    MMM-PublicTransportHafas – Public transport information for all stations known to Deutsche Bahn
    transportdeutsche bahn
    42 Posts 13 Posters 42.3k Views 13 Watching
      djsunrise19 @jimjay203
      @jimjay203 Yesterday morning some trains were cancelled in the near of frankfurt / main. Nothing on my mirror, nothing in the DB app (+0). But the RMV app was up do date.
      E 1 Reply Last reply
      • E
        E3V3A @djsunrise19
        @djsunrise19 Is that on Android? We can reverse the app… or use a VPN based sniffer, such as NetGuard to find the exact URL’s its using.
        “Everything I do (here) is for free – altruism is the way!”
        D 1 Reply Last reply
          djsunrise19 @E3V3A
          @E3V3A No, iOS.
            raywo Module Developer @raywo
            For all those of you who like this module, it would be nothing without the data from the hafas-client. Please consider supporting the author on his Patreon page.
            • E
              E3V3A @raywo
              @raywo Hi goal and standards are noble, but I think trying to get some money via Patreon is a dead end. People hate to sign up for (new) stuff to send some pocket cash here and there. He would probably benefit more from getting a crypto currency account. Or some other big payment chain. That said, those bloody public transportation agencies should donate him some living funds!
              • G
                gekberlin
                hi @raywo,
                it looks like there are no realtime datas avaible for (just) tramstops in Berlin ? Is a general fault or it’s just my one ?
                Example StationID : 000732980 , the module shows constanly + 0 min and öffi /bvg says +xx mins
                I Would appreciate any help and /or suggestions
                Best greetings
                R 1 Reply Last reply
                  raywo Module Developer @gekberlin
                  @gekberlin It is possible that no real-time data are shown in my module. But as far as I remember there is a module MMM-PublicTransportBerlin which should give you better information.
                  If you don’t mind doing a bit of hacking you can alter my source code. Go to line 5 in HafasFetcher.js And change the part after the equal sign to require('hafas-client/p/vbb'). That way you are using the VBB specific queries which may or may not include real-time data.
                    phunky2018
                    Thank you for this great module.
                    At my train station, beside DB rails services we also have some competitors.
                    e.g. (ag or OPB)
                    Is it possible to get a similar look for this competitors?
                    e.g. I want to give every competitors his own color. Is this possible in custom css file or styles.css?
                    My test so far are not successful.
                    Thany you in advance.
                      dvbit
                      Hello
                      Thanks for the wonderful module.
                      Thanks to Hafas international coverage this should work also over here (Italy)
                      Unfortunately I have not managed to make it work.
                      this even with the example config provided.
                      no complaint but nothing shows up.
                      did something broke in the backend? Just saw an issue in the github…
                      Does anybody else have the same behaviour?
                        dvbit @dvbit
                        forget the post above. everything works perfectly…stupid typo
                        • O
                          onkelbobby
                          Hi…
                          since a few weeks I’m facing a problem that the current bus departures for one specific bus stop in Munich is not working. I’m running the MMM_PublicransportHafas Module 3 times on my mirror and two instances are running perfectly fine - one showing suburban trains “Mittersendling” , and another one for bus station “Heckenstallerstrasse”. But the third instance that is meant to show the bus departures from station “Adunistrasse” only feeds back something like “no reachable departures”.
                          I crosschecked it with DB website and here the next departures are shown.
                          the code used for “Heckenstallerstrasse” and for “Adunistrasse” is absolutely identical except the station numbers.
                          // MMM-PublicTransportHafas Heckenstallerstr
                          		module: "MMM-PublicTransportHafas",
                          		position: "bottom_right",
                          			stationID: "000790109",          		// eigene stationID eintragen: Heckenstallerstr
                          			stationName: "Heckenstallerstrasse",   	// Replace with your station name!
                          			headerAppendix: "Richtung Harras", 		// wohin es gehen soll - wird nach dem station Name angezeigt
                          			direction: "008004130",    				// Show only departures heading to this station. (A station ID.) Harras
                          			ignoredLines: [],                 		// Which lines should be ignored? (comma-separated list of line names)
                          			excludedTransportationTypes: [],  		// Which transportation types should not be shown on the mirror? (comma-separated list of types) possible values: StN for tram, BuN for bus, s for suburban
                          			timeToStation: 0,                		// How long do you need to walk to the next Station?
                          			showTableHeaders: false,				// ob die Überschriften angezeigt werden sollen
                          			showColoredLineSymbols: true,     		// Want colored line symbols?
                          			useColorForRealtimeInfo: true,    		// Want colored real time information (timeToStation, early)?
                          			showTableHeadersAsSymbols: false,  		// Table Headers as symbols or text?
                          			maxUnreachableDepartures: 0,      		// How many unreachable departures should be shown?
                          			maxReachableDepartures: 5,        		// How many reachable departures should be shown?
                          			customLineStyles: "mvg",             	// Prefix for the name of the custom css file. ex: Leipzig-lines.css (case sensitive)
                          			showOnlyLineNumbers: true,       		// Display only the line number instead of the complete name, i. e. "11" instead of "STR 11"
                          			replaceInDirections: {					// Ersetzt gewisse Anzeigen in den Destinations z.B. München durch nix
                          				"München": "", "\\,": "",
                          		// MMM-PublicTransportHafas Adunistr
                          			stationID: "000790090",          		// eigene stationID eintragen: Heckenstallerstr
                          			stationName: "Adunistrasse",		   	// Replace with your station name!
                          			direction: "000624609",    				// Show only departures heading to this station. (A station ID.) Harras
                          			excludedTransportationTypes: ["suburban", "regional"],  		// Which transportation types should not be shown on the mirror? (comma-separated list of types) possible values: StN for tram, BuN for bus, s for suburban
                          What am I doing wrong?!
                          • O
                            onkelbobby
                            Strange and confusing news:
                            yesterday (Sunday June 24th) the Module worked perfectly. It also showed all departures from “Adunistrasse”. This morning unfortunately the old behavior was back again: no reachable departures as described above.
                            Any Ideas?
                            • O
                              onkelbobby
                              Now, one week later I can confirm that the module is working perfectly on sundays only…
                              The busses from this station are definitely running all week long.
                              Any idea what can be the reason for this?
                              • rudibaraniR
                                rudibarani Project Sponsor @raywo
                                • O
                                  onkelbobby
                                  …finally the module is working like a charm since more than 4 weeks. I think this was an issue with the data provided.
                                  • O
                                    onkelbobby
                                    One more css question popped up while I reconfigured the appearance of the module
                                    There is a train called Meridian stopping at our station. If I do not add any css style for this train it appears as the 5 digit train-number only that changes depending on the time of day.
                                    I want the module to show only the name “Meridian” for all of the trains. So is there a possibility to rename all train numbers to “Meridian” only without showing the train number?
                                    Below please find the css code I’m currently using:
                                    /* Meridian */
                                    .m79600:before {
                                      content: "Meridian";
                                    .m79500:before {
                                    // ... and so on for every train number
                                    thank you for yuour help…
                                    • O
                                      onkelbobby
                                      no ideas?
                                      • 2 / 3
