    MMM-voice setup but MagicMirror wont display
    31 Posts 4 Posters 19.0k Views 4 Watching
      shazglass
      @cyberphox said in MMM-voice setup but MagicMirror wont display:
      cat /proc/asound/cards
      the one above I took the USB sound card out and plugged the mic directly to the pi.
      this one I did your command again with the sound card in the USB slot and mic connected to USB sound card:
      pi@raspberrypi:~ $ cat /proc/asound/cards
      0 [ALSA ]: bcm2835_alsa - bcm2835 ALSA
      bcm2835 ALSA
      1 [Device ]: USB-Audio - USB Audio Device
      GeneralPlus USB Audio Device at usb-3f980000.usb-1.3, full speed
        shazglass @shazglass
        I have gone onto the pi itself and chossen the usb as an audio device with clicking microphone and microphone capture… but still shows the “error” in MM display.
          cyberphox
          and you ran the dependencies script from the installers folder?
            cyberphox
            mine was error cause i accidentally cloned into MMM-Voice…capital V and it didnt create the dic file…
            maybe try running npm start dev and see what errors you have in the console
              shazglass @cyberphox
              @cyberphox yes, that I def did -was super careful with that.
                @cyberphox heres what I get with the npm start dev…not sure I am doing this in the right dir. I checked the Capital V or v, and mine is def lowercase v
                pi@raspberrypi:~/MagicMirror/modules/MMM-voice $ npm start dev
                npm ERR! missing script: start
                npm ERR! /home/pi/.npm/_logs/2018-04-07T15_24_32_070Z-debug.log
                  pi@raspberrypi:~/MagicMirror $ npm start dev
                  magicmirror@2.3.1 start /home/pi/MagicMirror
                  sh run-start.sh “dev”
                  Starting MagicMirror: v2.3.1
                  Loading config …
                  Loading module helpers …
                  Module helper loaded: MMM-EARTH
                  No helper found for module: MMM-CountDown.
                  Module helper loaded: MMM-voice
                  No helper found for module: MMM-QRCode.
                  All module helpers loaded.
                  Starting server on port 8080 …
                  Server started …
                  Connecting socket for: MMM-EARTH
                  Starting module: MMM-EARTH
                  Connecting socket for: MMM-voice
                  Starting module helper: MMM-voice
                  Starting module: newsfeed
                  Sockets connected & modules started …
                  Launching application.
                  https://epic.gsfc.nasa.gov/api/natural
                  Create new news fetcher for url: http://ewn.co.za/RSS Feeds/Latest News - Interval: 300000
                  MMM-voice: Checking files.
                  MMM-voice: Starting pocketsphinx.
                  Shutting down server…
                  Stopping module helper: updatenotification
                  Stopping module helper: MMM-EARTH
                  Stopping module helper: MMM-voice
                  Stopping module helper: newsfeed
                    cyberphox
                    is the dev window…check the console tab…look for errors
                      @cyberphox hi… I am so hard trying not to be an ass… but I dont know what you mean? Sorry…I am serously a 5 day taught myself to help my son with his project.
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @shazglass
                        @shazglass said in MMM-voice setup but MagicMirror wont display:
                        No worries dude. Personally, I’m glad to see you involved with your son. That’s how this started for me. I wanted to have something in common with my 21 year old son so I could stay “cool” in his eyes. Now . . .
                        I don’t use voice on my Pi mirror anymore but I do use it extensively on other boards. This is what I remember.
                        • I didn’t use a 3rd party sound card
                        • USB microphone plugged directly into USB port of the Pi
                        • Needing to run alsamixer in a terminal window to set mic/capture device.
                        • Testing mic by recording your voice (forgot command - google it)
                        After that, installing MMM-voice, paying careful attention to the directions on how to install the dependencies. If at this point the module runs but displays a microphone and the word “ERROR” then I can help you. If, on the other hand, the module does not run and errors in the terminal or the dev console then something in your beginning steps is amiss
                          shazglass @Mykle1
                          @Mykle1 Good morning.
                          thank you for the reply, makes a lot of sense. I don’t know how to run alsamixer? which directory would I do that in. I have tested the mic and it def works. I am at the point where it displays a microphone with ERROR showing. Sometimes it says , INITIALISING, CHOOSE MODE, then straight away shows ERROR again. Is there something on the pi I need to configure? thnx again Mykle, and I am a mom to a 15 year old :)
                          strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 0
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @shazglass
                            @shazglass There is a error log in the module. Also there is a hidden debug option for for informations debug: true
                              shazglass @strawberry 3.141
                              @strawberry-3.141 Hi - thank you for your reply. Ok, so how do I fix the error log in the module? and where must i type debug: true? Sorry for being a pain - like I said, I have no idea, I am seriously just helping my son, who also just taught himself by reading all of this information.
                              • strawberry 3.141S
                                @shazglass
                                  module: 'MMM-voice',
                                  position: 'bottom_bar',
                                    microphone: 1,
                                    debug: true
                                post your error and debug log, it’s huge so maybe on pastebin
                                  @strawberry-3.141
                                  /* Magic Mirror Config Sample
                                   * MIT Licensed.
                                  var config = {
                                  	port: 8080,
                                  	language: "en",
                                  	timeFormat: 24,
                                  	units: "metric",
                                  			module: "alert",
                                  			module: "updatenotification",
                                  			position: "top_bar"
                                  			module: "clock",
                                  			position: "top_left"
                                  			module: "mmm-systemtemperature",
                                  			position: "top_center",
                                  			classes: 'small dimmed',
                                      			module: "MMM-Lunartic",
                                  					image: "animation",
                                  					distance: "km",
                                  					useHeader: true,
                                  					header: "The Moon",
                                  					maxWidth: "300px",
                                  					animationSpeed: 3000,
                                  			module: "compliments",
                                  			position: "lower_third",
                                  				compliments: {
                                  					anytime: [
                                  						"Hey there Tyler!"
                                  					morning: [
                                  						"Good morning, Tyler!",
                                  						"Enjoy your day!",
                                  						"How was your sleep Tyler?"
                                  					afternoon: [
                                  						"Hello, Tyler!",
                                  						"How was school Tyler?",
                                  						"Looking good today!"
                                  					evening: [
                                  						"Have a great evening!",
                                  						"You look nice!",
                                  						"Sleep well Tyler!"
                                  			module: "currentweather",
                                  				locationID: "3362024",  //ID from http://www.openweathermap.org/help/city_list.txt
                                  				appid: "9cb2b560a465957274fa56860a202af5"
                                  			module: "weatherforecast",
                                  			header: "Weather Forecast",
                                  				appid: "c65138e0beb14c63bdf5f804f8816f74"
                                  			module: "MMM-CountDown",
                                  			position: "bottom_right",
                                  				event: "End of Term 2",
                                  				date: "2018-06-22",
                                  			module: "MMM-voice",
                                  			position: "bottom_bar",
                                  				microphone: 1,
                                  			debug: true
                                  			module: "MMM-QRCode",
                                  			position: "bottom_left",
                                  				text: " Scan to join Home Wifi",
                                  				colorDark  : "#fff",
                                  				colorLight : "#000",
                                          			imageSize  : 60,
                                          			showRaw    : false,
                                  			module: "newsfeed",
                                  				feeds: [
                                  						title: "EWN News",
                                  						url: "http://ewn.co.za/RSS%20Feeds/Latest%20News"
                                  				showSourceTitle: true,
                                  				showPublishDate: true
                                  This is my config/config.js I have no clue whats wrong, but things arent even in the same place as before? The QRCode is higher, the Countdown is higher, the Moon thing is squashed. I think I am killing my sons project. The MM shows the mic display but says ERROR then UNDEFINED.
                                  • Mykle1M
                                    That is fantastic, and you are most welcome. I will leave you in the hands of @strawberry 3.141. He is the author of MMM-voice and best qualified to help you. If there is anything else that I can help you with, just ask, or PM me.
                                    A chilly, sunny NYC morning to you. :-)
                                    S 2 Replies Last reply Reply Quote 1
                                      shazglass @Mykle1
                                      @Mykle1 Thank you!! I hope I can help my son with this! Thank you for your help, I seriously appreciate your time.
                                      From a hot sunny South Africa;)
                                        cyberphox
                                        if Strawberry can’t fix it…no one can!!!
                                          shazglass @Mykle1
                                          @Mykle1
                                          I would just like to say a MASSIVE and HUGE THANK YOU to you for helping me fix the problem I was experiencing!! I PM’ed you and you have spend the last 10 minutes of your Sunday helping out a complete stranger who half the time didn’t know what you were asking me to do.
                                          So, you will be mentioned in my son’s science project that he has chosen to do the MM on.
                                          without you, there was no WOW factor! @Mykle1 - you are an ANGEL!!! thank you so much!!! x
                                          strawberry 3.141S 1 Reply Last reply Reply Quote 1
                                          • strawberry 3.141S
                                            @shazglass maybe you want to explain here what solved your issue, so people that experience the same issue can see the solution :)
