Displaying data from MySQL database
9 Posts 6 Posters 5.0k Views 4 Watching
  • W Offline
    wolkenaj
    Hello! I am quite new to MagicMirror and trying to display personal data from a MySQL database (stored on amazon cloud) in text and graphs on my mirror. I currently have a mixture of html and php files to access the data and display on a website. I would like to transfer the functionality but am unsure how to do so in a compatible way.
    I currently doing so with php:
    	$db = mysqli_connect(REDACTED) or die('Error connecting to MySQL server.');
    	//the SQL query to be executed
    	$query = "SELECT * FROM table";
    	//storing the result of the executed query
    	$result = $db->query($query);
    	//initialize the array to store the processed data
    	$jsonArray = array();
    	//check if there is any data returned by the SQL Query
    	if ($result->num_rows > 0) {
    	  //Converting the results into an associative array
    	  while($row = $result->fetch_assoc()) {
    		  $date= $row['timestamp'];
    	    $jsonArrayItem = array();
    	    $jsonArrayItem['label'] = $date;
    	    $jsonArrayItem['value'] = $row['columnName'];
    	    //append the above created object into the main array.
    	    array_push($jsonArray, $jsonArrayItem);
    	//Closing the connection to DB
    	$db->close();
    	//set the response content type as JSON
    	header('Content-type: application/json');
    	//output the return value of json encode using the echo function.
    	echo json_encode($jsonArray);
    And then displaying with Fusion charts:
    $(function(){
    	  $.ajax({
    	    url: 'http://REDACTED',
    	    type: 'GET',
    	    success : function(data) {
    	      chart1Data = data;
    	      var chart4Properties = {
    	        "caption": " ",
    	        "xAxisName": "Date",
    	        "yAxisName": " ",
    	        "rotatevalues": "1",
    	        "theme": "zune"
    	      api4Chart = new FusionCharts({
    	        type: 'column2d',
    	        renderAt: 'chart4-container',
    	        width: '550',
    	        height: '350',
    	        dataFormat: 'json',
    	        dataSource: {
    	          "chart": chart4Properties,
    	          "data": chart1Data
    	      api4Chart.render();
    Any help would be appreciated. If there is any other information I can provide, please let me know. Thank you :)
    H 1 Reply Last reply Mar 22, 2018, 8:46 PM Reply Quote 0
      cirdan
      @wolkenaj said in Displaying data from MySQL database:
      Copy an existing module with a node_helper.js. The graph section should go into the module js file, the php for db access rewritten into js and inserted into the node helper. Look at my rain forecast module for example https://github.com/73cirdan/MMM-rainfc
      Alternative is to call the php from within the node helper
      Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
      W 1 Reply Last reply Mar 27, 2018, 9:00 PM Reply Quote 0
      • H Offline
        Henrik @wolkenaj
        @wolkenaj You could just display the charts from the website with the iFrame module.
        https://github.com/alberttwong/MMM-iFrame
        C 1 Reply Last reply Mar 23, 2018, 1:30 AM Reply Quote 2
          cowboysdude Module Developer @Henrik
          @Henrik said in Displaying data from MySQL database:
          BINGO…that’s the easiest way :) I have a few ‘modules’ running that way on my mirror.
          • W Offline
            wolkenaj @cirdan
            @cirdan Thank you for this tidbit. I was aware that I would need a node helper. I think my preferred course would be to call the php file from the node helper. I will eventually need to also call a bash script from my node helper if possible as well. Do you know of a module that does a similar call that I could look at for reference?
            N 1 Reply Last reply Mar 27, 2018, 9:13 PM Reply Quote 0
            • N Offline
              ninjabreadman @wolkenaj
              @wolkenaj MMM-PIR-Sensor uses shell scripting in node_helper.js to turn the screen on and off with tvservice.
              W 1 Reply Last reply Mar 30, 2018, 7:29 PM Reply Quote 0
              • W Offline
                wolkenaj @ninjabreadman
                @ninjabreadman This was very helpful to get a node helper function up and running. I am able to receive a socket notification and run a function based on the notification. My program in the node helper currently looks like
                activateShell: function(){
                     console.log("Activating shell");
                     exec("/Test -s");
                I receive the activating shell in the console but the script (a simple echo “Hello World”) does not execute. I’ve tried placing it in my module folder, the Magic Mirror folder, and as a path in the desktop, all to no avail. Would you have any ideas on what is wrong?
                N 1 Reply Last reply Mar 31, 2018, 9:00 AM Reply Quote 0
                • N Offline
                  @wolkenaj /Test will tell the shell to look in the root of the filesystem (/) for Test. Instead, ./ will tell it to look in the current working directory (cwd), which I suspect is ~/MagicMirror. So ./Test is likely what you want.
                  Worst case, you could use the complete path (~/MagicMirror/Test or /home/pi/MagicMirror/Test) which should also work. I also suggest renaming Test to test.sh, just so it’s always immediately apparent that it’s a shell script.
                    cruunnerr
                    Don’t know if it helps and i am trying to keep it short…
                    I build an Oiltank measurement system with another raspberry pi.
                    The results will be written to a mysql database and to a JSON file, which will be uploaded to my NAS.
                    On the NAS i run the database and a web server.
                    To Display the results on a webpage i used this php script: https://github.com/cruunnerr/OilTank-Graph-WebPage
                    To display the results on my MM i got some very much help from our user @doubleT
                    He wrote this module for me: https://github.com/cruunnerr/MMM-Oiltank
                    The module grabs the data from a JSON file and shows it on the MM.
                    Maybe this could help :/
                    MagicMirror:
                    Web Page:
