    can someone help pleas with my config/config.js
    9 Posts 3 Posters 3.4k Views 3 Watching
      jiyar
      language: "en",
      timeFormat: 12,
      units: "imperial",
      		module: "alert",
      		module: "updatenotification",
      		position: "top_bar"
      		module: "clock",
      		position: "top_left"
      	        module: 'MMM-PrayerTime',
      	        position: 'top_left',	// This can be any of the regions. Best result is in the top_left/top_right.
      		         apiVersion: '1.0' // please, leave unchanged. reserved for future use.
      		        lat: false, // latitude of your position (city)
      		        lon: false, // longitude of your position (city)
      		        timezone: false, // please refer to http://php.net/manual/en/timezones.php
      		        timeFormat: 12,
      		        method: 5,
      		        playAdzan: ['spede', 'nivro', 'evar', 'maghrib', 'aisha'],
      		        notDisplayed: ['midnight', 'sunset'],
      		        useUpdateInterval: true,
      		        updateInterval: 86400 * 1000, // How often do you want to fetch new praying time? (milliseconds)
      		        animationSpeed: 2.5 * 1000, // Speed of the update animation. (milliseconds)
      		        language: config.language,
      		        showAdzanAlert: true,
      		        alertTimer: 15000
      		module: "compliments",
      		position: "lower_third"
      		module: "currentweather",
      			locationID: "95446",  //ID from http://www.openweathermap.org/help/city_list.txt
      			appid: "bd5e378503939ddaee76f12ad7a97608"
      		module: "weatherforecast",
      		header: "Weather Forecast",
      		module: "newsfeed",
      		position: "bottom_bar",
      			feeds: [
      					title: "New York Times",
      			showSourceTitle: true,
      			showPublishDate: true
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @jiyar
        @jiyar you have two issues, both are in the section of the module prayer time:
        1. after apiVersion there is a comma missing before your comment
          apiVersion: '1.0', // please, leave unchanged. reserved for future use.
        2. There are two brackets too much (} ]), it should be:
            alertTimer: 15000
          jiyar @strawberry 3.141
          @strawberry-3.141 thank u for replaying but I’v got the same problem
          language: “en”,
          timeFormat: 12,
          units: “imperial”,
          		module: "alert",
          		position: "top_bar"
          		module: "clock",
          		        timeFormat: 12,
          		        method: 5,
          		        alertTimer: 15000
          		module: "newsfeed",
          			feeds: [
          • strawberry 3.141S
            @jiyar linting your config on http://jshint.com/ doesn’t give anymore issues, can you specify what the issue is with your config. Can you provide any error logs (pm2, electron, browser, terminal …)?
              @strawberry-3.141 my problems when I run the magicmirror it says creat config file
              • strawberry 3.141S
                @jiyar is your file called config.js? Is it stored in MagicMirror/config/config.js
                  @strawberry-3.141 yes config.js
                    @strawberry-3.141 I add a new module I got this problem but whith defualt config file it works
                    • Mykle1M
                      https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
