchfarinoM
                                      @strawberry-3.141 nice one!
                                      I’ll wait for that to be released, then I can compare both before committing to one.
                                      On to building my frame now
                                      • strawberry 3.141S
                                        @Mitchfarino well there’s no reason to wait @alexyak 's module is working already so you can build your frame it’s extendable too and it’s just software it could be changed later on if needed
                                        and i can tell for sure, that it will be much easier to install his module
                                        Reply Quote 2
                                          Here’s a video showing the current status of the voice command module. I am eager to hear your thoughts on it.
                                          Current Features:
                                          • Extremely simple for mirror module developers to add their own voice commands for their modules.
                                          • Default voice commands: hide or show any module
                                          • Multiple commands mapped to one voice command. (for eg. “How old are you?”, “What’s your age?” corresponds to “Age”)
                                          Upcoming Features:
                                          • More default voice commands: change mirror settings; current time, date and weather; jokes; list all widgets; help;
                                          https://youtu.be/zDiNfS7s5h4
                                          Thank you!
                                            plumcraft
                                            Really good job ! Looking forward to test it
                                            Reply Quote 2
                                            • 3 / 4
