    Ecobee
    50 Posts 19 Posters 44.7k Views 20 Watching
    • cowboysdudeC
      Anything is possible… npm has a few modules for ecobee so it’s doable… however I am VERY new to programming with js and this is above my pay grade LOL
      I’m thinking that this: homebridge-ecobee3-sensors from npm would work…
      • F
        fabbr
        Coming soon !!!
        Who wants to help me BETA test this?
        alt text
        S E G 3 Replies Last reply
        Reply Quote 3
        • E
          E3V3A
          @TheDireOne said in Ecobee:
          Ecobee
          https://support.ecobee.com/hc/en-us/articles/115006260748-How-do-I-enable-Amazon-Alexa-Voice-Service-on-my-ecobee4-
          rpi3 inside??
          “Everything I do (here) is for free – altruism is the way!”
          F 1 Reply Last reply
          • F
            fabbr @E3V3A
            @E3V3A ecobee4 has Alexa in it.
              stephenmelody @fabbr
              @fabbr count me in! Would love to add this!!
              • E
                E3V3A @fabbr
                @fabbr said in Ecobee:
                Me too, where;s your repo?
                • G
                  getsarcasm @fabbr
                  @fabbr I’ll help with the beta - much appreciated!
                  • F
                    fabbr
                    @stephenmelody @E3V3A @getsarcasm I will PM you this week as soon as a fix the registration process. I tested this whole weekend and it’s working beautifully!
                    Thank you for helping
                    M 1 Reply Last reply
                    Reply Quote 2
                      majik655 @fabbr
                      @fabbr I am new to magicmirror but have it working with motion activation so I at least have gotten that far. I have also been able to install and use facial recognition but it being problematic I am currently not using it.
                      I would love to test this with my ecobee 3 if it helps you any because having an ecobee module would be awesome!
                      Thank you!
                      • F
                        fabbr
                        @stephenmelody @E3V3A @getsarcasm @majik655
                        Here is the git repo for you to download the module.
                        https://github.com/fabbr/MMM-Ecobee
                        Code is very messy because I haven’t cleaned up anything yet, but it’s working.
                        Please report any problems, ideas, suggestions, configuration, question, etc. etc. to me (PM or at gitHub) so I can improve this. Also if you can help in any way, please let me know.
                        This is my first module, I have spent way too many hours on it but I am proud to give something back to this amazing community.
                          stephenmelody
                          Where do I find the code to enter on the ecobee portal??
                            majik655 @stephenmelody
                            @stephenmelody I will be installing this tonight but in theory the code should be given to you on the device you are trying to connect…
                            So start the module and it should give a code on the screen…then you can put that in on the portal at ecobee.com
                            Again sorry I am answering without actually installing it but the way ecobee works is the code is given from the device connecting to ecobee.
                            I will update tonight when I get it installed.
                            • F
                              fabbr @majik655
                              @majik655 @stephenmelody That is correct. you will get the code after you do the git clone and added the module to the config.js
                              Code refresh every 5min so you need to be quick on adding it to your account :)
                                stephenmelody
                                Got it… I had it hidden due to some other module, my bad…
                                Quick question, can it show Celsius instead of Fahrenheit?
                                • F
                                  fabbr @stephenmelody
                                  @stephenmelody Yes, but not correctly. I added this suggestion for the next release. Let me know if you have more :)
                                    stephenmelody
                                    Ok, I can do that, although you might regret it!!
                                    Some questions that might turn into requests… but these all seem to be minor tweaks
                                    Does the heat symbol change colour depending on whether the system is heating or cooling, like it does on the app? (orange flame for heating, blue snowflake for cooling). In the example below, it’s currently 68, targeting 71. The app shows the flame in orange, that would be nice to quickly visualise if the system is running.
                                    Can the order in which the sensors are presented be set? For example, I’d like my Thermostat to be at the top, not the bottom
                                    It would be nice to be able to toggle what you see, for example, on my thermostat, I’m not too bothered about the humidity, so it would be nice to toggle that off - that would make the module smaller on my screen.
                                    Great work by the way, I’m happy this is a new module, I’ve been hoping for this one for a while!!!
                                    Here’s what I see
                                    • F
                                      @stephenmelody said in Ecobee:
                                      Currently No. I could add that tho. Currently the way you can check if the system is running or not is by checking the icon of the thermostat. It will change depending on the running status. I did that because a lot of people don’t like to have colors on their Mirrors. However, if you think this would make it better, elaborate on the different status and what should be displayed and I will work on having that as an option!
                                      If you haven’t notice, when there’s motion the icon of the sensor also changes :)
                                      Not currently. The results of the API will always give the Thermostat as the last “device” I can have that as an option also. Any other order change that you think should happen?
                                      I will add that an option, keep in mind that you won’t save any space on the module, you only will see less information.
                                      Here’s what I see
                                      I am happy that it’s working! I have spend countless hours working on it.
                                        stephenmelody
                                        Checking the icon of the thermostat - what are the options here? mine says ON, but the system is in idle (neither heating nor cooling). Is that what you meant? I have noticed the motion icon - I like that!
                                        If you could toggle the displayed info, wouldn’t all the icons shift over to the right, if there was less on the line?
                                        Elaboration, I think these would be the options, to be honest, I think it would just be System Heat Mode and System Cool Mode that I would be intereted in, I don’t have the capabilities for the other icons. I know a number of modules that I have allow for the toggle of colour on / off:
                                        alt text
                                        • F
                                          Right now it will show if the Thermostat is set to a mode (ON) or off (OFF)
                                          First image is OFF, Second is set to AUTO (69-64):
                                          Screen_Shot_2018_04_06_at_10_38_16_AM
                                          Screen_Shot_2018_04_06_at_10_41_20_AM
                                          That being said, to show when it’s ACTUALLY running I need to figure what is the best way. (if that is important)
                                          Not the way the I have the code running right now :(
                                          So you want to see the colors in the module? or see them when the machine is running only?
                                          Thanks for the feedback. I can’t way to go back to work on it :)
                                            stephenmelody
                                            OK, what would be “important” to me, would be to show what the system is doing:
                                            So if the AC is running, then a Blue Snowflake, if the Heating is running, an Orange Flame, it would just need to be one of them, not both, as per the app example. If nothing is actually running, then white would be fine.
                                            For example:
                                            Heating:
                                            alt text
                                            Cooling:
                                            alt text
