    Voice/motion control
    utility
    72 Posts 15 Posters 100.5k Views 14 Watching
      alexyak
      I think using https://snowboy.kitt.ai is the best approach right now for detecting a hot word and then continuing with the google one (annyang). The same way the guy at the http://docs.smart-mirror.io has done it.
      • T Offline
        tyho
        @alexyak yea, i have seen the smart-mirror code. But i don’t pref 2 voice modules… the thing is if your playing around with the map function (zoom in, zoom in, zoom in, go to, zoom out, enz) then you run out of api calls fast.
        I give up on the voice control module… i hope there will be one soon ^^
          alexyak
          Actually I’ve started looking at this: https://syl22-00.github.io/pocketsphinx.js/ Need to test the performance on RaspPi
            ronny3050 Module Developer
            I have to second @alexyak and @tyho. Relying on chrome keys is not a good solution, especially when the goal is to interact with mirror through voice completely. Pocketsphinx is a good solution and I am getting it to work on RPi as well.
            • T Offline
              tyho
              Yea i have finaly installed node-pocketsphinx. It needs a lot of dependeties. I start find out now how get a voice command out of it. Are u using node-pocketsphinx as well? Or are u using it standalone? Or maybe the pocketsphinx.js?
              I like to hear if you get something working.
              • T Offline
                tyho
                Ok, I find out that https://syl22-00.github.io/pocketsphinx.js/ is the best bet.
                I have run pocketsphinx before and it’s really fast. So i have no doubt the js port is also good.
                But with my lack of skill i don’t know how to create a module. Who can?
                @michmich and @KirAsh4 you already seen this one?
                KirAsh4K 1 Reply Last reply Reply Quote 1
                  I have tried standalone, but I am currently trying the node version. I’ll let you know once something gets going! Thanks.
                  • KirAsh4K Offline
                    KirAsh4 Moderator @tyho
                    @tyho, I have not, but then I’m not the one working on voice control. :)
                    • T Offline
                      tyho @ronny3050
                      @ronny3050 i guess you can better try pocketsphinx.js
                        alexyak
                        OK, I’ve tested the pocketsphinx.js. It’s very unreliable with the minimal setting - too many false positives. The native pocketsphinx installation and configuration is too convoluted with a lot of dependencies.
                        Actually I was able to achieve the best and consistent results with https://snowboy.kitt.ai. There’s a way to create multiple keyword models on their web site and include it with the app. I’ve got this working pretty well in the MM. I should be able to publish the voice control module based on snowboy pretty soon.
                        MitchfarinoM 1 Reply Last reply Reply Quote 1
                        • MitchfarinoM Offline
                          Mitchfarino Module Developer @alexyak
                          @alexyak Looking forward to seeing that!
                            alexyak
                            Hey guys, I’ve published the module: https://forum.magicmirror.builders/topic/425/voicecontrol-module
                            Let me know if you have any issues.
                            Enjoy!
                            MitchfarinoM 1 Reply Last reply Reply Quote 0
                              @alexyak
                              I’m in work at the moment, so can’t look in detail…
                              Are the only commands play/stop music?
                              • strawberry 3.141S Offline
                                strawberry 3.141 Project Sponsor Module Developer @Mitchfarino
                                @Mitchfarino you can create every command you want by inserting it in the config and create a trained model for it
                                • T Offline
                                  tyho
                                  @alexyak I will try when i am home. Looking good!
                                    Mitchfarino Module Developer @strawberry 3.141
                                    @strawberry-3.141 Is there any way of registering without social media?
                                      @Mitchfarino you can also register with github account which is a control version system used for coding, but i’m not using snowboy.kitt.ai. i have my own voice recognition
                                        @strawberry-3.141 Thanks I’ll look to do that
                                        Have you shared your solution?
                                        strawberry 3.141S 1 Reply Last reply Reply Quote 1
                                          @Mitchfarino it’s just work in progress as i showed here https://forum.magicmirror.builders/topic/222/voice-control but i’m collaborating with @ronny3050 the next days to hopefully get a nice module based on pocketsphinx.
                                          progress can be watched on my github
                                            @strawberry-3.141 nice one!
                                            I’ll wait for that to be released, then I can compare both before committing to one.
                                            On to building my frame now
                                            • 3 / 4
