    Module Position
    34 Posts 5 Posters 18.1k Views 4 Watching
      maxbachmann
      @dherl0623 ty Ik I can change it in there, but would have been cool to change during runtime so I can blend the module in at whatever place I currently need it ;) Well can’t change when it’s not possible
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @maxbachmann
        @maxbachmann there is now magicmirror api for it, but you could manipulate the dom and set the module in a different region manually.
          maxbachmann
          @strawberry-3-141
          How can I do that in there (sorry I am a absolute noob with the dom)
            maxbachmann
            I just asked my friend google:
             var d = document.getElementById(wrapper);
             d.style.left = newx_pos;
             d.style.top = newy_pos;
            is that how to do it?
              @maxbachmann no, you would get the module itself, the wrapper has an id with the identifier of the module, then you would get the wrapper of the position and would call appendChild with your module
                maxbachmann
                @strawberry-3-141 Can you help me with how that would look like in software? I am sorry this project is the first time I use javascript at all and absolutely clueless when it’s about the dom
                  @maxbachmann
                  // get the module to move with it's identifier
                  var clock = document.getElementById('module_0_clock');
                  // append it to the region you like
                  document.querySelector('div.region.top.left div.container').appendChild(clock);
                  it will work only if you already have a module in that position, otherwise you need to ovverride the style to display block
                  document.querySelector('div.region.top.left div.container').style.display = 'block';
                  that’s it
                    maxbachmann
                    @strawberry-3-141 So I always have to know wether there is already a element in that region? Is there a way to check all modules and return the ID’s of the elements that are in this position?
                      maxbachmann
                      @strawberry-3-141 and where to add that? is that already the “end code”? I tried in the domupdate function and it did not work, so I guess that was wrong
                        it is safe to always run the code so you don’t need to check if there is a module necessarily.
                        it is not related to the get dom function, you can put it where ever you want except node_helper (because its not executed in the browser)
                        can you post the code of your module or upload it to github, then i can have a look
                        • 1 / 4
