    Voice/motion control
    utility
    72 Posts 15 Posters 106.9k Views 14 Watching
    • KirAsh4K
      KirAsh4 Moderator
      FYI, setting 'TEXTAREA' size works fine in Chrome, both by using 'cols' and 'rows' as well as using CSS styling 'width' and 'height'.
      • T
        tyho
        Sorry for spamming what about: https://github.com/cmusphinx/node-pocketsphinx
        • T
          tyho @KirAsh4
          @KirAsh4 The output is exactly what i want. It’s just the proof i get over the api limit of 50 request/day when i use chrome. The thing is when i use this in electron/chromium i have a limit of 50…
          I am still searching for a way to get around the limit or perhaps use another api/voice recognizer…
          • A
            alexyak
            I think using https://snowboy.kitt.ai is the best approach right now for detecting a hot word and then continuing with the google one (annyang). The same way the guy at the http://docs.smart-mirror.io has done it.
            • T
              tyho
              @alexyak yea, i have seen the smart-mirror code. But i don’t pref 2 voice modules… the thing is if your playing around with the map function (zoom in, zoom in, zoom in, go to, zoom out, enz) then you run out of api calls fast.
              I give up on the voice control module… i hope there will be one soon ^^
              • A
                alexyak
                Actually I’ve started looking at this: https://syl22-00.github.io/pocketsphinx.js/ Need to test the performance on RaspPi
                  ronny3050 Module Developer
                  I have to second @alexyak and @tyho. Relying on chrome keys is not a good solution, especially when the goal is to interact with mirror through voice completely. Pocketsphinx is a good solution and I am getting it to work on RPi as well.
                  • T
                    tyho
                    Yea i have finaly installed node-pocketsphinx. It needs a lot of dependeties. I start find out now how get a voice command out of it. Are u using node-pocketsphinx as well? Or are u using it standalone? Or maybe the pocketsphinx.js?
                    I like to hear if you get something working.
                    • T
                      tyho
                      Ok, I find out that https://syl22-00.github.io/pocketsphinx.js/ is the best bet.
                      I have run pocketsphinx before and it’s really fast. So i have no doubt the js port is also good.
                      But with my lack of skill i don’t know how to create a module. Who can?
                      @michmich and @KirAsh4 you already seen this one?
                      KirAsh4K 1 Reply Last reply
                        I have tried standalone, but I am currently trying the node version. I’ll let you know once something gets going! Thanks.
                        T 1 Reply Last reply
                        • KirAsh4K
                          KirAsh4 Moderator @tyho
                          @tyho, I have not, but then I’m not the one working on voice control. :)
                          • T
                            tyho @ronny3050
                            @ronny3050 i guess you can better try pocketsphinx.js
                            • A
                              alexyak
                              OK, I’ve tested the pocketsphinx.js. It’s very unreliable with the minimal setting - too many false positives. The native pocketsphinx installation and configuration is too convoluted with a lot of dependencies.
                              Actually I was able to achieve the best and consistent results with https://snowboy.kitt.ai. There’s a way to create multiple keyword models on their web site and include it with the app. I’ve got this working pretty well in the MM. I should be able to publish the voice control module based on snowboy pretty soon.
                              MitchfarinoM 1 Reply Last reply
                              • MitchfarinoM
                                Mitchfarino Module Developer @alexyak
                                @alexyak Looking forward to seeing that!
                                • A
                                  alexyak
                                  Hey guys, I’ve published the module: https://forum.magicmirror.builders/topic/425/voicecontrol-module
                                  Let me know if you have any issues.
                                  Enjoy!
                                  • MitchfarinoM
                                    @alexyak
                                    I’m in work at the moment, so can’t look in detail…
                                    Are the only commands play/stop music?
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @Mitchfarino
                                      @Mitchfarino you can create every command you want by inserting it in the config and create a trained model for it
                                      • T
                                        tyho
                                        @alexyak I will try when i am home. Looking good!
                                        • MitchfarinoM
                                          Mitchfarino Module Developer @strawberry 3.141
                                          @strawberry-3.141 Is there any way of registering without social media?
                                          • strawberry 3.141S
                                            @Mitchfarino you can also register with github account which is a control version system used for coding, but i’m not using snowboy.kitt.ai. i have my own voice recognition
                                            • 3 / 4
