    Magic Mirror 2 - Please create a config file error
    8 Posts 3 Posters 7.6k Views 3 Watching
      Rpickp
      @cyberphox said in Magic Mirror 2 - Please create a config file error:
      config.js
      I used the installer script i think it was already renamed. Should I make any changes in the config file?
        Rpickp @Mykle1
        @Mykle1
        Great! I will go back and give this a try.
          Mykle1 Project Sponsor Module Developer @Rpickp
          @Rpickp said in Magic Mirror 2 - Please create a config file error:
          What you should get from the installation of MM is a file called config.js.sample. If you no longer have this file then it is likely that you renamed it instead of copying it and renaming the copy. Once you obtain a new, clean config.js.sample you can follow the directions in the link I gave you.
          Yes, you can make any changes you like to the config.js file once you’ve followed the directions above
            Rpickp @Mykle1
            @Mykle1
            It worked! Thank you so much!
              Excellent! :-)
