    Motion Detector
    213 Posts 38 Posters 567.5k Views 39 Watching
      alexyak
      Sorry, guys, the problem should be fixed now. Just pull the latest.
        Cato Module Developer @alexyak
        @alexyak Thanks, works now!
          plumcraft
          Works for me too, thanks :)
          Is there a way to wake up faster the screen ? On my RPI it tooks around 30 secondes to turn back on, i might have a configuration issue…
            alexyak @plumcraft
            @plumcraft which RPI you have?
              plumcraft
              The latest, RPI 3.
                alexyak @plumcraft
                @plumcraft strange, I’ve RPI 3 as well and I don’t see this problem … This may be related to which monitor/TV your RPI is connected.
                  I assume too that the behaviour is different between TV’s. On my LG the screen turns blue with a big message of lost signal on HDMI after 10 seconds after the screen turns off. Not so nice - but then again, nobody should be in the room anyway…? ;-)
                  • cowboysdudeC Offline
                    I installed it… it turns off the monitor but won’t turn it back on… suggestions?
                      cowboysdude Module Developer @plumcraft
                      @plumcraft Yeah there doesn’t seem to be an answer for the blank screen issue…
                        alexyak
                        I am sorry to hear about your issues. Trying to think of the best way to troubleshoot that. The module doesn’t do anything fancy. It just executes these in the node_helper to switch on/of the output on HDMI:
                        Switch off:
                        /opt/vc/bin/tvservice -o
                        Switch-on:
                        /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7
                        As a first step, could you please try to execute these commands in the ssh terminal?
                        • T Offline
                          trividar
                          Hi alexyak
                          I try it with the commands an it works, it switch off and on.
                            alexyak
                            Ok, the next step let’s check whether the off state is detected correctly. After you switched off the monitor with the first command try to execute this in the ssh term:
                            /opt/vc/bin/tvservice -s
                            and let me know which output you see.
                            • T Offline
                              trividar
                              output is:
                              state 0x120002 [TV is off]
                              • strawberry 3.141S Offline
                                strawberry 3.141 Project Sponsor Module Developer @trividar
                                @trividar @cowboysdude paviro is also using the same code lines in his pir sensor module and a user had similar issues, maybe his solution also work for you
                                https://forum.magicmirror.builders/topic/208/pir-sensor-put-your-mirror-to-sleep-if-not-used/43
                                https://forum.magicmirror.builders/topic/208/pir-sensor-put-your-mirror-to-sleep-if-not-used/64
                                  Thanks everyone I will look into this later today!
                                  • T Offline
                                    trividar
                                    @strawberry-3-141 unfortunately it didn’t work for me;0( but thanks for your input.
                                      @trividar I thought the commands are working for you, as you pointed out 2 hours ago? I was struggling with this myself for a seperate module, it didn’t work in the terminal i had to login at tty6 or with the solution I posted I got weird colors and a zoom effect on my screen, but in the node_helper it worked at least for me.
                                      • T Offline
                                        trividar
                                        @strawberry-3-141 This two things work for me if i put it in the terminal:
                                        Switch off:
                                        Switch-on:
                                        But not the module. I tried to change node_helper, but if I tried to start pm2 start mm.sh i got just a white screen. Sorry I’m not a coder, I just start to learn.
                                          @trividar can you post your pm2 logs
                                          • T Offline
                                            trividar
                                            I will… I will be in one hour at home and I will post it.
                                            • 10
                                            • 11
                                            • 1 / 11
