    Ip whitelist
    4 Posts 2 Posters 3.5k Views 2 Watching
    • HrierebH
      Hriereb
      Re: ipWhitelist HowTo
      Hi all,
      I apologize if I make silly questions but I’m completely new in this fantastic world.
      I installed my magic mirror and I’m tried to customize it following my tastes. I installed the MMremote module but I cannot set the right ip in the whitelist. I tried several times to access, through a tablet and a laptop, but every time I get the refused access error.
      My Pi ip address is 192.168.188.52
      my laptop ipv4 is 192.168.188.32
      my tablet ip is 192.168.188.28
      I tired to edit this ips to the whitelist but nothing happens.
      Can someone help me?
      Since I made some mistake I resumed the default configuration.
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	address: "0.0.0.0", // Address to listen on, can be:
      	port: 8080,
      	language: "it",
      	timeFormat: 24,
      	units: "metric",
                              module: "alert",
                              module: 'MMM-Remote-Control',
                              // uncomment the following line to show the URL of the remote control on the mirror,
                              position: 'bottom_right',
      			header: "MyTab",
      			position: "bottom_left",
      						symbol: "angellist",
      						url: "https://calendar.google.com/calendar/ical/XXX.com/private-bfa9ee5d1713d4d59c9c662e4b0aa959/basic.ics"
                              module: 'persistent_config_interface'
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Hriereb
        @hriereb said in Ip whitelist:
        ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”],
        I just whitelist all of the devices on my network by changing to this at the beginning of my config.
        ipWhitelist: [],
        • HrierebH
          Hriereb
          Thank you so much, your advise was really precious.
          • Mykle1M
            @hriereb
            You’re welcome, mate. :-)
