Change default interface colors
16 Posts 6 Posters 16.0k Views 5 Watching
  • 0 Offline
    00conman
    Just wondering, where would I go to change rgb values for the colors on the screen or if the aren’t rgb values then are they hexidecimal?
    P 1 Reply Last reply May 9, 2016, 3:48 PM Reply Quote 0
      MichMich Admin
      you can use the /css/custom.css to overwrite all styles. This file is embedded after all other css files, so you should be able to overwrite what you want. Is just a matter of creative CSS usage.
        paviro Admin @00conman
        @00conman what exactly do you mean? Do you want to for example change a text color?
        Another note: Please use a title for new topics that consists of more than just one word so people know what it is about! I chanced it for you this time :)
        – The Doctor
        • K Offline
          KirAsh4 Moderator
          Assuming you’re simply talking about the elements on the display, one possible way is to use a custom CSS file, where you over ride the colors of the various elements.
          • 0 Offline
            00conman
            I’m asking in reference to the color of the text.
            • K Offline
              KirAsh4 Moderator
              For custom modules that you create, you can use the getStyles method to assign a custom CSS file so you can override the colors to whatever you want. For the current, default modules, I think those are hard coded styles. I suppose you can always edit those files should you really want to.
              D 1 Reply Last reply Aug 18, 2020, 8:54 PM Reply Quote 0
              • 0 Offline
                00conman
                I’ll look into it. By the way what calendar are you using?
                • K Offline
                  KirAsh4 Moderator
                  A modified one that I haven’t checked into the base code yet. :)
                  • 0 Offline
                    00conman
                    Whatever it is it’s awesome. Good on you man.
                    • K Offline
                      KirAsh4 Moderator
                      Once I figure out why git(hub) is pulling in all of the erroneous stuff and fix that, I’ll create a pull request so it gets merged.
                      • K Offline
                        KirAsh4 Moderator
                        By the way, that colorful screen capture was simply demonstrating that if you want to edit the default modules, you can, and you can then color them any way you want. In this case, I opened calendar.js and in the 'getStyles' section, I added another file:
                                // Define required scripts.
                                getStyles: function() {
                                        return ["calendar.css", "font-awesome.css", "mystyles.css"];
                        In this instance, 'mystyles.css' is my custom one, which I then created and added my own colors to the various elements:
                        #module_1_clock .time, #module_1_clock .date {
                                color: #99F;
                        #module_1_clock .dimmed {
                                color: #449;
                        #module_2_calendar header {
                                color: #F00;
                                border-bottom: 2px solid #600;
                        #module_2_calendar .title {
                                color: #F99;
                        #module_2_calendar .time {
                                color: #FBB;
                        #module_2_calendar .symbol {
                                color: #FF0;
