    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 570.3k Views 58 Watching
    • T
      thebeetleuk
      OK after lots and lots of trial and error I hope this helps people… these are the settings and results I had and as far as I can tell the everyone setting doesnt do what I would expect…
      I don’t hink you have a way of identifying a stranger and do something specific for them?
      defaultClass: "default", //Module set used for strangers and if no user is detected
      It looks like when everyone is specified on its own then the logic doesnt seem to work. See classes: “everyone” below…
                                      users: ['martin'], // Array with usernames (copy and paste from training script)
                                      everyoneClass: "everyone", //Set of modules which should be shown for every user
                                      welcomeMessage: false // Boolean to toggle welcomeMessage
                              module: "clock",
                              classes: "default" // displays with no face detection (OK) - not displayed when martin detected (OK) - displayed with no specific user detected (OK?)
                              module: "clock",
                              classes: "default everyone" // displays with no face detection (OK) - displayed with no specific user and martin (OK)
                              module: "clock",
                              position: "bottom_right",
                              classes: "default martin" // displays with no face detection (OK) - displayed with no specific user and martin (OK)
                              module: "clock",
                              position: "bottom_left",
                              classes: "everyone" // never displays (??? I would expect this to display when Martin is detected - or any other user)
                              module: "compliments",
                              position: "lower_third",
                              classes: "martin" // only displayed when martin detected (OK)
      • G
        gismo2006
        I use your Facial Recognition modul. I have create some user and everything work fine.
        But now I install MMM-Motion-Detection modul. I works fine, too. But if I use this modul your modul didn´t work. When I cut off the MMM-Motion-Detection module from config.js and start again your modul will work fine again.
        Can someone help me?
        greets gismo
          PrivatVoidMarmot @paviro
          @paviro I have the same problem like @shashank, but I don’t figure out any mistake… the trainingfile is in the right direction… It doesn’t work with PiCam and with an webcam neither…
            PrivatVoidMarmot
            Sorry for spaming,
            but I tried to refresh everything. So I installed the Rasbian new, the Magic Mirror, the Facial Recognition and the Tools. It worked… ONCE. After rebooting the system I have the same error as bevor:
            It load training data and select the PiCam and then it doesn’t go on. No error-message.
            Any idea which component was active when I reinstalled everything and isn’t active after rebooting?
            The camera is enabled.
              jer78
              I have the same issue. Training went fine. I got everything working but then after a reboot it seems to load the module but then nothing. It doesn’t seem to want to do anything. No errors just no facial recognition.
              J 1 Reply Last reply
                jer78 @jer78
                So I figured out my own problem. Seems like it doesn’t like it when I changed the language file. Restored the old one and everything works as it should. Also, I find raising the threshold to 250 for the LBPH Algorithm helps a lot to get more accurate results. The confidence seems to hover around 49-52 for me but I couldn’t get any results with 50, constantly thought I was “stranger”. Thanks for all the hard work on this module. It’s really fun to play with!
                  Prestitivo
                  I got this module working after a bit of trial and error, and it’s awesome. I only have 1 issue so far. When I’m recognized, all of the modules drop by about 30 pixels. I’m not a programmer by any stretch of the imagination, but have no issues looking around at code trying to figure out what it does. I used Firebug to see what was going, and from what I can see, the one of the div’s updates from style=“display: none;” to style=“display: block;”. The part that’s really confusing me is that it only does this when it recognizes me. When it recognizes a stranger, none of the modules shift. I can provide anything requested, but I wasn’t sure if anyone else was experiencing this issue.
                    j.e.f.f Project Sponsor Module Developer @Prestitivo
                    @Prestitivo It means you’ve configured that module to be displayed when you are recognized, and hidden when you are not. Take a look at your config to see if you can pinpoint which module is making this happen.
                      Prestitivo
                      Ah yes, thank you. It was the “updatenotification” module in the top bar. I took myself off of that, and now it works as expected. Now that I think about it, that makes sense.
                      Still have a lot of tinkering to do, but this solved the annoying issue I caused.
                      Thank you kindly for the help.
                      • W
                        WookyDO
                        Hi… will there be any possibility to use Facial Recognition along with motion detection for turning on/off the Display ?
                        Regards,
                        Wolfgang
                        • E
                          eviltrooper
                          Hello, have some Proplem with this Modul:
                          0|mm  | > magicmirror@2.5.0 start /home/pi/MagicMirror
                          0|mm  | > sh run-start.sh
                          0|mm  | Starting MagicMirror: v2.5.0
                          0|mm  | Loading config ...
                          0|mm  | Loading module helpers ...
                          0|mm  | No helper found for module: alert.
                          0|mm  | Initializing new module helper ...
                          0|mm  | Module helper loaded: updatenotification
                          0|mm  | No helper found for module: clock.
                          0|mm  | Module helper loaded: MMM-Facial-Recognition
                          0|mm  | Module helper loaded: calendar
                          0|mm  | Module helper loaded: MMM-EARTH
                          0|mm  | No helper found for module: currentweather.
                          0|mm  | No helper found for module: weatherforecast.
                          0|mm  | Check MagicMirror version for node helper 'MMM-LocalTemperature' - Minimum version:  2.2.1 - Current version: 2.5.0
                          0|mm  | Version is ok!
                          0|mm  | Module helper loaded: MMM-LocalTemperature
                          0|mm  | Module helper loaded: mmm-systemtemperature
                          0|mm  | Module helper loaded: newsfeed
                          0|mm  | All module helpers loaded.
                          0|mm  | Starting server on port 8080 ...
                          0|mm  | Server started ...
                          0|mm  | Connecting socket for: updatenotification
                          0|mm  | Connecting socket for: MMM-Facial-Recognition
                          0|mm  | Starting module helper: MMM-Facial-Recognition
                          0|mm  | Connecting socket for: calendar
                          0|mm  | Starting node helper for: calendar
                          0|mm  | Connecting socket for: MMM-EARTH
                          0|mm  | Starting module: MMM-EARTH
                          0|mm  | Connecting socket for: MMM-LocalTemperature
                          0|mm  | MMM-LocalTemperature: module loaded! Path: /home/pi/MagicMirror/modules/MMM-LocalTemperature
                          0|mm  | Connecting socket for: mmm-systemtemperature
                          0|mm  | Starting node helper: mmm-systemtemperature
                          0|mm  | Connecting socket for: newsfeed
                          0|mm  | Starting module: newsfeed
                          0|mm  | Sockets connected & modules started ...
                          0|mm  | (node:11742) [DEP0025] DeprecationWarning: sys is deprecated. Use util instead.
                          0|mm  | Launching application.
                          0|mm  | libGL error: MESA-LOADER: failed to retrieve device information
                          0|mm  | MESA-LOADER: failed to retrieve device information
                          0|mm  | Create new calendar fetcher for url: http://.... - Interval: 300000
                          0|mm  | Whoops! There was an uncaught exception...
                          0|mm  | TypeError: PythonShell is not a constructor
                          0|mm  |     at Class.python_start (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:11:21)
                          0|mm  |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:40:14)
                          0|mm  |     at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
                          0|mm  |     at emitTwo (events.js:126:13)
                          0|mm  |     at Socket.emit (events.js:214:7)
                          0|mm  |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:513:12
                          0|mm  |     at _combinedTickCallback (internal/process/next_tick.js:131:7)
                          0|mm  |     at process._tickCallback (internal/process/next_tick.js:180:9)
                          0|mm  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          0|mm  | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          0|mm  | Create new calendar fetcher for url: http://i.cal.to/.....ics - Interval: 300000
                          0|mm  | https://epic.gsfc.nasa.gov/api/natural
                          0|mm  | MMM-LocalTemperature: Socket Notification Received: "INIT".
                          0|mm  | MMM-LocalTemperature: Socket Notification Received: "GET_DATA".
                          0|mm  | Create new news fetcher for url: https://www.ofc.de/rss-feed.xml - Interval: 300000
                          0|mm  | Create new news fetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                          anyone an idea?
                          N 1 Reply Last reply
                          • N
                            nano79 @eviltrooper
                            @eviltrooper you can also install an older version of python-shell (0.4.0 ) and it works without modifying the node_helper.js file! You can install this specific version of python-shell by this command:
                            npm install python-shell@0.4.0
                            L 1 Reply Last reply
                            • N
                              nano79
                              Hey @paviro ! I’m having an issue with the module. This module worked only once for me. Now it just logs into the “everyone” page and doesn’t recognize me anymore. How do I fix this?
                              • L
                                lovesicker @nano79
                                @nano79
                                Fist of all, thanks @MichMich @paviro and @tosti007 gave me provided these fantastic applications and modules!
                                Secondly, thanks for your help! According to your method, I installed python-shell 0.4.0 and resolved the issue of “PythonShell is not a constructor” .
                                Now I had another issue in the followed steps.
                                I have installed and configured MMM-Facial-Recognition-Tools, MMM-Facial-Recognition and MMM-ProfileSwitcher. I passed the facerecognition.py test:
                                pi@MagicMirror2:~/MagicMirror/modules/MMM-Facial-Recognition-Tools $ export FACE_ALGORITHM=1
                                pi@MagicMirror2:~/MagicMirror/modules/MMM-Facial-Recognition-Tools $ export FACE_USERS=
                                pi@MagicMirror2:~/MagicMirror/modules/MMM-Facial-Recognition-Tools $ export FACE_USERS=Xueping
                                pi@MagicMirror2:~/MagicMirror/modules/MMM-Facial-Recognition-Tools $ python facerecognition.py
                                ['Xueping']
                                Using FACE_ALGORITM: 1
                                Loading training data...
                                Training data loaded!
                                Strong:Xueping
                                Strong:Xueping
                                Strong:Xueping
                                Strong:Xueping
                                Strong:Xueping
                                Strong:Xueping
                                Now I added the configuration in config.js as followings:
                                            module: 'MMM-Logging',
                                            classes: 'default everyone',
                                			module: "alert",
                                			module: "updatenotification",
                                			position: "top_bar",
                                			classes: 'Xueping',
                                				compliments: {
                                					anytime: [
                                						"Hello!THIS IS TESTING!"
                                			module: "clock",
                                			classes: 'everyone'
                                			module: 'MMM-Facial-Recognition',
                                				// 1=LBPH | 2=Fisher | 3=Eigen
                                				recognitionAlgorithm: 1,
                                				lbphThreshold: 50,
                                				fisherThreshold: 250,
                                				eigenThreshold: 3000,
                                				alwaysShowLeave: false,
                                				useUSBCam: false,
                                				trainingFile: '/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/training.xml',
                                				interval: 2,
                                				logoutDelay: 30,
                                				users: ['Xueping'],
                                				welcomeMessage: true,
                                			module: 'MMM-ProfileSwitcher',
                                				// Disable the enter messages for everyone but me and Kevin
                                				enterMessages: {
                                					"Xueping": "Hello :D", // Kevin has a custom message
                                					"everyone": "Hello :D",
                                					"default": "No Users were detected"
                                				// Everyone has a custom message
                                				leaveMessages: {
                                					// %profile% will be replaced with the correct name
                                					"everyone": "Hey %person%, already leaving?",
                                					// I have a custom and the default message
                                					//  this is not the same as everyone since we changed it
                                					"Xueping": ["Bye bye!"],
                                					"default": "Goodbye"
                                			module: "MMM-ping",
                                			classes: 'default',
                                				colored: true,
                                				font: "xsmall",
                                				updateInterval: 1,
                                				hosts: [
                                					"192.168.1.1",
                                					"forum.magicmirror.builders"
                                When I run MagicMirror, the screen layout changed from default classes mode into user classes mode. the icons, which is in default classes mode, disappeared as I want. BUT in user classes mode, the very module (compliments) did not appeared! the whole screen is still black.
                                The whole process log is as following:
                                2019-03-15T15:08:50 <log> [MMM-Facial-Recognition] Facerecognition started... (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:16 PythonShell.<anonymous>)
                                2019-03-15T15:08:50 <log> [MMM-Facial-Recognition] Loading training data... (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:16 PythonShell.<anonymous>)
                                2019-03-15T15:08:50 <log> [MMM-Facial-Recognition] ALGORITHM: LBPH (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:16 PythonShell.<anonymous>)
                                2019-03-15T15:08:55 <log> [MMM-Facial-Recognition] Training data loaded! (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:16 PythonShell.<anonymous>)
                                2019-03-15T15:08:55 <log> [MMM-Facial-Recognition] -------------------- (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:16 PythonShell.<anonymous>)
                                2019-03-15T15:08:55 <log> [MMM-Facial-Recognition] PiCam ausgewählt... (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:16 PythonShell.<anonymous>)
                                2019-03-15T15:09:07 <log> [MMM-Facial-Recognition] User Xueping with confidence 29.2076146738 logged in. (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:19 PythonShell.<anonymous>)
                                [3656:0315/150907.528143:INFO:CONSOLE(205)] "MMM-ping is resumed.", source: http://10.133.26.219:8080/js/module.js (205)
                                [3656:0315/150907.532130:INFO:CONSOLE(154)] "clock received a module notification: CURRENT_USER from sender: MMM-Facial-Recognition", source: http://10.133.26.219:8080/js/module.js (154)
                                [3656:0315/150907.533400:INFO:CONSOLE(154)] "MMM-ping received a module notification: CURRENT_USER from sender: MMM-Facial-Recognition", source: http://10.133.26.219:8080/js/module.js (154)
                                2019-03-15T15:09:07 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                [3656:0315/150907.543631:INFO:CONSOLE(205)] "compliments is resumed.", source: http://10.133.26.219:8080/js/module.js (205)
                                [3656:0315/150907.544869:INFO:CONSOLE(275)] "Will not show compliments. LockStrings active: module_6_MMM-ProfileSwitcher", source: http://10.133.26.219:8080/js/main.js (275)
                                [3656:0315/150907.545862:INFO:CONSOLE(154)] "clock received a module notification: CURRENT_USER from sender: MMM-Facial-Recognition", source: http://10.133.26.219:8080/js/module.js (154)
                                [3656:0315/150907.546709:INFO:CONSOLE(154)] "MMM-ping received a module notification: CURRENT_USER from sender: MMM-Facial-Recognition", source: http://10.133.26.219:8080/js/module.js (154)
                                [3656:0315/150907.552615:INFO:CONSOLE(154)] "clock received a module notification: SHOW_ALERT from sender: MMM-Facial-Recognition", source: http://10.133.26.219:8080/js/module.js (154)
                                [3656:0315/150907.554160:INFO:CONSOLE(154)] "MMM-ping received a module notification: SHOW_ALERT from sender: MMM-Facial-Recognition", source: http://10.133.26.219:8080/js/module.js (154)
                                [3656:0315/150908.582237:INFO:CONSOLE(198)] "MMM-ping is suspended.", source: http://10.133.26.219:8080/js/module.js (198)
                                [3656:0315/150908.587425:INFO:CONSOLE(60)] "MMM-ping is hidden.", source: http://10.133.26.219:8080/modules/MMM-Facial-Recognition//MMM-Facial-Recognition.js (60)
                                2019-03-15T15:11:08 <log> [MMM-Facial-Recognition] User Xueping logged out. (/home/pi/MagicMirror/modules/MMM-Facial-Recognition/node_helper.js:23 PythonShell.<anonymous>)
                                [3656:0315/151108.702056:INFO:CONSOLE(205)] "MMM-ping is resumed.", source: http://10.133.26.219:8080/js/module.js (205)
                                [3656:0315/151108.712169:INFO:CONSOLE(154)] "clock received a module notification: CURRENT_USER from sender: MMM-Facial-Recognition", source: http://10.133.26.219:8080/js/module.js (154)
                                [3656:0315/151108.712959:INFO:CONSOLE(154)] "MMM-ping received a module notification: CURRENT_USER from sender: MMM-Facial-Recognition", source: http://10.133.26.219:8080/js/module.js (154)
                                2019-03-15T15:11:08 <log>  payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                [3656:0315/151109.703213:INFO:CONSOLE(198)] "compliments is suspended.", source: http://10.133.26.219:8080/js/module.js (198)
                                [3656:0315/151109.703561:INFO:CONSOLE(78)] "compliments is hidden.", source: http://10.133.26.219:8080/modules/MMM-Facial-Recognition//MMM-Facial-Recognition.js (78)
                                [3656:0315/151109.709930:INFO:CONSOLE(84)] "MMM-ping is shown.", source: http://10.133.26.219:8080/modules/MMM-Facial-Recognition//MMM-Facial-Recognition.js (84)
                                ^C
                                pi@MagicMirror2:~/MagicMirror $
                                Could you or anyone give me some suggestions? Thanks in advance.
                                • I
                                  Irfan ali @YourhighnessLeender
                                  @YourhighnessLeender Hi bro
                                    BiaGen @PointPubMedia
                                    Getting the orientation right for the training images was the trickiest part for me. If your PiCam or USB cam is mounted at an odd angle (or upside down for cable management), the recognition often fails because the training set doesn’t match the live feed.
                                    If anyone is struggling with mirrored images in their preview or while testing their training data, I found this quick tool helpful to flip them before feeding them into the trainer- https://www.thetoolapp.com/mirror-image-online/. It’s a lot faster than script-flipping every individual JPEG when you’re just trying to troubleshoot the dataset.
                                    • 10
                                    • 11
                                    • 11 / 11
