    MMM-ImageSlideshow no showing and no errors in the log
    15 Posts 5 Posters 9.7k Views 5 Watching
      pbrunson
      Correct, I will look try these adds.
        Mykle1 Project Sponsor Module Developer @pbrunson
        @pbrunson said in MMM-ImageSlideshow no showing and no errors in the log:
        I see something else. You have
        module: 'MMM-ImageSlideShow',
        when you should have
        module: 'MMM-ImageSlideshow',
        That’s likely your problem
          pbrunson
          That was it, works great now (well after I put the fix settings in), thank you.
          Did I see something about if the images change, this will not pick them up? I have another script that grabs updated images (same name) and puts them in the folder every hour. Will the module update them?
            @pbrunson
            The names wouldn’t have to be the same as long as the new files reside in correct path. However, the Dom may have to update so that MM isn’t just loading them from the initial loading/cache (If that’s how the module works)
            Peace!
              pbrunson
              Great thank you, I will keep an eye on it.
                drfukc
                @Mykle1
                I am successfully running the MMM-ImageSlideshow module, but the images in my image directory are constantly changing. Looks like the images are all loaded from cached folder information.
                How would I update the Dom to get my new images on the mirror?
                Cheers
                  sdetweil @drfukc
                  @drfukc the module needs to be changed to search for files again, instead of just once
                  Module MMM-ImagesPhotos does update on a cycle u can configure
                  • Alex2020A Offline
                    Alex2020
                    Salve mi piace moltissimo questo modulo solo un piccola informazione si può aggiungere un testo ? e in caso dove va scritto nel file css.custom oppure nella directory MMM-ImageSlideshow?inoltre gentilmente potreste dirmi quale sia la sintassi CSS da scrivere? Sono all’inizio di questo ‘mondo’.Grazie in anticipo.
                      sdetweil @Alex2020
                      @Alex2020 what information do u want to add and where on the screen?
                      Alex2020A 1 Reply Last reply Reply Quote 0
                      • Alex2020A Offline
                        Alex2020 @sdetweil
                        @sdetweil ho messo tutte immagini di locandine di films che ho visto recentemente al cinema e vorrei mettere il titolo "ULTIMI FILMS VISTI"come si imposta la sintassi nel file css,la position dell modulo è top_left nel mio caso.?Grazie.
