    Voice/motion control
    utility
    72 Posts 15 Posters 106.0k Views 14 Watching
    • T
      tyho
      i can’t get it to work with the sphinx package. simply cuz i am not smart enough -_-
      I get pocketsphinx regognize my words but not in the js envirement and i don’t get response out of it.
      I think i just use “blather” for the time being to control my monitor on and off. I hope someone make a voice module soon. ^^
      • T
        tyho
        @michmich @KirAsh4 running a simple html with the following code gets me more results then 50. and also run more then a hour already.
        I run it with https in chrome and get:
        0_1469556674964_upload-8cd7fc28-ea4b-4861-9aa3-a711d2c8e440
        has this something to do with chrome that there is no limit?
        • K
          KirAsh4 Moderator
          What’s the HTML/CSS output look like? That’s usually the first thing to look at when stuff like this happens and it’s not the expected result.
          • T
            tyho
            nvm i already see it depends on the chrome api key and not the chromium…
            What about cloud voice api?
            • K
              KirAsh4 Moderator
              FYI, setting 'TEXTAREA' size works fine in Chrome, both by using 'cols' and 'rows' as well as using CSS styling 'width' and 'height'.
              • T
                tyho
                Sorry for spamming what about: https://github.com/cmusphinx/node-pocketsphinx
                • T
                  tyho @KirAsh4
                  @KirAsh4 The output is exactly what i want. It’s just the proof i get over the api limit of 50 request/day when i use chrome. The thing is when i use this in electron/chromium i have a limit of 50…
                  I am still searching for a way to get around the limit or perhaps use another api/voice recognizer…
                  • A
                    alexyak
                    I think using https://snowboy.kitt.ai is the best approach right now for detecting a hot word and then continuing with the google one (annyang). The same way the guy at the http://docs.smart-mirror.io has done it.
                    • T
                      tyho
                      @alexyak yea, i have seen the smart-mirror code. But i don’t pref 2 voice modules… the thing is if your playing around with the map function (zoom in, zoom in, zoom in, go to, zoom out, enz) then you run out of api calls fast.
                      I give up on the voice control module… i hope there will be one soon ^^
                      • A
                        alexyak
                        Actually I’ve started looking at this: https://syl22-00.github.io/pocketsphinx.js/ Need to test the performance on RaspPi
                          ronny3050 Module Developer
                          I have to second @alexyak and @tyho. Relying on chrome keys is not a good solution, especially when the goal is to interact with mirror through voice completely. Pocketsphinx is a good solution and I am getting it to work on RPi as well.
                          • T
                            tyho
                            Yea i have finaly installed node-pocketsphinx. It needs a lot of dependeties. I start find out now how get a voice command out of it. Are u using node-pocketsphinx as well? Or are u using it standalone? Or maybe the pocketsphinx.js?
                            I like to hear if you get something working.
                            • T
                              tyho
                              Ok, I find out that https://syl22-00.github.io/pocketsphinx.js/ is the best bet.
                              I have run pocketsphinx before and it’s really fast. So i have no doubt the js port is also good.
                              But with my lack of skill i don’t know how to create a module. Who can?
                              @michmich and @KirAsh4 you already seen this one?
                              K 1 Reply Last reply Reply Quote 1
                                I have tried standalone, but I am currently trying the node version. I’ll let you know once something gets going! Thanks.
                                • K
                                  KirAsh4 Moderator @tyho
                                  @tyho, I have not, but then I’m not the one working on voice control. :)
                                  • T
                                    tyho @ronny3050
                                    @ronny3050 i guess you can better try pocketsphinx.js
                                    • A
                                      alexyak
                                      OK, I’ve tested the pocketsphinx.js. It’s very unreliable with the minimal setting - too many false positives. The native pocketsphinx installation and configuration is too convoluted with a lot of dependencies.
                                      Actually I was able to achieve the best and consistent results with https://snowboy.kitt.ai. There’s a way to create multiple keyword models on their web site and include it with the app. I’ve got this working pretty well in the MM. I should be able to publish the voice control module based on snowboy pretty soon.
                                        Mitchfarino Module Developer @alexyak
                                        @alexyak Looking forward to seeing that!
                                        • A
                                          alexyak
                                          Hey guys, I’ve published the module: https://forum.magicmirror.builders/topic/425/voicecontrol-module
                                          Let me know if you have any issues.
                                          Enjoy!
                                            @alexyak
                                            I’m in work at the moment, so can’t look in detail…
                                            Are the only commands play/stop music?
                                            • 3 / 4
