    GIF update from URL with MMM-EyeCandy
    26 Posts 5 Posters 14.4k Views 5 Watching
      JRWJR
      Weather radar is a tough thing to solve, but I stumbled across a solution if I can get a module like MM-EyeCandy to do an update pull from the URL.
              module: "MMM-EyeCandy",
              position: "bottom_right",
                  maxWidth: "50%", // Sizes the images. Retains aspect ratio.
                  //style: "1",            // 1 - 52 or use ownImagePath to override style
                  ownImagePath: "https://icons.wxug.com/data/weather-maps/radar/united-states/united-states-current-radar-animation.gif", // ex: "modules/MMM-EyeCandy/pix/YOUR_PICTURE_NAME.jpg", or internet url to image
                  //ownImagePath: "https://icons.wxug.com/data/weather-maps/radar/united-states/san-antonio-texas-region-current-radar-animation.gif",
                  updateInterval: 10 * 60 * 1000,
      It does not appear the updateInterval is working unless it is throwing the following error when isolated.
      Whoops! There was an uncaught exception…
      TypeError: Cannot read property ‘hash’ of null
      at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:68:31
      at Git. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1482:10)
      at done (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1354:21)
      at ChildProcess. (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1379:16)
      at emitTwo (events.js:106:13)
      at ChildProcess.emit (events.js:191:7)
      at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
      Any ideas?
        Mykle1 Project Sponsor Module Developer @JRWJR
        @JRWJR said in GIF update from URL with MMM-EyeCandy:
        I’ll take a look at this tonight
        N 1 Reply Last reply Reply Quote 1
        • N Offline
          ninjabreadman @Mykle1
          @Mykle1 @JRWJR
          I think this should work; add the following at the bottom of the start function in MMM-EyeCandy.js:
            start: function () {
              // ADDED: Schedule update timer
              setInterval(function() {
              self.updateDom(self.config.fadeSpeed || 0); // use config.fadeSpeed or revert to zero
              }, this.config.updateInterval);
            }, // this was line 83
          Mykle1M 1 Reply Last reply Reply Quote 3
            Thanks ninja. I was a little tied up last night with yesterday’s Nor’Easter slamming NYC late into the evening. If you don’t mind, I’ll just incorporate that into the module when I get home from work. :-)
            Peace!
              Mykle1 Project Sponsor Module Developer @ninjabreadman
              @ninjabreadman
              Thanks again but the problem still exists. Let me explain what I’ve done so far.
              1. Added your setInterval(function().
              2. Tried to seed the url of the .gif file with a timestamp but that was rejected with a 404 error.
              3. Added a timestamp div/tag so I could check if the module was actually updating. It is.
              This url is not refreshing upon updateDom but the timestamp is.
              I’m lost. :-/
              • N Offline
                @Mykle1 How did you seed the url with a timestamp? When I visit https://icons.wxug.com/data/weather-maps/radar/united-states/united-states-current-radar-animation.gif?1521767776, I get the image returned (not a 404).
                  @ninjabreadman
                  Like this, because I need the seed to change. Feel free to tell me what I’m doing wrong. Hehe :-)
                  var getTimeStamp = new Date().getTime();
                  img.src = "https://icons.wxug.com/data/weather-maps/radar/united-states/united-states-current-radar-animation.gif&seed=" + getTimeStamp;
                  pic.appendChild(img);
                  wrapper.appendChild(pic);
                  • N Offline
                    @Mykle1 Yep, just needs to be a ? before the first parameter. Anything after gets appended with an &, e.g. https://icons.wxug.com/data/weather-maps/radar/united-states/united-states-current-radar-animation.gif?seed=1521767776&otherseed=4846528&page=2.
                    Making your code the following:
                    ... // img creation, etc
                    img.src = "https://icons.wxug.com/data/weather-maps/radar/united-states/united-states-current-radar-animation.gif?seed=" + getTimeStamp;
                    Mykle1M M 3 Replies Last reply Reply Quote 2
                      @ninjabreadman said in GIF update from URL with MMM-EyeCandy:
                      That did the trick. The .gif file is refreshing to reflect the new data when it changes.
                      Thanks for the lesson. I do appreciate the help.
                      Peace!
                        @JRWJR
                        I will post the update on github shortly. Thanks to our friend, @ninjabreadman, the module now works as it should.
                        EDIT:
                        A git pull in the /MagicMirror/modules/MMM-EyeCandy folder will fix you up. Please take note of the changes to the config.js entry. Also, please take into account that the url you gave only updates itself about every 15 minutes.
