    Change default interface colors
    16 Posts 6 Posters 18.8k Views 5 Watching
    • 0
      00conman
      I’m asking in reference to the color of the text.
      • K
        KirAsh4 Moderator
        For custom modules that you create, you can use the getStyles method to assign a custom CSS file so you can override the colors to whatever you want. For the current, default modules, I think those are hard coded styles. I suppose you can always edit those files should you really want to.
        D 1 Reply Last reply
        • 0
          00conman
          I’ll look into it. By the way what calendar are you using?
          • K
            KirAsh4 Moderator
            A modified one that I haven’t checked into the base code yet. :)
            • 0
              00conman
              Whatever it is it’s awesome. Good on you man.
              • K
                KirAsh4 Moderator
                Once I figure out why git(hub) is pulling in all of the erroneous stuff and fix that, I’ll create a pull request so it gets merged.
                • K
                  KirAsh4 Moderator
                  By the way, that colorful screen capture was simply demonstrating that if you want to edit the default modules, you can, and you can then color them any way you want. In this case, I opened calendar.js and in the 'getStyles' section, I added another file:
                          // Define required scripts.
                          getStyles: function() {
                                  return ["calendar.css", "font-awesome.css", "mystyles.css"];
                  In this instance, 'mystyles.css' is my custom one, which I then created and added my own colors to the various elements:
                  #module_1_clock .time, #module_1_clock .date {
                          color: #99F;
                  #module_1_clock .dimmed {
                          color: #449;
                  #module_2_calendar header {
                          color: #F00;
                          border-bottom: 2px solid #600;
                  #module_2_calendar .title {
                          color: #F99;
                  #module_2_calendar .time {
                          color: #FBB;
                  #module_2_calendar .symbol {
                          color: #FF0;
                  • K
                    KirAsh4 Moderator
                    The same approach applies when you’re creating your own custom modules. Keep in mind that if you edit the default files, a future update can overwrite them and you lose your changes.
                    • K
                      KirAsh4 Moderator
                      Also note the warning as stated on the wiki page:
                      Note: If a file can not be loaded, the boot up of the mirror will stall.
                      Meaning, if you tell getStyles to look for a file called 'myStyles.css' but in reality it’s called 'mystyles.css' (case matters) or 'coolcolor.css', the mirror will stall and not load. So be careful.
                      • MichMichM
                        MichMich
                        you can use the /css/custom.css to overwrite all styles. This file is embedded after all other css files, so you should be able to overwrite what you want. Is just a matter of creative CSS usage.
                        • 0
                          00conman
                          Okay thank you guys I’ll have to look into it.
                            dyard @KirAsh4
                            @KirAsh4 Hi I am setting up my first magic mirror, is this old post still valid? This look is great, I tried to follow and add a custom mystyles.css and added to the same calendar module. But I didn’t see it make a change. Thanks for your help
                              sdetweil @dyard
                              @dyard please, just edit the css/custom.css, don’t change the module code unless u are fixing a bug or adding function (and then don’t tell anyone about it, release a new updated module)
                              https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1597692865011
