    [MMM-RadioDe] - Simple Web Radio.de player
    22 Posts 8 Posters 22.2k Views 8 Watching
      Disturbx @Steff
        Disturbx
        Hey @Steff, any updates on the module and how its not working with mine?
          Steff @Disturbx
          @Disturbx Wanted to post a reply already yesterday, but was too stupid to use git push…, I modified the behavior slightly, letting the module wait until the others are started, added as well some changes. I put them to the develop branch, so if you change your git to develop, you can try whether this helps.
          How to do:
          Enter local directory of module --> git checkout develop --> git pull
          Why develop branch ? I did only test on my development platform, but not on the Raspi itself.
          Feedback highly welcome
            Disturbx @Steff
            @Steff said in [MMM-RadioDe] - Simple Web Radio.de player:
            How to do:
            Cant seem to get it working mate :(
            • FistandantilusF Offline
              Fistandantilus
              Hi Steff,
              I have just tested your module which is working quite good so far. The are two things I would like to address:
              • I´m running it with station “ffhlounge” and sometimes there are short dropouts while playing the stream (CPU is between 2 and 4% and free memory at 44%), maybe you can test if it happens on your side as well, I have a dedicated radio where I can run the stream without dropouts
              • while running the mirror in dev mode to debug a problem with another module I found some 403 errors for the RadioDe module. Can you also have a look at them? Attached there is a screenshot.
              best regards,
              F.
                Fistandantilus
                Just integrated another player (https://www.muses.org/setup) using iFrame which is working without dropouts. Maybe a problem with radio.de?
                  Preve
                  Is it possible to make a kind of “Radio Stations” list to select from. Or do we just add the module a couple of times with on each line another radio station?
                    Rolandb
                    Hello everybody.
                    How do I manage the antenne Bayern is played.
                    I have opened the Station once in the browser and when I start the MagicMirror then comes again antenna Niedersachsen.
                    • tbbearT Offline
                      tbbear Module Developer
                      Maybe have a look at MMM-MyRadio ;-)
                      Robert the Bear
                        Sputnik
                          Sputnik @Sputnik
                          @Sputnik I suspected, that maybe my Wifi connection is not good enough but the speedtest shows 11-14Mbt download speed and about 4 Mbt upload speed which I believe should be sufficient.
                            Sputnik @Sputnik
                              Sputnik
                              My present situation is a follows: I get the radio station to play but I got many many drop-outs.
                              I tried iFrame as an alternative platform to play radio and I have the same problem. Changing the radio station or link doesnt help either.
                              I dont think its an issue with the module but probably more with the Pi resourcs. My internet connection clocks at >10 Mbyte download and>4upload speed hence I dont think thats the issue.
                              Now how to find out the actually cause ?
                              Could I try to use a lower quality (bitrate) radio stream instead or allocate more hardware resources ???
                              Please help !
                              • T Offline
                                tgl
                                Hello :-)
                                I´ve a Question.
                                Is it possible to controle this modules with “voicecontrole” from alexyak?
                                I would like to say “Radio on” or “Radio off” to play a Radiostation or pause a Radiostation.
                                I hope it´s possible :-)
                                and sorry for my bad English :-/
                                Have a nice Day anf thanks for answers! :-)
                                  Sputnik
                                  I am still trying to fix the drop outs on the radio stream. I now suspect that it has nothing to do with the wifi connection but somehow with the resources of the PI. I have Alexa & WakeWord running in the background as well as Magic Mirror and Node Red. I switch alexa and wakword off by closing the terminal screens but the server probably still runs so i cant realy rule it out. Anyway to provide radio with more resources or to finalse the cause ?
                                  I also noticed, that after a few seconds of running radio, the VCN connection and even terminal connection disconnects.
