    [MMM-RadioDe] - Simple Web Radio.de player
    22 Posts 8 Posters 22.6k Views 8 Watching
      Steff @Disturbx
      @Disturbx Wanted to post a reply already yesterday, but was too stupid to use git push…, I modified the behavior slightly, letting the module wait until the others are started, added as well some changes. I put them to the develop branch, so if you change your git to develop, you can try whether this helps.
      How to do:
      Enter local directory of module --> git checkout develop --> git pull
      Why develop branch ? I did only test on my development platform, but not on the Raspi itself.
      Feedback highly welcome
        Disturbx @Steff
        @Steff said in [MMM-RadioDe] - Simple Web Radio.de player:
        How to do:
        Cant seem to get it working mate :(
        • FistandantilusF
          Fistandantilus
          Hi Steff,
          I have just tested your module which is working quite good so far. The are two things I would like to address:
          • I´m running it with station “ffhlounge” and sometimes there are short dropouts while playing the stream (CPU is between 2 and 4% and free memory at 44%), maybe you can test if it happens on your side as well, I have a dedicated radio where I can run the stream without dropouts
          • while running the mirror in dev mode to debug a problem with another module I found some 403 errors for the RadioDe module. Can you also have a look at them? Attached there is a screenshot.
          best regards,
          F.
          • FistandantilusF
            Fistandantilus
            Just integrated another player (https://www.muses.org/setup) using iFrame which is working without dropouts. Maybe a problem with radio.de?
              Preve
              Is it possible to make a kind of “Radio Stations” list to select from. Or do we just add the module a couple of times with on each line another radio station?
                Rolandb
                Hello everybody.
                How do I manage the antenne Bayern is played.
                I have opened the Station once in the browser and when I start the MagicMirror then comes again antenna Niedersachsen.
                • tbbearT
                  tbbear Module Developer
                  Maybe have a look at MMM-MyRadio ;-)
                  Robert the Bear
                    Sputnik
                      Sputnik @Sputnik
                      @Sputnik I suspected, that maybe my Wifi connection is not good enough but the speedtest shows 11-14Mbt download speed and about 4 Mbt upload speed which I believe should be sufficient.
                        Sputnik @Sputnik
                          Sputnik
                          My present situation is a follows: I get the radio station to play but I got many many drop-outs.
                          I tried iFrame as an alternative platform to play radio and I have the same problem. Changing the radio station or link doesnt help either.
                          I dont think its an issue with the module but probably more with the Pi resourcs. My internet connection clocks at >10 Mbyte download and>4upload speed hence I dont think thats the issue.
                          Now how to find out the actually cause ?
                          Could I try to use a lower quality (bitrate) radio stream instead or allocate more hardware resources ???
                          Please help !
                          • T
                            tgl
                            Hello :-)
                            I´ve a Question.
                            Is it possible to controle this modules with “voicecontrole” from alexyak?
                            I would like to say “Radio on” or “Radio off” to play a Radiostation or pause a Radiostation.
                            I hope it´s possible :-)
                            and sorry for my bad English :-/
                            Have a nice Day anf thanks for answers! :-)
                              Sputnik
                              I am still trying to fix the drop outs on the radio stream. I now suspect that it has nothing to do with the wifi connection but somehow with the resources of the PI. I have Alexa & WakeWord running in the background as well as Magic Mirror and Node Red. I switch alexa and wakword off by closing the terminal screens but the server probably still runs so i cant realy rule it out. Anyway to provide radio with more resources or to finalse the cause ?
                              I also noticed, that after a few seconds of running radio, the VCN connection and even terminal connection disconnects.
