    MMM-voice setup but MagicMirror wont display
    31 Posts 4 Posters 19.3k Views 4 Watching
      shazglass @cyberphox
      @cyberphox wow that was a fast response! thank you
      ok, removed the … MM now works but shows a microphone and says error.
      What have I done wrong?
        shazglass @shazglass
        I have my mic plugged into a USB sound card on my pi. Is that ok, or should I plug it directly into the audio of the pi? My mic is not a USB connection.
          cyberphox
          Run this from terminal
          cat /proc/asound/cards
          and see if your microphone is listed as : 1
            @cyberphox said in MMM-voice setup but MagicMirror wont display:
            this is the response:
            pi@raspberrypi:~ $ cat /proc/asound/cards
            0 [ALSA ]: bcm2835_alsa - bcm2835 ALSA
            bcm2835 ALSA
            pi@raspberrypi:~ $
              shazglass
              the one above I took the USB sound card out and plugged the mic directly to the pi.
              this one I did your command again with the sound card in the USB slot and mic connected to USB sound card:
              bcm2835 ALSA
              1 [Device ]: USB-Audio - USB Audio Device
              GeneralPlus USB Audio Device at usb-3f980000.usb-1.3, full speed
                I have gone onto the pi itself and chossen the usb as an audio device with clicking microphone and microphone capture… but still shows the “error” in MM display.
                  cyberphox
                  and you ran the dependencies script from the installers folder?
                    cyberphox
                    mine was error cause i accidentally cloned into MMM-Voice…capital V and it didnt create the dic file…
                    maybe try running npm start dev and see what errors you have in the console
                      @cyberphox yes, that I def did -was super careful with that.
                        @cyberphox heres what I get with the npm start dev…not sure I am doing this in the right dir. I checked the Capital V or v, and mine is def lowercase v
                        pi@raspberrypi:~/MagicMirror/modules/MMM-voice $ npm start dev
                        npm ERR! missing script: start
                        npm ERR! /home/pi/.npm/_logs/2018-04-07T15_24_32_070Z-debug.log
                          pi@raspberrypi:~/MagicMirror $ npm start dev
                          magicmirror@2.3.1 start /home/pi/MagicMirror
                          sh run-start.sh “dev”
                          Starting MagicMirror: v2.3.1
                          Loading config …
                          Loading module helpers …
                          Module helper loaded: MMM-EARTH
                          No helper found for module: MMM-CountDown.
                          Module helper loaded: MMM-voice
                          No helper found for module: MMM-QRCode.
                          All module helpers loaded.
                          Starting server on port 8080 …
                          Server started …
                          Connecting socket for: MMM-EARTH
                          Starting module: MMM-EARTH
                          Connecting socket for: MMM-voice
                          Starting module helper: MMM-voice
                          Starting module: newsfeed
                          Sockets connected & modules started …
                          Launching application.
                          https://epic.gsfc.nasa.gov/api/natural
                          Create new news fetcher for url: http://ewn.co.za/RSS Feeds/Latest News - Interval: 300000
                          MMM-voice: Checking files.
                          MMM-voice: Starting pocketsphinx.
                          Shutting down server…
                          Stopping module helper: updatenotification
                          Stopping module helper: MMM-EARTH
                          Stopping module helper: MMM-voice
                          Stopping module helper: newsfeed
                            cyberphox
                            is the dev window…check the console tab…look for errors
                              @cyberphox hi… I am so hard trying not to be an ass… but I dont know what you mean? Sorry…I am serously a 5 day taught myself to help my son with his project.
                              Mykle1M 1 Reply Last reply
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @shazglass
                                @shazglass said in MMM-voice setup but MagicMirror wont display:
                                No worries dude. Personally, I’m glad to see you involved with your son. That’s how this started for me. I wanted to have something in common with my 21 year old son so I could stay “cool” in his eyes. Now . . .
                                I don’t use voice on my Pi mirror anymore but I do use it extensively on other boards. This is what I remember.
                                • I didn’t use a 3rd party sound card
                                • USB microphone plugged directly into USB port of the Pi
                                • Needing to run alsamixer in a terminal window to set mic/capture device.
                                • Testing mic by recording your voice (forgot command - google it)
                                After that, installing MMM-voice, paying careful attention to the directions on how to install the dependencies. If at this point the module runs but displays a microphone and the word “ERROR” then I can help you. If, on the other hand, the module does not run and errors in the terminal or the dev console then something in your beginning steps is amiss
                                Reply Quote 2
                                  shazglass @Mykle1
                                  @Mykle1 Good morning.
                                  thank you for the reply, makes a lot of sense. I don’t know how to run alsamixer? which directory would I do that in. I have tested the mic and it def works. I am at the point where it displays a microphone with ERROR showing. Sometimes it says , INITIALISING, CHOOSE MODE, then straight away shows ERROR again. Is there something on the pi I need to configure? thnx again Mykle, and I am a mom to a 15 year old :)
                                  strawberry 3.141S Mykle1M 2 Replies Last reply
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @shazglass
                                    @shazglass There is a error log in the module. Also there is a hidden debug option for for informations debug: true
                                      shazglass @strawberry 3.141
                                      @strawberry-3.141 Hi - thank you for your reply. Ok, so how do I fix the error log in the module? and where must i type debug: true? Sorry for being a pain - like I said, I have no idea, I am seriously just helping my son, who also just taught himself by reading all of this information.
                                      • strawberry 3.141S
                                        @shazglass
                                          module: 'MMM-voice',
                                          position: 'bottom_bar',
                                            microphone: 1,
                                            debug: true
                                        post your error and debug log, it’s huge so maybe on pastebin
                                          @strawberry-3.141
                                          /* Magic Mirror Config Sample
                                           * MIT Licensed.
                                          var config = {
                                          	port: 8080,
                                          	language: "en",
                                          	timeFormat: 24,
                                          	units: "metric",
                                          			module: "alert",
                                          			module: "updatenotification",
                                          			position: "top_bar"
                                          			module: "clock",
                                          			position: "top_left"
                                          			module: "mmm-systemtemperature",
                                          			position: "top_center",
                                          			classes: 'small dimmed',
                                              			module: "MMM-Lunartic",
                                          					image: "animation",
                                          					distance: "km",
                                          					useHeader: true,
                                          					header: "The Moon",
                                          					maxWidth: "300px",
                                          					animationSpeed: 3000,
                                          			module: "compliments",
                                          			position: "lower_third",
                                          				compliments: {
                                          					anytime: [
                                          						"Hey there Tyler!"
                                          					morning: [
                                          						"Good morning, Tyler!",
                                          						"Enjoy your day!",
                                          						"How was your sleep Tyler?"
                                          					afternoon: [
                                          						"Hello, Tyler!",
                                          						"How was school Tyler?",
                                          						"Looking good today!"
                                          					evening: [
                                          						"Have a great evening!",
                                          						"You look nice!",
                                          						"Sleep well Tyler!"
                                          			module: "currentweather",
                                          				locationID: "3362024",  //ID from http://www.openweathermap.org/help/city_list.txt
                                          				appid: "9cb2b560a465957274fa56860a202af5"
                                          			module: "weatherforecast",
                                          			header: "Weather Forecast",
                                          				appid: "c65138e0beb14c63bdf5f804f8816f74"
                                          			module: "MMM-CountDown",
                                          			position: "bottom_right",
                                          				event: "End of Term 2",
                                          				date: "2018-06-22",
                                          			module: "MMM-voice",
                                          			position: "bottom_bar",
                                          				microphone: 1,
                                          			debug: true
                                          			module: "MMM-QRCode",
                                          			position: "bottom_left",
                                          				text: " Scan to join Home Wifi",
                                          				colorDark  : "#fff",
                                          				colorLight : "#000",
                                                  			imageSize  : 60,
                                                  			showRaw    : false,
                                          			module: "newsfeed",
                                          				feeds: [
                                          						title: "EWN News",
                                          						url: "http://ewn.co.za/RSS%20Feeds/Latest%20News"
                                          				showSourceTitle: true,
                                          				showPublishDate: true
                                          This is my config/config.js I have no clue whats wrong, but things arent even in the same place as before? The QRCode is higher, the Countdown is higher, the Moon thing is squashed. I think I am killing my sons project. The MM shows the mic display but says ERROR then UNDEFINED.
                                          • Mykle1M
                                            That is fantastic, and you are most welcome. I will leave you in the hands of @strawberry 3.141. He is the author of MMM-voice and best qualified to help you. If there is anything else that I can help you with, just ask, or PM me.
                                            A chilly, sunny NYC morning to you. :-)
                                            S 2 Replies Last reply
