    [MMM-TweetsByTimelineOrList] - A module for the Magic Mirror to display tweets from a user's timeline or list.
    twittertweetstimelinemodulemagic mirror
    16 Posts 6 Posters 9.6k Views 7 Watching
    • yawnsY Offline
      yawns Moderator
      There is a }, missing at the end, I guess your config.js is now “broken”
        Dicous @yawns
        @yawns
        sorry bad copy. i have this
        				module: 'MMM-TweetsByTimelineOrList',
        				position: 'top_right',
        					consumer_key: 'xxx',
        					consumer_secret: 'xxx',
        					access_token_key: 'xxx',
        					access_token_secret: 'xxx',
        					screenName: 'S-Bahn Berlin',
        					listToShow: 'TIMELINE',
        AdamMoses-GitHubA 1 Reply Last reply Reply Quote 0
        • AdamMoses-GitHubA Offline
          AdamMoses-GitHub Module Developer @Dicous
          @Dicous
          And you’re sure it’s working if you remove this module from the config?
          Also, the screenName field looks wrong, there should be no dashes or spaces. The screenName is not the same as the “display name”. Put in there whatever comes as part of the twitter.com/XXXXXX part of the URL.
            Dicous
            ok, please help a big noob =(
            i want this tweets https://twitter.com/SBahnBerlin
            the keys and so on are correct.
            where are my mistakes?
            					screenName: 'SBahnBerlin',
            					listToShow: 'screename',
              @Dicous
              You’re close, just change the listToShow field to “TIMELINE” and it should work.
                Dicous
                Thank you very much my Hero!
                  Dicous
                  Oh man
                  sometimes I see tweets
                  sometimes not
                  https://twitter.com/SBahnBerlin tweets pretty much but I see maximum 1
                  I despair = (
                    @Dicous
                    Try adding these config options:
                    excludeTweetsWithQuotes: false,
                    excludeMediaTweets: false,
                    excludeLinkTweets: false,
                    maxTweetsPerUser: 0,
                    maxTweetAgeMins: 7000,
                      celliott
                      How can I install this module?
                        sdetweil @celliott
                        @celliott same way u install any module
                        read the links in my signature below
