    Cant put this to work
    8 Posts 5 Posters 4.0k Views 5 Watching
    • el97E Offline
      el97 @goncalovsc
      @goncalovsc If you look in the terminal you can see that its creating a server on 8080. If you can access it you should have a correct configuration. Can you see anything that indicate that the program is working on your rpi?
      • T Offline
        thk4711
        Hi I am having the same problem here. I am using a PI 3 with a fresh installation of Raspbian. I followed the instructions under Manual Installation. The I copied config/config.js.sample to config/config.js This worked but when I start the software with npm start I only get a black screen. Also when I start the software with node serveronly and use Chrome on a different computer I only get a black screen in the browser. In the console of Chrome I get the following errors (install log is below the console output):
        Failed to load resource: the server responded with a status of 404 (Not Found)
        Roboto-Condensed-Regular.woff2 Failed to load resource: the server responded with a status of 404 (Not Found)
        Roboto-Condensed-Regular.woff Failed to load resource: the server responded with a status of 404 (Not Found)
        main.js:404 Initializing MagicMirror.
        translator.js:197 Loading core translation file: translations/en.json
        translator.js:219 Loading core translation fallback file: translations/en.json
        loader.js:182 Load script: modules/default/alert//alert.js
        Roboto-Condensed-Regular.ttf Failed to load resource: the server responded with a status of 404 (Not Found)
        module.js:477 Module registered: alert
        loader.js:152 Bootstrapping module: alert
        loader.js:182 Load script: modules/default/alert/classie.js
        loader.js:182 Load script: modules/default/alert/modernizr.custom.js
        loader.js:182 Load script: modules/default/alert/notificationFx.js
        loader.js:157 Scripts loaded for: alert
        loader.js:197 Load stylesheet: modules/default/alert/ns-default.css
        loader.js:159 Styles loaded for: alert
        translator.js:170 alert - Load translation fallback: translations/en.json
        loader.js:161 Translations loaded for: alert
        loader.js:182 Load script: modules/default/updatenotification//updatenotification.js
        module.js:477 Module registered: updatenotification
        loader.js:152 Bootstrapping module: updatenotification
        loader.js:157 Scripts loaded for: updatenotification
        loader.js:159 Styles loaded for: updatenotification
        loader.js:161 Translations loaded for: updatenotification
        loader.js:182 Load script: modules/default/clock//clock.js
        module.js:477 Module registered: clock
        loader.js:152 Bootstrapping module: clock
        loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
        :8080/vendor/node_modules/moment/min/moment-with-locales.js Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:190 Error on loading script: vendor/node_modules/moment/min/moment-with-locales.js
        script.onerror @ loader.js:190
        loader.js:182 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
        :8080/vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:190 Error on loading script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
        loader.js:157 Scripts loaded for: clock
        loader.js:197 Load stylesheet: modules/default/clock/clock_styles.css
        loader.js:159 Styles loaded for: clock
        loader.js:161 Translations loaded for: clock
        loader.js:182 Load script: modules/default/calendar//calendar.js
        module.js:477 Module registered: calendar
        loader.js:152 Bootstrapping module: calendar
        loader.js:237 File already loaded: moment.js
        loader.js:157 Scripts loaded for: calendar
        loader.js:197 Load stylesheet: modules/default/calendar/calendar.css
        loader.js:197 Load stylesheet: vendor/node_modules/font-awesome/css/font-awesome.min.css
        192.168.178.40/:1 Refused to apply style from 'http://192.168.178.40:8080/vendor/node_modules/font-awesome/css/font-awesome.min.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled.
        loader.js:206 Error on loading stylesheet: vendor/node_modules/font-awesome/css/font-awesome.min.css
        stylesheet.onerror @ loader.js:206
        loader.js:159 Styles loaded for: calendar
        loader.js:161 Translations loaded for: calendar
        loader.js:182 Load script: modules/default/compliments//compliments.js
        module.js:477 Module registered: compliments
        loader.js:152 Bootstrapping module: compliments
        loader.js:157 Scripts loaded for: compliments
        loader.js:159 Styles loaded for: compliments
        loader.js:161 Translations loaded for: compliments
        loader.js:182 Load script: modules/default/currentweather//currentweather.js
        module.js:477 Module registered: currentweather
        loader.js:152 Bootstrapping module: currentweather
        loader.js:157 Scripts loaded for: currentweather
        loader.js:197 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
        192.168.178.40/:1 Refused to apply style from 'http://192.168.178.40:8080/vendor/node_modules/weathericons/css/weather-icons.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled.
        loader.js:206 Error on loading stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
        loader.js:197 Load stylesheet: modules/default/currentweather/currentweather.css
        loader.js:159 Styles loaded for: currentweather
        loader.js:161 Translations loaded for: currentweather
        loader.js:182 Load script: modules/default/weatherforecast//weatherforecast.js
        module.js:477 Module registered: weatherforecast
        loader.js:152 Bootstrapping module: weatherforecast
        loader.js:157 Scripts loaded for: weatherforecast
        loader.js:237 File already loaded: weather-icons.css
        loader.js:197 Load stylesheet: modules/default/weatherforecast/weatherforecast.css
        loader.js:159 Styles loaded for: weatherforecast
        loader.js:161 Translations loaded for: weatherforecast
        loader.js:182 Load script: modules/default/newsfeed//newsfeed.js
        module.js:477 Module registered: newsfeed
        loader.js:152 Bootstrapping module: newsfeed
        loader.js:157 Scripts loaded for: newsfeed
        loader.js:159 Styles loaded for: newsfeed
        loader.js:161 Translations loaded for: newsfeed
        loader.js:197 Load stylesheet: css/custom.css
        alert.js:151 Starting module: alert
        updatenotification.js:10 Start updatenotification
        clock.js:40 Starting module: clock
        clock.js:49 Uncaught ReferenceError: moment is not defined
        at Class.start (clock.js:49)
        at startModules (loader.js:55)
        at loader.js:40
        at HTMLLinkElement.stylesheet.onload (loader.js:203)
        7clock.js:77 Uncaught ReferenceError: moment is not defined
        at Class.getDom (clock.js:77)
        at updateDom (main.js:99)
        at Object.updateDom (main.js:468)
        at Class.updateDom (module.js:358)
        at clock.js:45
        32clock.js:77 Uncaught ReferenceError: moment is not defined
        at clock.js:45
        getDom @ clock.js:77
        updateDom @ main.js:99
        updateDom @ main.js:468
        updateDom @ module.js:358
        (anonymous) @ clock.js:45
        the install log looks like this:
        npm install
        npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
        npm WARN prefer global coffeescript@1.10.0 should be installed with -g
        npm WARN prefer global jsonlint@1.6.2 should be installed with -g
        > uws@9.14.0 install /123/MagicMirror/node_modules/uws
        > node-gyp rebuild > build_log.txt 2>&1 || exit 0
        > electron-chromedriver@1.7.1 install /123/MagicMirror/node_modules/electron-chromedriver
        > node ./download-chromedriver.js
        > electron@1.4.15 postinstall /123/MagicMirror/node_modules/electron
        > node install.js
        > magicmirror@2.2.2 install /123/MagicMirror
        > cd vendor && npm install
        > nunjucks@3.1.2 postinstall /123/MagicMirror/vendor/node_modules/nunjucks
        > node postinstall-build.js src
        magicmirror-vendors@ /123/MagicMirror/vendor
        ├── font-awesome@4.7.0
        ├── moment@2.20.1
        ├── moment-timezone@0.5.14
        ├─┬ nunjucks@3.1.2
        │ ├── a-sync-waterfall@1.0.0
        │ ├── asap@2.0.6
        │ ├─┬ chokidar@1.7.0
        │ │ ├─┬ anymatch@1.3.2
        │ │ │ ├─┬ micromatch@2.3.11
        │ │ │ │ ├─┬ arr-diff@2.0.0
        │ │ │ │ │ └── arr-flatten@1.1.0
        │ │ │ │ ├── array-unique@0.2.1
        │ │ │ │ ├─┬ braces@1.8.5
        │ │ │ │ │ ├─┬ expand-range@1.8.2
        │ │ │ │ │ │ └─┬ fill-range@2.2.3
        │ │ │ │ │ │   ├── is-number@2.1.0
        │ │ │ │ │ │   ├── isobject@2.1.0
        │ │ │ │ │ │   ├─┬ randomatic@1.1.7
        │ │ │ │ │ │   │ ├─┬ is-number@3.0.0
        │ │ │ │ │ │   │ │ └── kind-of@3.2.2
        │ │ │ │ │ │   │ └── kind-of@4.0.0
        │ │ │ │ │ │   └── repeat-string@1.6.1
        │ │ │ │ │ ├── preserve@0.2.0
        │ │ │ │ │ └── repeat-element@1.1.2
        │ │ │ │ ├─┬ expand-brackets@0.1.5
        │ │ │ │ │ └── is-posix-bracket@0.1.1
        │ │ │ │ ├── extglob@0.3.2
        │ │ │ │ ├── filename-regex@2.0.1
        │ │ │ │ ├─┬ kind-of@3.2.2
        │ │ │ │ │ └── is-buffer@1.1.6
        │ │ │ │ ├─┬ object.omit@2.0.1
        │ │ │ │ │ ├─┬ for-own@0.1.5
        │ │ │ │ │ │ └── for-in@1.0.2
        │ │ │ │ │ └── is-extendable@0.1.1
        │ │ │ │ ├─┬ parse-glob@3.0.4
        │ │ │ │ │ ├── glob-base@0.3.0
        │ │ │ │ │ └── is-dotfile@1.0.3
        │ │ │ │ └─┬ regex-cache@0.4.4
        │ │ │ │   └─┬ is-equal-shallow@0.1.3
        │ │ │ │     └── is-primitive@2.0.0
        │ │ │ └─┬ normalize-path@2.1.1
        │ │ │   └── remove-trailing-separator@1.1.0
        │ │ ├── async-each@1.0.1
        │ │ ├── glob-parent@2.0.0
        │ │ ├── inherits@2.0.3
        │ │ ├─┬ is-binary-path@1.0.1
        │ │ │ └── binary-extensions@1.11.0
        │ │ ├─┬ is-glob@2.0.1
        │ │ │ └── is-extglob@1.0.0
        │ │ ├── path-is-absolute@1.0.1
        │ │ └─┬ readdirp@2.1.0
        │ │   ├── graceful-fs@4.1.11
        │ │   ├─┬ minimatch@3.0.4
        │ │   │ └─┬ brace-expansion@1.1.11
        │ │   │   ├── balanced-match@1.0.0
        │ │   │   └── concat-map@0.0.1
        │ │   ├─┬ readable-stream@2.3.4
        │ │   │ ├── core-util-is@1.0.2
        │ │   │ ├── isarray@1.0.0
        │ │   │ ├── process-nextick-args@2.0.0
        │ │   │ ├── safe-buffer@5.1.1
        │ │   │ ├── string_decoder@1.0.3
        │ │   │ └── util-deprecate@1.0.2
        │ │   └── set-immediate-shim@1.0.1
        │ ├── postinstall-build@5.0.1
        │ └─┬ yargs@3.32.0
        │   ├── camelcase@2.1.1
        │   ├─┬ cliui@3.2.0
        │   │ ├─┬ strip-ansi@3.0.1
        │   │ │ └── ansi-regex@2.1.1
        │   │ └── wrap-ansi@2.1.0
        │   ├── decamelize@1.2.0
        │   ├─┬ os-locale@1.4.0
        │   │ └─┬ lcid@1.0.0
        │   │   └── invert-kv@1.0.0
        │   ├─┬ string-width@1.0.2
        │   │ ├── code-point-at@1.1.0
        │   │ └─┬ is-fullwidth-code-point@1.0.0
        │   │   └── number-is-nan@1.0.1
        │   ├── window-size@0.1.4
        │   └── y18n@3.2.1
        └── weathericons@2.1.0
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        > magicmirror@2.2.2 postinstall /123/MagicMirror
        > sh installers/postinstall/postinstall.sh && npm run install-fonts
        MagicMirror installation successful!
        > magicmirror@2.2.2 install-fonts /123/MagicMirror
        > cd fonts && npm install
        magicmirror-fonts@ /123/MagicMirror/fonts
        └── roboto-fontface@0.8.0
        magicmirror@2.2.2 /123/MagicMirror
        ├─┬ body-parser@1.18.2
        │ ├── bytes@3.0.0
        │ ├── content-type@1.0.4
        │ ├─┬ debug@2.6.9
        │ │ └── ms@2.0.0
        │ ├── depd@1.1.2
        │ ├─┬ http-errors@1.6.2
        │ │ ├── depd@1.1.1
        │ │ ├── setprototypeof@1.0.3
        │ │ └── statuses@1.4.0
        │ ├─┬ on-finished@2.3.0
        │ │ └── ee-first@1.1.1
        │ ├── qs@6.5.1
        │ ├─┬ raw-body@2.3.2
        │ │ └── unpipe@1.0.0
        │ └─┬ type-is@1.6.16
        │   └── media-typer@0.3.0
        ├─┬ chai@4.1.2
        │ ├── assertion-error@1.1.0
        │ ├── check-error@1.0.2
        │ ├── deep-eql@3.0.1
        │ ├── get-func-name@2.0.0
        │ ├── pathval@1.1.0
        │ └── type-detect@4.0.8
        ├── chai-as-promised@7.1.1
        ├── colors@1.1.2
        ├── current-week-number@1.0.7
        ├─┬ electron@1.4.15
        │ ├─┬ electron-download@3.3.0
        │ │ ├─┬ fs-extra@0.30.0
        │ │ │ ├── graceful-fs@4.1.11
        │ │ │ ├── jsonfile@2.4.0
        │ │ │ ├── klaw@1.3.1
        │ │ │ └── rimraf@2.6.2
        │ │ ├── home-path@1.0.5
        │ │ ├── minimist@1.2.0
        │ │ ├─┬ nugget@2.0.1
        │ │ │ ├── pretty-bytes@1.0.4
        │ │ │ ├─┬ progress-stream@1.2.0
        │ │ │ │ ├── speedometer@0.1.4
        │ │ │ │ └─┬ through2@0.2.3
        │ │ │ │   └─┬ xtend@2.1.2
        │ │ │ │     └── object-keys@0.4.0
        │ │ │ ├─┬ single-line-log@1.1.2
        │ │ │ │ └─┬ string-width@1.0.2
        │ │ │ │   ├── code-point-at@1.1.0
        │ │ │ │   └── is-fullwidth-code-point@1.0.0
        │ │ │ └── throttleit@0.0.2
        │ │ ├─┬ path-exists@2.1.0
        │ │ │ └─┬ pinkie-promise@2.0.1
        │ │ │   └── pinkie@2.0.4
        │ │ ├─┬ rc@1.2.5
        │ │ │ ├── deep-extend@0.4.2
        │ │ │ └── ini@1.3.5
        │ │ ├── semver@5.5.0
        │ │ └─┬ sumchecker@1.3.1
        │ │   └── es6-promise@4.2.4
        │ └─┬ extract-zip@1.6.6
        │   ├─┬ concat-stream@1.6.0
        │   │ └── typedarray@0.0.6
        │   ├─┬ mkdirp@0.5.0
        │   │ └── minimist@0.0.8
        │   └─┬ yauzl@2.4.1
        │     └─┬ fd-slicer@1.0.1
        │       └── pend@1.2.0
        ├─┬ express@4.16.2
        │ ├─┬ accepts@1.3.4
        │ │ └── negotiator@0.6.1
        │ ├── array-flatten@1.1.1
        │ ├── content-disposition@0.5.2
        │ ├── cookie@0.3.1
        │ ├── cookie-signature@1.0.6
        │ ├── encodeurl@1.0.2
        │ ├── escape-html@1.0.3
        │ ├── etag@1.8.1
        │ ├─┬ finalhandler@1.1.0
        │ │ └── statuses@1.3.1
        │ ├── fresh@0.5.2
        │ ├── merge-descriptors@1.0.1
        │ ├── methods@1.1.2
        │ ├── parseurl@1.3.2
        │ ├── path-to-regexp@0.1.7
        │ ├─┬ proxy-addr@2.0.3
        │ │ ├── forwarded@0.1.2
        │ │ └── ipaddr.js@1.6.0
        │ ├── range-parser@1.2.0
        │ ├─┬ send@0.16.1
        │ │ ├── destroy@1.0.4
        │ │ ├── mime@1.4.1
        │ ├── serve-static@1.13.1
        │ ├── setprototypeof@1.1.0
        │ ├── statuses@1.3.1
        │ ├── utils-merge@1.0.1
        │ └── vary@1.1.2
        ├─┬ express-ipfilter@0.3.1
        │ ├── ip@1.1.5
        │ ├── lodash@3.10.1
        │ └─┬ range_check@1.4.0
        │   ├── ip6@0.0.4
        │   └── ipaddr.js@1.2.0
        ├─┬ feedme@1.2.0
        │ ├── clarinet@0.12.0
        │ ├── eventyoshi@0.2.0
        │ └── sax@1.2.4
        ├─┬ grunt@1.0.2
        │ ├── coffeescript@1.10.0
        │ ├─┬ dateformat@1.0.12
        │ │ ├── get-stdin@4.0.1
        │ │ └─┬ meow@3.7.0
        │ │   ├─┬ camelcase-keys@2.1.0
        │ │   │ └── camelcase@2.1.1
        │ │   ├── decamelize@1.2.0
        │ │   ├── map-obj@1.0.1
        │ │   ├─┬ read-pkg-up@1.0.1
        │ │   │ ├── find-up@1.1.2
        │ │   │ └─┬ read-pkg@1.1.0
        │ │   │   ├─┬ load-json-file@1.1.0
        │ │   │   │ ├── parse-json@2.2.0
        │ │   │   │ └─┬ strip-bom@2.0.0
        │ │   │   │   └── is-utf8@0.2.1
        │ │   │   └── path-type@1.1.0
        │ │   ├─┬ redent@1.0.0
        │ │   │ ├─┬ indent-string@2.1.0
        │ │   │ │ └── repeating@2.0.1
        │ │   │ └── strip-indent@1.0.1
        │ │   └── trim-newlines@1.0.0
        │ ├── eventemitter2@0.4.14
        │ ├── exit@0.1.2
        │ ├─┬ findup-sync@0.3.0
        │ │ └── glob@5.0.15
        │ ├─┬ glob@7.0.6
        │ │ ├── fs.realpath@1.0.0
        │ │ ├─┬ inflight@1.0.6
        │ │ │ └── wrappy@1.0.2
        │ │ └── once@1.4.0
        │ ├─┬ grunt-cli@1.2.0
        │ │ └── resolve@1.1.7
        │ ├── grunt-known-options@1.1.0
        │ ├─┬ grunt-legacy-log@1.0.0
        │ │ ├─┬ grunt-legacy-log-utils@1.0.0
        │ │ │ └── lodash@4.3.0
        │ │ └── underscore.string@3.2.3
        │ ├─┬ grunt-legacy-util@1.0.0
        │ │ ├── async@1.5.2
        │ │ ├── getobject@0.1.0
        │ │ ├── lodash@4.3.0
        │ │ └─┬ which@1.2.14
        │ │   └── isexe@2.0.0
        │ ├─┬ js-yaml@3.5.5
        │ │ ├── argparse@1.0.10
        │ │ └── esprima@2.7.3
        │ ├─┬ nopt@3.0.6
        │ │ └── abbrev@1.1.1
        │ └── rimraf@2.2.8
        ├─┬ grunt-eslint@20.1.0
        │ ├─┬ chalk@2.3.1
        │ │ ├─┬ ansi-styles@3.2.0
        │ │ │ └─┬ color-convert@1.9.1
        │ │ │   └── color-name@1.1.3
        │ │ └─┬ supports-color@5.2.0
        │ │   └── has-flag@3.0.0
        │ └─┬ eslint@4.18.1
        │   ├─┬ ajv@5.5.2
        │   │ ├── co@4.6.0
        │   │ ├── fast-deep-equal@1.1.0
        │   │ ├── fast-json-stable-stringify@2.0.0
        │   │ └── json-schema-traverse@0.3.1
        │   ├─┬ babel-code-frame@6.26.0
        │   │ └── js-tokens@3.0.2
        │   ├─┬ chalk@2.3.1
        │   │ ├── ansi-styles@3.2.0
        │   │ └── supports-color@5.2.0
        │   ├─┬ cross-spawn@5.1.0
        │   │ ├─┬ lru-cache@4.1.1
        │   │ │ ├── pseudomap@1.0.2
        │   │ │ └── yallist@2.1.2
        │   │ └─┬ shebang-command@1.2.0
        │   │   └── shebang-regex@1.0.0
        │   ├── debug@3.1.0
        │   ├── doctrine@2.1.0
        │   ├─┬ eslint-scope@3.7.1
        │   │ ├── esrecurse@4.2.1
        │   │ └── estraverse@4.2.0
        │   ├── eslint-visitor-keys@1.0.0
        │   ├─┬ espree@3.5.3
        │   │ ├── acorn@5.5.0
        │   │ └─┬ acorn-jsx@3.0.1
        │   │   └── acorn@3.3.0
        │   ├── esquery@1.0.0
        │   ├── esutils@2.0.2
        │   ├── functional-red-black-tree@1.0.1
        │   ├── globals@11.3.0
        │   ├─┬ inquirer@3.3.0
        │   │ ├── ansi-escapes@3.0.0
        │   │ ├─┬ chalk@2.3.1
        │   │ │ ├── ansi-styles@3.2.0
        │   │ │ └── supports-color@5.2.0
        │   │ ├─┬ cli-cursor@2.1.0
        │   │ │ └─┬ restore-cursor@2.0.0
        │   │ │   └─┬ onetime@2.0.1
        │   │ │     └── mimic-fn@1.2.0
        │   │ ├── cli-width@2.2.0
        │   │ ├─┬ external-editor@2.1.0
        │   │ │ ├── chardet@0.4.2
        │   │ │ └─┬ tmp@0.0.33
        │   │ │   └── os-tmpdir@1.0.2
        │   │ ├── figures@2.0.0
        │   │ ├── lodash@4.17.5
        │   │ ├── mute-stream@0.0.7
        │   │ ├─┬ run-async@2.3.0
        │   │ │ └── is-promise@2.1.0
        │   │ ├── rx-lite@4.0.8
        │   │ ├── rx-lite-aggregates@4.0.8
        │   │ ├─┬ string-width@2.1.1
        │   │ │ └── is-fullwidth-code-point@2.0.0
        │   │ └─┬ strip-ansi@4.0.0
        │   │   └── ansi-regex@3.0.0
        │   ├── is-resolvable@1.1.0
        │   ├─┬ js-yaml@3.10.0
        │   │ └── esprima@4.0.0
        │   ├── json-stable-stringify-without-jsonify@1.0.1
        │   ├─┬ levn@0.3.0
        │   │ ├── prelude-ls@1.1.2
        │   │ └── type-check@0.3.2
        │   ├── lodash@4.17.5
        │   ├─┬ mkdirp@0.5.1
        │   ├── natural-compare@1.4.0
        │   ├─┬ optionator@0.8.2
        │   │ ├── deep-is@0.1.3
        │   │ ├── fast-levenshtein@2.0.6
        │   │ └── wordwrap@1.0.0
        │   ├── path-is-inside@1.0.2
        │   ├── pluralize@7.0.0
        │   ├── progress@2.0.0
        │   ├─┬ require-uncached@1.0.3
        │   │ ├─┬ caller-path@0.1.0
        │   │ │ └── callsites@0.2.0
        │   │ └── resolve-from@1.0.1
        ├─┬ grunt-jsonlint@1.1.0
        │ ├─┬ jsonlint@1.6.2
        │ │ ├── JSV@4.0.2
        │ │ └─┬ nomnom@1.8.1
        │ │   ├─┬ chalk@0.4.0
        │ │   │ ├── ansi-styles@1.0.0
        │ │   │ ├── has-color@0.1.7
        │ │   │ └── strip-ansi@0.1.1
        │ │   └── underscore@1.6.0
        │ └── strip-json-comments@2.0.1
        ├─┬ grunt-markdownlint@1.1.0
        │ └─┬ markdownlint@0.7.0
        │   └─┬ markdown-it@8.4.0
        │     ├── entities@1.1.1
        │     ├── linkify-it@2.0.3
        │     ├── mdurl@1.0.1
        │     └── uc.micro@1.0.5
        ├─┬ grunt-stylelint@0.9.0
        │ └─┬ chalk@1.1.3
        │   ├── ansi-styles@2.2.1
        │   ├─┬ has-ansi@2.0.0
        │   ├── strip-ansi@3.0.1
        │   └── supports-color@2.0.0
        ├─┬ grunt-yamllint@0.3.0
        │ ├─┬ async@2.6.0
        │ │ └── lodash@4.17.5
        │ └─┬ js-yaml@3.10.0
        │   └── esprima@4.0.0
        ├─┬ helmet@3.11.0
        │ ├── dns-prefetch-control@0.1.0
        │ ├── dont-sniff-mimetype@1.0.0
        │ ├── expect-ct@0.1.0
        │ ├── frameguard@3.0.0
        │ ├─┬ helmet-csp@2.7.0
        │ │ ├── camelize@1.0.0
        │ │ ├── content-security-policy-builder@2.0.0
        │ │ ├── dasherize@2.0.0
        │ │ ├── lodash.reduce@4.6.0
        │ │ └── platform@1.3.5
        │ ├── hide-powered-by@1.0.0
        │ ├── hpkp@2.0.0
        │ ├── hsts@2.1.0
        │ ├── ienoopen@1.0.0
        │ ├── nocache@2.0.0
        │ ├── referrer-policy@1.1.0
        │ └── x-xss-protection@1.0.0
        ├─┬ http-auth@3.2.3
        │ ├─┬ apache-crypt@1.2.1
        │ │ └── unix-crypt-td-js@1.0.0
        │ ├── apache-md5@1.1.2
        │ ├── bcryptjs@2.4.3
        │ └── uuid@3.2.1
        ├── iconv-lite@0.4.19
        ├─┬ jshint@2.9.5
        │ ├── cli@1.0.1
        │ ├─┬ console-browserify@1.1.0
        │ │ └── date-now@0.1.4
        │ ├─┬ htmlparser2@3.8.3
        │ │ ├── domelementtype@1.3.0
        │ │ ├── domhandler@2.3.0
        │ │ ├─┬ domutils@1.5.1
        │ │ │ └─┬ dom-serializer@0.1.0
        │ │ │   └── domelementtype@1.1.3
        │ │ ├── entities@1.0.0
        │ │ └─┬ readable-stream@1.1.14
        │ │   ├── isarray@0.0.1
        │ │   └── string_decoder@0.10.31
        │ ├── lodash@3.7.0
        │ ├── shelljs@0.3.0
        │ └── strip-json-comments@1.0.4
        ├─┬ mocha@4.1.0
        │ ├── browser-stdout@1.3.0
        │ ├── commander@2.11.0
        │ ├── debug@3.1.0
        │ ├── diff@3.3.1
        │ ├── escape-string-regexp@1.0.5
        │ ├── glob@7.1.2
        │ ├── growl@1.10.3
        │ ├── he@1.1.1
        │ ├─┬ mkdirp@0.5.1
        │ └─┬ supports-color@4.4.0
        │   └── has-flag@2.0.0
        ├─┬ mocha-each@1.1.0
        │ └── sprintf-js@1.0.3
        ├── mocha-logger@1.0.5
        ├── moment@2.20.1
        ├─┬ request@2.83.0
        │ ├── aws-sign2@0.7.0
        │ ├── aws4@1.6.0
        │ ├── caseless@0.12.0
        │ ├─┬ combined-stream@1.0.6
        │ │ └── delayed-stream@1.0.0
        │ ├── extend@3.0.1
        │ ├── forever-agent@0.6.1
        │ ├─┬ form-data@2.3.2
        │ │ └── asynckit@0.4.0
        │ ├─┬ har-validator@5.0.3
        │ │ └── har-schema@2.0.0
        │ ├─┬ hawk@6.0.2
        │ │ ├── boom@4.3.1
        │ │ ├─┬ cryptiles@3.1.2
        │ │ │ └── boom@5.2.0
        │ │ ├── hoek@4.2.1
        │ │ └── sntp@2.1.0
        │ ├─┬ http-signature@1.2.0
        │ │ ├── assert-plus@1.0.0
        │ │ ├─┬ jsprim@1.4.1
        │ │ │ ├── extsprintf@1.3.0
        │ │ │ ├── json-schema@0.2.3
        │ │ │ └── verror@1.10.0
        │ │ └─┬ sshpk@1.13.1
        │ │   ├── asn1@0.2.3
        │ │   ├── bcrypt-pbkdf@1.0.1
        │ │   ├── dashdash@1.14.1
        │ │   ├── ecc-jsbn@0.1.1
        │ │   ├── getpass@0.1.7
        │ │   ├── jsbn@0.1.1
        │ │   └── tweetnacl@0.14.5
        │ ├── is-typedarray@1.0.0
        │ ├── isstream@0.1.2
        │ ├── json-stringify-safe@5.0.1
        │ ├─┬ mime-types@2.1.18
        │ │ └── mime-db@1.33.0
        │ ├── oauth-sign@0.8.2
        │ ├── performance-now@2.1.0
        │ ├── stringstream@0.0.5
        │ ├─┬ tough-cookie@2.3.4
        │ │ └── punycode@1.4.1
        │ └── tunnel-agent@0.6.0
        ├── rrule-alt@2.2.8
        ├─┬ simple-git@1.91.0
        │ └── debug@3.1.0
        ├─┬ socket.io@2.0.4
        │ ├─┬ engine.io@3.1.5
        │ │ ├── base64id@1.0.0
        │ │ ├── debug@3.1.0
        │ │ ├─┬ engine.io-parser@2.1.2
        │ │ │ ├── after@0.8.2
        │ │ │ ├── arraybuffer.slice@0.0.7
        │ │ │ └── blob@0.0.4
        │ │ ├── uws@9.14.0
        │ │ └─┬ ws@3.3.3
        │ │   ├── async-limiter@1.0.0
        │ │   └── ultron@1.1.1
        │ ├── socket.io-adapter@1.1.1
        │ ├─┬ socket.io-client@2.0.4
        │ │ ├── backo2@1.0.2
        │ │ ├── base64-arraybuffer@0.1.5
        │ │ ├── component-bind@1.0.0
        │ │ ├── component-emitter@1.2.1
        │ │ ├─┬ engine.io-client@3.1.5
        │ │ │ ├── component-inherit@0.0.3
        │ │ │ ├── debug@3.1.0
        │ │ │ ├── xmlhttprequest-ssl@1.5.5
        │ │ │ └── yeast@0.1.2
        │ │ ├── has-cors@1.1.0
        │ │ ├── indexof@0.0.1
        │ │ ├── object-component@0.0.3
        │ │ ├─┬ parseqs@0.0.5
        │ │ │ └─┬ better-assert@1.0.2
        │ │ │   └── callsite@1.0.0
        │ │ ├── parseuri@0.0.5
        │ │ └── to-array@0.1.4
        │ └─┬ socket.io-parser@3.1.3
        │   ├── debug@3.1.0
        │   ├─┬ has-binary2@1.0.2
        │   │ └── isarray@2.0.1
        │   └── isarray@2.0.1
        ├─┬ spectron@3.7.3
        │ ├── dev-null@0.1.1
        │ ├─┬ electron-chromedriver@1.7.1
        │ │ └─┬ electron-download@4.1.0
        │ │   ├── env-paths@1.0.0
        │ │   ├── fs-extra@2.1.2
        │ │   ├── path-exists@3.0.0
        │ │   └── sumchecker@2.0.2
        │ ├─┬ split@1.0.1
        │ │ └── through@2.3.8
        │ └─┬ webdriverio@4.11.0
        │   ├─┬ archiver@2.1.1
        │   │ ├─┬ archiver-utils@1.3.0
        │   │ │ ├─┬ lazystream@1.0.0
        │   │ │ │ └─┬ readable-stream@2.3.4
        │   │ │ │   ├── isarray@1.0.0
        │   │ │ │   └── string_decoder@1.0.3
        │   │ │ ├── lodash@4.17.5
        │   │ ├── async@2.6.0
        │   │ ├── buffer-crc32@0.2.13
        │   │ ├─┬ tar-stream@1.5.5
        │   │ │ ├─┬ bl@1.2.1
        │   │ │ ├── end-of-stream@1.4.1
        │   │ │ ├─┬ readable-stream@2.3.4
        │   │ │ └── xtend@4.0.1
        │   │ └─┬ zip-stream@1.2.0
        │   │   ├─┬ compress-commons@1.2.2
        │   │   │ ├─┬ crc32-stream@2.0.0
        │   │   │ │ ├── crc@3.5.0
        │   ├─┬ babel-runtime@6.26.0
        │   │ ├── core-js@2.5.3
        │   │ └── regenerator-runtime@0.11.1
        │   ├─┬ css-parse@2.0.0
        │   │ └─┬ css@2.2.1
        │   │   ├─┬ source-map@0.1.43
        │   │   │ └── amdefine@1.0.1
        │   │   ├─┬ source-map-resolve@0.3.1
        │   │   │ ├── atob@1.1.3
        │   │   │ ├── resolve-url@0.2.1
        │   │   │ └── source-map-url@0.3.0
        │   │   └── urix@0.1.0
        │   ├── css-value@0.0.1
        │   ├── deepmerge@2.0.1
        │   ├── ejs@2.5.7
        │   ├─┬ gaze@1.1.2
        │   │ └─┬ globule@1.2.0
        │   ├─┬ mkdirp@0.5.1
        │   ├── npm-install-package@2.1.0
        │   ├─┬ optimist@0.6.1
        │   │ ├── minimist@0.0.10
        │   │ └── wordwrap@0.0.3
        │   ├── q@1.5.1
        │   ├── rgb2hex@0.1.0
        │   ├─┬ supports-color@5.0.1
        │   │ └── has-flag@2.0.0
        │   ├─┬ url@0.11.0
        │   │ ├── punycode@1.3.2
        │   │ └── querystring@0.2.0
        │   ├── wdio-dot-reporter@0.0.9
        │   └── wgxpath@1.0.0
        ├─┬ stylelint@8.4.0
        │ ├─┬ autoprefixer@7.2.6
        │ │ ├─┬ browserslist@2.11.3
        │ │ │ └── electron-to-chromium@1.3.34
        │ │ ├── caniuse-lite@1.0.30000810
        │ │ ├── normalize-range@0.1.2
        │ │ └── num2fraction@1.2.2
        │ ├─┬ chalk@2.3.1
        │ ├─┬ cosmiconfig@3.1.0
        │ │ ├── is-directory@0.3.1
        │ │ ├─┬ js-yaml@3.10.0
        │ │ │ └── esprima@4.0.0
        │ │ ├─┬ parse-json@3.0.0
        │ │ │ └─┬ error-ex@1.3.1
        │ │ │   └── is-arrayish@0.2.1
        │ │ └── require-from-string@2.0.1
        │ ├── debug@3.1.0
        │ ├─┬ execall@1.0.0
        │ │ └─┬ clone-regexp@1.0.0
        │ │   ├── is-regexp@1.0.0
        │ │   └── is-supported-regexp-flag@1.0.0
        │ ├─┬ file-entry-cache@2.0.0
        │ │ ├─┬ flat-cache@1.3.0
        │ │ │ ├── circular-json@0.3.3
        │ │ │ ├─┬ del@2.2.2
        │ │ │ │ ├── globby@5.0.0
        │ │ │ │ ├── is-path-cwd@1.0.0
        │ │ │ │ ├─┬ is-path-in-cwd@1.0.0
        │ │ │ │ │ └── is-path-inside@1.0.1
        │ │ │ │ └── pify@2.3.0
        │ │ │ └─┬ write@0.2.1
        │ │ │   └─┬ mkdirp@0.5.1
        │ │ │     └── minimist@0.0.8
        │ │ └── object-assign@4.1.1
        │ ├── get-stdin@5.0.1
        │ ├─┬ globby@7.1.1
        │ │ ├─┬ array-union@1.0.2
        │ │ │ └── array-uniq@1.0.3
        │ │ ├─┬ dir-glob@2.0.0
        │ │ │ ├── arrify@1.0.1
        │ │ │ └─┬ path-type@3.0.0
        │ │ │   └── pify@3.0.0
        │ │ └── slash@1.0.0
        │ ├── globjoin@0.1.4
        │ ├── html-tags@2.0.0
        │ ├── ignore@3.3.7
        │ ├── imurmurhash@0.1.4
        │ ├── known-css-properties@0.5.0
        │ ├── lodash@4.17.5
        │ ├─┬ log-symbols@2.2.0
        │ │ └─┬ chalk@2.3.1
        │ ├── mathml-tag-names@2.0.1
        │ ├─┬ meow@4.0.0
        │ │ ├─┬ camelcase-keys@4.2.0
        │ │ │ ├── camelcase@4.1.0
        │ │ │ ├── map-obj@2.0.0
        │ │ │ └── quick-lru@1.1.0
        │ │ ├── decamelize-keys@1.1.0
        │ │ ├─┬ loud-rejection@1.6.0
        │ │ │ ├─┬ currently-unhandled@0.4.1
        │ │ │ │ └── array-find-index@1.0.2
        │ │ │ └── signal-exit@3.0.2
        │ │ ├─┬ minimist-options@3.0.2
        │ │ │ └── is-plain-obj@1.1.0
        │ │ ├─┬ normalize-package-data@2.4.0
        │ │ │ ├── hosted-git-info@2.5.0
        │ │ │ ├─┬ is-builtin-module@1.0.0
        │ │ │ │ └── builtin-modules@1.1.1
        │ │ │ └─┬ validate-npm-package-license@3.0.3
        │ │ │   ├─┬ spdx-correct@3.0.0
        │ │ │   │ └── spdx-license-ids@3.0.0
        │ │ │   └─┬ spdx-expression-parse@3.0.0
        │ │ │     └── spdx-exceptions@2.1.0
        │ │ ├─┬ read-pkg-up@3.0.0
        │ │ │ ├─┬ find-up@2.1.0
        │ │ │ │ └─┬ locate-path@2.0.0
        │ │ │ │   ├─┬ p-locate@2.0.0
        │ │ │ │   │ └─┬ p-limit@1.2.0
        │ │ │ │   │   └── p-try@1.0.0
        │ │ │ │   └── path-exists@3.0.0
        │ │ │ └─┬ read-pkg@3.0.0
        │ │ │   ├─┬ load-json-file@4.0.0
        │ │ │   │ ├─┬ parse-json@4.0.0
        │ │ │   │ │ └── json-parse-better-errors@1.0.1
        │ │ │   │ └── strip-bom@3.0.0
        │ │ │   └── path-type@3.0.0
        │ │ ├─┬ redent@2.0.0
        │ │ │ ├── indent-string@3.2.0
        │ │ │ └── strip-indent@2.0.0
        │ │ └── trim-newlines@2.0.0
        │ │ │ │   ├─┬ isobject@2.1.0
        │ │ │ │   │ └── isarray@1.0.0
        │ │ │ │   └─┬ randomatic@1.1.7
        │ │ ├── is-extglob@1.0.0
        │ │ ├── is-glob@2.0.1
        │ │ ├─┬ normalize-path@2.1.1
        │ │ │ ├─┬ glob-base@0.3.0
        │ │ │ │ └── glob-parent@2.0.0
        │ ├── normalize-selector@0.2.0
        │ ├── pify@3.0.0
        │ ├─┬ postcss@6.0.19
        │ │ ├─┬ chalk@2.3.1
        │ │ │ └── ansi-styles@3.2.0
        │ │ ├── source-map@0.6.1
        │ ├─┬ postcss-html@0.12.0
        │ │ ├─┬ htmlparser2@3.9.2
        │ │ ├─┬ remark@8.0.0
        │ │ │ ├─┬ remark-parse@4.0.0
        │ │ │ │ ├── collapse-white-space@1.0.3
        │ │ │ │ ├── is-alphabetical@1.0.1
        │ │ │ │ ├── is-decimal@1.0.1
        │ │ │ │ ├── is-whitespace-character@1.0.1
        │ │ │ │ ├── is-word-character@1.0.1
        │ │ │ │ ├── markdown-escapes@1.0.1
        │ │ │ │ ├─┬ parse-entities@1.1.1
        │ │ │ │ │ ├── character-entities@1.2.1
        │ │ │ │ │ ├── character-entities-legacy@1.1.1
        │ │ │ │ │ ├── character-reference-invalid@1.1.1
        │ │ │ │ │ ├── is-alphanumerical@1.0.1
        │ │ │ │ │ └── is-hexadecimal@1.0.1
        │ │ │ │ ├── repeat-string@1.6.1
        │ │ │ │ ├── state-toggle@1.0.0
        │ │ │ │ ├── trim@0.0.1
        │ │ │ │ ├── trim-trailing-lines@1.1.0
        │ │ │ │ ├─┬ unherit@1.1.0
        │ │ │ │ │ └── xtend@4.0.1
        │ │ │ │ ├─┬ unist-util-remove-position@1.1.1
        │ │ │ │ │ └── unist-util-visit@1.3.0
        │ │ │ │ ├── vfile-location@2.0.2
        │ │ │ ├─┬ remark-stringify@4.0.0
        │ │ │ │ ├── ccount@1.0.2
        │ │ │ │ ├── is-alphanumeric@1.0.0
        │ │ │ │ ├── longest-streak@2.0.2
        │ │ │ │ ├── markdown-table@1.1.1
        │ │ │ │ ├─┬ mdast-util-compact@1.0.1
        │ │ │ │ │ └─┬ unist-util-modify-children@1.1.1
        │ │ │ │ │   └── array-iterate@1.1.1
        │ │ │ │ ├─┬ stringify-entities@1.3.1
        │ │ │ │ │ └── character-entities-html4@1.1.1
        │ │ │ └─┬ unified@6.1.6
        │ │ │   ├── bail@1.0.2
        │ │ │   ├── trough@1.0.1
        │ │ │   ├─┬ vfile@2.3.0
        │ │ │   │ ├── replace-ext@1.0.0
        │ │ │   │ ├── unist-util-stringify-position@1.1.1
        │ │ │   │ └── vfile-message@1.0.0
        │ │ │   ├── x-is-function@1.0.4
        │ │ │   └── x-is-string@0.1.0
        │ │ └─┬ unist-util-find-all-after@1.0.1
        │ │   └── unist-util-is@2.1.1
        │ ├─┬ postcss-less@1.1.3
        │ │ └─┬ postcss@5.2.18
        │ │   ├── js-base64@2.4.3
        │ │   ├── source-map@0.5.7
        │ │   └─┬ supports-color@3.2.3
        │ │     └── has-flag@1.0.0
        │ ├── postcss-media-query-parser@0.2.3
        │ ├─┬ postcss-reporter@5.0.0
        │ │ ├─┬ chalk@2.3.1
        │ ├── postcss-resolve-nested-selector@0.1.1
        │ ├── postcss-safe-parser@3.0.1
        │ ├─┬ postcss-sass@0.2.0
        │ │ └─┬ gonzales-pe@4.2.3
        │ │   └── minimist@1.1.3
        │ ├── postcss-scss@1.0.4
        │ ├─┬ postcss-selector-parser@3.1.1
        │ │ ├─┬ dot-prop@4.2.0
        │ │ │ └── is-obj@1.0.1
        │ │ ├── indexes-of@1.0.1
        │ │ └── uniq@1.0.1
        │ ├── postcss-value-parser@3.3.0
        │ ├── resolve-from@4.0.0
        │ ├── specificity@0.3.2
        │ │ ├── is-fullwidth-code-point@2.0.0
        │ ├── style-search@0.1.0
        │ ├── sugarss@1.0.1
        │ ├── svg-tags@1.0.0
        │ └─┬ table@4.0.3
        │   ├── UNMET PEER DEPENDENCY ajv@6.2.0
        │   ├── ajv-keywords@3.1.0
        │   ├─┬ chalk@2.3.1
        │   ├── lodash@4.17.5
        │   ├─┬ slice-ansi@1.0.0
        │   └─┬ string-width@2.1.1
        ├─┬ stylelint-config-standard@18.1.0
        │ └── stylelint-config-recommended@2.1.0
        ├─┬ time-grunt@1.4.0
        │ ├─┬ date-time@1.1.0
        │ │ └── time-zone@0.1.0
        │ ├── figures@1.7.0
        │ ├── hooker@0.2.3
        │ ├── number-is-nan@1.0.1
        │ ├─┬ pretty-ms@2.1.0
        │ │ ├── is-finite@1.0.2
        │ │ ├── parse-ms@1.0.1
        │ │ └── plur@1.0.0
        │ └── text-table@0.2.0
        ├── valid-url@1.0.9
        └─┬ walk@2.3.9
          └── foreachasync@3.0.0
        npm WARN ajv-keywords@3.1.0 requires a peer of ajv@^6.0.0 but none was installed.
        pi@raspi3:/123/MagicMirror $
          pinsdorf Module Developer
          If I see it correctly, you are installing Magic Mirror in directory /123/MagicMirror. Usual place is in the home directory of user pi, i.e. /home/pi/MagicMirror or ~/MagicMirror.
          In your startup logs you get many errors on loading resources such as CSS files. I’d assume the web server you are starting as user pi when starting MagicMirror is not allowed to access files in an arbitrary root directory, which your directory /123/MagicMirror actually is.
          • T Offline
            thk4711
            Thank You! After installing it again at /home/pi/MagicMirror it works now. That should be pointed out in the instructions.
              Mykle1 Project Sponsor Module Developer @thk4711
              @thk4711 said in Cant put this to work:
