    MMM-MyCommute
    286 Posts 80 Posters 720.4k Views 77 Watching
      j.e.f.f Project Sponsor Module Developer @cruunnerr
      @cruunnerr make sure you’ve got your API key set correctly. Without it you’ll only get limited functionality. Make sure to set property name as apikey. Some people have tried to use api_key or apiKey, neither of which will work.
      • cruunnerrC Offline
        cruunnerr
        its correct.
        intentionally i typed in a wrong apikey, what effects an error message when module loads up.
        its this format and its correct:
        apikey: 'ABCDabcd1234abcd5679',
        edit:
        i used the “standard api key” from google. there was also a “premium api key”, but this one i don’t need, right?
        to make sure that I express myself correctly… i want it to looks like this:
        alt text
          @cruunnerr standard API key is fine.
          I’m currently in the process of moving my family overseas, so I don’t have a lot of time to help troubleshoot this at the moment. Send me a private message with your complete config and i’ll try and troubleshoot it on my side when I get a few minutes.
          Might be a few days, please be patient :)
            cruunnerr
            For sure this is no problem. Take as much time as u need for your family. thats much more important!
            didn’t find a private message option, just a chat^^ sorry for that. I post my config right here.
            just for info: I didn’t touch the MMM-MyCommute.js, so its just this one i need: https://github.com/jclarke0000/MMM-MyCommute/blob/master/MMM-MyCommute.js
            So here is my full config:
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
            	address: "0.0.0.0", // Address to listen on, can be:
            	port: 8080,
            	ipWhitelist: ["192.0.0.0/3", "::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses
            	language: "de",
            	timeFormat: 24,
            	units: "metric",
            			module: "alert",
                    		module: 'MMM-Remote-Control'
                    		// , position: 'bottom_left'
            		module: 'MMM-SystemStats',
            		position: 'top_center', // This can be any of the regions.
            		classes: 'small dimmed', // Add your own styling. Optional.
            			updateInterval: 5000,
            			animationSpeed: 0,
            			align: 'right', // align labels
            			//header: 'System Stats', // This is optional
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
            			module: 'calendar',
            			header: 'Chris Kalender',
            			position: 'top_left',
            						symbol: 'calendar-check-o ',
            						url: '*private*'
                                                            url: 'http://i.cal.to/ical/61/nrw/feiertage/71e91ccb.83fad41c-d19fda68.ics'
            			module: 'MMM-MyCommute',
            			header: 'Verkehrslage',
            			classes: 'default everyone',
            			showSummary: 'true',
            				apikey: '*private*',
                				origin: '*private*',
            				destinations: [
                    				destination: '*private*',
                    				label: 'Arbeit',
                    				mode: 'driving',
            					alternatives: 'true',
            					time: null
                    				label: '*private*',
                    				mode: 'driving',
                    				time: null
            //			module: "compliments",
            //			position: "lower_third"
            //			module: "currentweather",
            //			position: "top_right",
            //			config: {
            //				location: "New York",
            //				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
            //				appid: "YOUR_OPENWEATHER_API_KEY"
            //			module: "weatherforecast",
            //			header: "Weather Forecast",
            //			config: {
            //				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
            			disabled: false,
            			module: 'MMM-NOAA',
            			position: 'top_right',
            				apiKey: "*private*",    // https://www.wunderground.com/weather/api  select the middle plan...
            				useAir: false,             // set to false if you do not want to use Air Quality Index
            				airKey: "*private*",    // IF you want Air Quality Index
            				pws: "*private*",         // go here to find your pws: https://www.wunderground.com/wundermap
            				showClock: false,           // Hides or shows clock
            				dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
            				format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
            				ampm: false,                // to show AM and PM on Sunrise/Sunset time
            				showGreet: false,          // deafult is false - to show greeting under clock and above date
            				name: "",                  // Your name
            				showWind: false,
            				showDate: false,
            				showForecast: true,         //show bottom 3 day forecast
            				flash: true,                 //Today in forecast flashes halo
            				showUV: true,               //show UV index
            	      			showBar: true,             // show Barometer
            	    			showHum: true,              //show Humidity level
            				position: 'top_right',       //whatever you have in above position must also be here
            	      			alert: true                //show weather alerts default is true
            			module: 'MMM-Globe',
            					style: 'natColor',
            					imageSize: 200,
            					ownImagePath:'',
            					updateInterval: 10*60*1000
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "Tagesschau Themen",
            						url: "http://www.tagesschau.de/xml/rss2"
            				showSourceTitle: true,
            				showPublishDate: true,
            				showDescription: true,
            				updateInterval: 25000,
            Thank u very much for helping :)
              @cruunnerr sorry yes. Chat was what I meant. Send me your entire MMM-MyCommute config without hiding anything so I can test your exact config.
                cruunnerr
                ok. i send it to you, but the code looks scary with the chat.
                i uploaded it to my ftp-server and send you the link
                thanks for helping me
                edit:
                Got it!
                you have too write it like this:
                alternatives: true, //does work
                not like this:
                alternatives: 'true', //doesn't work
                Thank you anyway :)
                  raggedyandy
                  Has anyone else had trouble getting the icons to display? I’m not sure if the SVG file I’m using has been corrupted, but I also seem to get an error message whenever I try opening that file separately, even after pulling the latest from the git. Below is how it renders for me.
                  Great module btw!
                    ATibbs
                    I Just recently installed and configured MMM-MyCalendar and MMM-MyCommute with few issues and love the modules. I noticed in the config for the calendar (and also in the console logs) that the calendar is broadcasting an array with data such as location, geo, etc.
                    I was hoping someone with a little more JS experience (I have PS and VB scripting experience but this is my first dive into development) might help me out a little. I have been trying to use the receiveNotification: Function to pull the location and title values from the calendar and use them to update the destination and label fields from MyCommute respectively. Essentially I want the driving duration displayed in MyCommute to give me driving times to my next calendar appointment. I have been searching and throwing code at this module for 3 days now and am ready to start smashing things.
                    Help me MagicMirror forums…you’re my only hope.
                    pyrosmileyP 1 Reply Last reply Reply Quote 1
                    • pyrosmileyP Offline
                      pyrosmiley @ATibbs
                      @ATibbs This is not my work (I’m not that smart) but I did find a fork of this module that adds what I think you’re looking for – it’s behind the master still, but it works pretty well by and large. Check out the calendar-integration branch of this repository (courtesy of olexs on github).
                      You may need some additional configuration settings to make it work. I don’t currently have access to mine, but iirc I guessed at the changes based on this changelog from the pull request on the master repo.
                      In a few days I’ll be back home, feel free to shoot me a message if you can’t get it up and running an I’ll send you my config once I can get to it.
                      A 2 Replies Last reply Reply Quote 1
                        ATibbs @pyrosmiley
                        @pyrosmiley Oh man, thank you so much for this. I was on the right track too but this would have taken me a month to figure out. Now I just need to sit here at work for the next 8 hours waiting to try this out. Thanks again for this, Ill update here if I get it working.
                          ATibbs @pyrosmiley
                          @pyrosmiley So I copy/Pasta’d the .js file from the calendar-integration branch and it worked like a charm without any configuration other than changing the showcalendarevents value from false. Thanks again, this is huge for me.
                          • O Offline
                            olexs @ATibbs
                            @ATibbs I’m the author of the calendar-integration fork. It’s quite old but works stable enough for myself. OP has a very valid issue with it, in that it uses up a lot of API calls if you have many events refreshing often - so be careful to limit the showcalendarevents to a low value. I have it running with 3 events shown and haven’t had an API limit issue in many months of use.
                            I’ll take a look at upstream changes and update/rebase the fork to the current master, to keep it up to date and compatible.
                            A pyrosmileyP 2 Replies Last reply Reply Quote 4
                              ATibbs @olexs
                              @olexs Thanks for putting the work in, you did a great job. I too have showcalendarevents set to 3 and everything seems to be running fine. Thanks again.
                                pyrosmiley @olexs
                                @olexs Thanks a lot for that fork – it’s exactly what I needed for the mirror!
                                  aishaamila @j.e.f.f
                                  @j.e.f.f does this modules in Malaysia? Because i keep on getting syntax error so the config cannot be validated
                                    j.e.f.f Project Sponsor Module Developer @aishaamila
                                    @aishaamila I don’t see why it wouldn’t. Does google maps work for you just in your browser?
                                    If you can’t figure it out PM me and I’ll help you troubleshoot.
                                      AlexNY007
                                      Not sure everybody is aware of this but today when i was trying to deploy the module and then getting the APi i found out that Google now is requesting a billing account. Even has a $200 limit for use per month. Do you guys know if this is per project or per account? If so anybody recently created an account for this module? any hints will be appreciated.
                                      AlbinolanA 1 Reply Last reply Reply Quote 0
                                      • O Offline
                                        olexs
                                        Annoyingly enough, this is correct. Google is changing their Maps API access, and billing now needs to be set up for all uses of the API - including free tier. The 200$ limit is their free allowance, as long as you stay under that you don’t pay anything at all. Using only MMM-MyCommute should not even come close to that. But you still have to provide billing information, even if it’s never going to be used.
                                        I have updated my account and project that I use for MMM-MyCommute, and it works just fine.
                                          AlexNY007 @olexs
                                          @olexs yes. I read their last FAQ and basically its is what you said. Sorry if this sound stupid but, when you said MM-Commute should not come close to the allowance limit, do you mean that even if i have one project for em and my wife should not cost me a billing headache? I mean if i do something like this.
                                          • O Offline
                                            olexs @AlexNY007
                                            @alexny007 Unless you have many (dozens) instances of the module running on the same account, it will stay far below the 200$ free tier limit, and it won’t cost you anything.
                                            A 1 Reply Last reply Reply Quote 1
                                            • 10
                                            • 14
                                            • 15
                                            • 8 / 15
