    Module Position
    34 Posts 5 Posters 16.9k Views 4 Watching
      maxbachmann
      can I change the position of a module while MM2 is running?
        dherl0623 @maxbachmann
        @maxbachmann As far as I know, no. You can however update your position in the configuration file, then press CTRL+R to hard refresh the MM browser.
          maxbachmann
          @dherl0623 ty Ik I can change it in there, but would have been cool to change during runtime so I can blend the module in at whatever place I currently need it ;) Well can’t change when it’s not possible
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @maxbachmann
            @maxbachmann there is now magicmirror api for it, but you could manipulate the dom and set the module in a different region manually.
              maxbachmann
              @strawberry-3-141
              How can I do that in there (sorry I am a absolute noob with the dom)
                maxbachmann
                I just asked my friend google:
                 var d = document.getElementById(wrapper);
                 d.style.left = newx_pos;
                 d.style.top = newy_pos;
                is that how to do it?
                  @maxbachmann no, you would get the module itself, the wrapper has an id with the identifier of the module, then you would get the wrapper of the position and would call appendChild with your module
                    maxbachmann
                    @strawberry-3-141 Can you help me with how that would look like in software? I am sorry this project is the first time I use javascript at all and absolutely clueless when it’s about the dom
                      @maxbachmann
                      // get the module to move with it's identifier
                      var clock = document.getElementById('module_0_clock');
                      // append it to the region you like
                      document.querySelector('div.region.top.left div.container').appendChild(clock);
                      it will work only if you already have a module in that position, otherwise you need to ovverride the style to display block
                      document.querySelector('div.region.top.left div.container').style.display = 'block';
                      that’s it
                        maxbachmann
                        @strawberry-3-141 So I always have to know wether there is already a element in that region? Is there a way to check all modules and return the ID’s of the elements that are in this position?
                        • 1 / 4
