    Module Position
    34 Posts 5 Posters 18.3k Views 4 Watching
      maxbachmann
      I just asked my friend google:
       var d = document.getElementById(wrapper);
       d.style.left = newx_pos;
       d.style.top = newy_pos;
      is that how to do it?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @maxbachmann
        @maxbachmann no, you would get the module itself, the wrapper has an id with the identifier of the module, then you would get the wrapper of the position and would call appendChild with your module
          maxbachmann
          @strawberry-3-141 Can you help me with how that would look like in software? I am sorry this project is the first time I use javascript at all and absolutely clueless when it’s about the dom
            @maxbachmann
            // get the module to move with it's identifier
            var clock = document.getElementById('module_0_clock');
            // append it to the region you like
            document.querySelector('div.region.top.left div.container').appendChild(clock);
            it will work only if you already have a module in that position, otherwise you need to ovverride the style to display block
            document.querySelector('div.region.top.left div.container').style.display = 'block';
            that’s it
              maxbachmann
              @strawberry-3-141 So I always have to know wether there is already a element in that region? Is there a way to check all modules and return the ID’s of the elements that are in this position?
                maxbachmann
                @strawberry-3-141 and where to add that? is that already the “end code”? I tried in the domupdate function and it did not work, so I guess that was wrong
                  it is safe to always run the code so you don’t need to check if there is a module necessarily.
                  it is not related to the get dom function, you can put it where ever you want except node_helper (because its not executed in the browser)
                  can you post the code of your module or upload it to github, then i can have a look
                    maxbachmann
                    In general I want to add it to all kind of modules so I can change the position when sending them a socketmessage to do so
                      @maxbachmann i wouldn’t place that code in other modules, you can perform that from your module for every module, this isn’t magicmirror related. its pure dom manipulation.
                        maxbachmann
                        Ah did not know that ;) well yes then it’s definetly in my program. All my program does so far is subscribe to a mqtt broker, load some data and according to this show/hide modules. Now I want to add the possibility to move modules to different positions.
                        Can send the current code later
                        • 1 / 4
