    Basic Setup Question
    5 Posts 3 Posters 3.0k Views 3 Watching
      Merijeek
      Alright, so this may seem beyond simple, but I have to ask…
      I’ve run through the install on a Pi2. The install gave me no problems. I go through the final reboot and…I’m looking at the Raspbian GUI.
      Can anyone suggest the (clearly extremely obvious) step that I must have missed?
      • Y
        yawns Moderator
        You mean, you miss the autostart feature?
        Did you follow the instructions mentioned in the read.me?
        Configuration: https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi
        Autostart: https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
        M 1 Reply Last reply
          Merijeek @yawns
          No, I was actually using this setup guide here, which is less complete, but sure shows up in searches more often: https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
          Now, however, I’ve gone through the setup you linked and and have ended up with:
          Check current Node installation …
          Minimum Node version: v5.1.0
          Installed Node version: v6.4.0
          No Node.js upgrade nessecery.
          It seems like MagicMirror is already installed.
          To prevent overwriting, the installer will be aborted.
          Please rename the ~/MagicMirror folder and try again.
          If you want to upgrade your installation run git pull from the ~/MagicMirror directory.
          pi@pi:~ $ cd ~/MagicMirror
          pi@pi:~/MagicMirror $ git pull
          Already up-to-date.
          pi@pi:~/MagicMirror $ cd $HOME/MagicMirror
          pi@pi:~/MagicMirror $ npm start
          magicmirror@2.0.0 start /home/pi/MagicMirror
          electron js/electron.js
          npm ERR! Linux 4.4.18-v7+
          npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
          npm ERR! node v6.4.0
          npm ERR! npm v3.10.3
          npm ERR! code ELIFECYCLE
          npm ERR! magicmirror@2.0.0 start: electron js/electron.js
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
          npm ERR! If you do, this is most likely a problem with the magicmirror package,
          npm ERR! not with npm itself.
          npm ERR! electron js/electron.js
          npm ERR! npm bugs magicmirror
          npm ERR! Or if that isn’t available, you can get their info via:
          npm ERR! npm owner ls magicmirror
          npm ERR! /home/pi/MagicMirror/npm-debug.log
            Merijeek @Merijeek
            @Merijeek
            Actually, reran yet again and (possibly) looking better.
            Once my card reader stops acting oddly I’ll probably do a reinstall and start again from scratch. Maybe figure out where I went wrong.
            • G
              gshimself
