    Change default interface colors
    16 Posts 6 Posters 18.4k Views 5 Watching
    • 0 Offline
      00conman
      Just wondering, where would I go to change rgb values for the colors on the screen or if the aren’t rgb values then are they hexidecimal?
      • MichMichM Offline
        MichMich
        you can use the /css/custom.css to overwrite all styles. This file is embedded after all other css files, so you should be able to overwrite what you want. Is just a matter of creative CSS usage.
          paviro @00conman
          @00conman what exactly do you mean? Do you want to for example change a text color?
          Another note: Please use a title for new topics that consists of more than just one word so people know what it is about! I chanced it for you this time :)
          – The Doctor
          • K Offline
            KirAsh4 Moderator
            Assuming you’re simply talking about the elements on the display, one possible way is to use a custom CSS file, where you over ride the colors of the various elements.
            • 0 Offline
              00conman
              I’m asking in reference to the color of the text.
              • K Offline
                KirAsh4 Moderator
                For custom modules that you create, you can use the getStyles method to assign a custom CSS file so you can override the colors to whatever you want. For the current, default modules, I think those are hard coded styles. I suppose you can always edit those files should you really want to.
                • 0 Offline
                  00conman
                  I’ll look into it. By the way what calendar are you using?
                  • K Offline
                    KirAsh4 Moderator
                    A modified one that I haven’t checked into the base code yet. :)
                    • 0 Offline
                      00conman
                      Whatever it is it’s awesome. Good on you man.
                      • K Offline
                        KirAsh4 Moderator
                        Once I figure out why git(hub) is pulling in all of the erroneous stuff and fix that, I’ll create a pull request so it gets merged.
                        • K Offline
                          KirAsh4 Moderator
                          By the way, that colorful screen capture was simply demonstrating that if you want to edit the default modules, you can, and you can then color them any way you want. In this case, I opened calendar.js and in the 'getStyles' section, I added another file:
                                  // Define required scripts.
                                  getStyles: function() {
                                          return ["calendar.css", "font-awesome.css", "mystyles.css"];
                          In this instance, 'mystyles.css' is my custom one, which I then created and added my own colors to the various elements:
                          #module_1_clock .time, #module_1_clock .date {
                                  color: #99F;
                          #module_1_clock .dimmed {
                                  color: #449;
                          #module_2_calendar header {
                                  color: #F00;
                                  border-bottom: 2px solid #600;
                          #module_2_calendar .title {
                                  color: #F99;
                          #module_2_calendar .time {
                                  color: #FBB;
                          #module_2_calendar .symbol {
                                  color: #FF0;
                          • K Offline
                            KirAsh4 Moderator
                            The same approach applies when you’re creating your own custom modules. Keep in mind that if you edit the default files, a future update can overwrite them and you lose your changes.
                            • K Offline
                              KirAsh4 Moderator
                              Also note the warning as stated on the wiki page:
                              Note: If a file can not be loaded, the boot up of the mirror will stall.
                              Meaning, if you tell getStyles to look for a file called 'myStyles.css' but in reality it’s called 'mystyles.css' (case matters) or 'coolcolor.css', the mirror will stall and not load. So be careful.
                              • MichMichM Offline
                                MichMich
                                • 0 Offline
                                  00conman
                                  Okay thank you guys I’ll have to look into it.
                                    dyard @KirAsh4
                                    @KirAsh4 Hi I am setting up my first magic mirror, is this old post still valid? This look is great, I tried to follow and add a custom mystyles.css and added to the same calendar module. But I didn’t see it make a change. Thanks for your help
                                      sdetweil @dyard
                                      @dyard please, just edit the css/custom.css, don’t change the module code unless u are fixing a bug or adding function (and then don’t tell anyone about it, release a new updated module)
                                      https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1597692865011
