    current weather feels 185F!!!
    7 Posts 4 Posters 2.5k Views 4 Watching
    • T Offline
      tv25666
      i just installed magic mirror on the rpi2. loooks great except not sure why current weather shows 185F
      just to check, i went outside and it’re about 90F, not 185F!
      alt text
      any idea what went wrong? and how do i have current weather section colorized?
      thanks!
        maxbachmann
        The Temperature says 81.2 F which is pretty good I guess ;)
        The other one 185F is the feels like temperature. It’s calculated from the normal temperature and the windspeed.
        var windchillinF = Math.round(35.74+0.6215*tempInF-35.75*Math.pow(windInMph,0.16)+0.4275*tempInF*Math.pow(windInMph,0.16));
        			var windChillInC = (windchillinF - 32) * (5/9);
        			// this.feelsLike = windChillInC.toFixed(0);
        			switch (this.config.units){
        			case "metric": this.feelsLike = windChillInC.toFixed(0);
        				break;
        			case "imperial": this.feelsLike = windChillInF.toFixed(0);
        				break;
        			case "default":
        				var tc = windChillInC - 273.15;
        				this.feelsLike = tc.toFixed(0);
        				break;
        doing the calculation manually given the 81.2 degree and 5 Beaufort you should have a feel like of somewhat around 84 degree. You might want to check what the results in between are that you get to find the fault. However if you just want to see the actual temperature you can aswell just deativate this feels-like temperature
        • T Offline
          tv25666 @maxbachmann
          @maxbachmann
          thank you. i dont know why that day was special. now, feels like temp is back to “normal” without me doing anything special. if it goes crazy again, i will delete those code. thanks!
            Mykle1 Project Sponsor Module Developer @tv25666
            @tv25666
            Most likely, the API was faulty. It happens. :-/
              maxbachmann
              @Mykle1 but the feel Temperature gets calculated out of two of the numbers he showed on the screen (windspeed and real temperatur) when I pulled out my calculator to check it it was definetly below 100, so not quite sure what caused the error, but would surprise me if it was the API.
                Mykle1 Project Sponsor Module Developer @maxbachmann
                @maxbachmann
                Ahh, I didn’t realize that the feels like temp was being calculated manually. I thought it was coming directly from the api. My bad.
                  A Former User
