adding fans for airflow?
5 Posts 2 Posters 2.0k Views 2 Watching
    MWel1977
    Hi all,
    Today I’ve recieved my Pi 3B+ and right away I’ve installed the MagicMirror software on it!
    And it works!!! Yeah!!!
    So now to set it up…but that’s going to be okay. What I noticed is that the heatsink I’ve put on the Pi’s core is getting “hot/warm”.
    So… my question: would it be usefull to ad a 5v 0.2amp fan in the bottom and top of the frame of the MagicMirror to have an airflow through the frame?
    M 1 Reply Last reply Jun 9, 2018, 2:08 AM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @MWel1977
      @mwel1977
      Yes, or you could place that fan blowing right on the heatsink. That’s what I’ve done. CPU temp is now 30C cooler!
        MWel1977
        @Mykle1 : and did you connect the fan to the wallsocket or to the raspberry pi?
        If it’s to the pi… what pins did you use?
        And how much amp can they handle?
        I’d like to ad 2 fans (1 in the bottom and 1 in the top of the frame) and have them draw power from the raspberry pi.
        I have a 5v 3amp power supply for my pi 3B+.
        M 1 Reply Last reply Jun 10, 2018, 12:57 AM Reply Quote 0
          @mwel1977 said in adding fans for airflow?:
          The Pi
          One 5v pin and one ground pin
          Dunno
          Best to check how much draw 2 fans will have. My single fan has no problems
          M 1 Reply Last reply Jun 12, 2018, 11:20 AM Reply Quote 0
            MWel1977 @Mykle1
            @mykle1
            Okay, Thanks for the answers.
            Will order a few fans from Aliexpress sometime soon. No rush.
            First I want to have the software part ready. :winking_face:
