    MM Shows a plain Black Screen on iOS 9.3.5 device
    29 Posts 12 Posters 15.4k Views 11 Watching
      Pipe-line
      Same problem here… iPad 2 with iOS 9.3.5 and I’m getting a black screen… I tried with Google Chrome, Dolphin Browser but no good luck.
      A work around: Install VNC Server on RPi, and a client on the iPad. Go to fullscreen mode, and voila!
      idoodlerI 1 Reply Last reply
      • idoodlerI
        idoodler Module Developer @Pipe-line
        @pipe-line I think we have an iOs 9 device at work. I will debug it tomorrow night. What modules do you have installed?
          Pipe-line
          @idoodler I started with Current Weather and Weather Forecast and then only with Current Weather, but no lucky.
          Thanks!
          • idoodlerI
            @pipe-line ok. I just gathered the iPad. Its an iPad mini running iOS 9.3.3. I hope I won’t forget it until I get home:)
            • idoodlerI
              Issue has been identified. I am just preparing a pull request. Hold on tight!
              • idoodlerI
                Lol. This issue has already been fixed on the 8th of April 2018 by Chris Pickett. It is available on the develop branch. It eventually will be merged with the masterbranch.
                  Pipe-line
                  @idoodler thanks! I will try develop branch this night :)
                  • T
                    thobach
                    I also identified the issue. It is related to the use of Promises, a feature of ECMAScript 6, which is not supported by iOS 9.3.5. The feature is used in multiple javascript files that are built into the core of MagicMirror2. I believe it can be fixed with a polyfill.
                    • idoodlerI
                      idoodler Module Developer @thobach
                      @thobach I don‘t think its an issue with the promise itself, but rather with the arrow (=>) operator that defines the callback.
                      T 1 Reply Last reply
                      • T
                        thobach @idoodler
                        @idoodler True! It was fixed in https://github.com/MichMich/MagicMirror/commit/6bb4db38428af7ac46a6f4240ab9cfe4bf9fcbea and I can load now the default configuration on iOS 9.3.5 again.
                        But I can still find one use of “=>” in the develop branch: https://github.com/MichMich/MagicMirror/blob/fb0cc61e09542533affa92b1e8bd6f9a2aca6363/js/module.js#L84.
                        • idoodlerI
                          @thobach that link you posted points me to a specific commit. I can not find any use of the => operator in the browser part In remote/develop
                            shiroe @idoodler
                            @idoodler so just to clarify, this has been found and due to be fixed?
                            or did i totally misread that…
                            if so can’t wait for new release!
                            EDIT: pardon my manners, thank you for checking this out as well :)
                            • idoodlerI
                              idoodler Module Developer @shiroe
                              @shiroe This issue has already been fixed on the active development branch. Its basically ready and will be available on the next release.
                              You can already test this fix by switching to the develop branch, but be carefull, this branch is still under active development, hence the name;)
                                shiroe @idoodler
                                @idoodler thank you very much again, will keep an eager eye out for this one!
                                  realthinx
                                  I had also an issue with the default calendar module on an iOS 9.3.5 iPad. It could not be rendered. On debugging the iPad Safari with my MacBook i found the reason here: modules/default/calendar/calendar.js, Line 439.
                                  for(let evt of eventList){
                                  should be
                                  for(var evt of eventList){
                                  so that older browsers can render the module without error. Would be great if you can add that for the next release :folded_hands:
                                    StevenSeagal
                                    Force close the app. Then upgrade your app may solve iPad screen black problem.
                                    Reply Quote -1
                                      spoonek
                                      This is still an issue.
                                      I have MM 2.12.0 and an iPad2 running 9.3.6 (the highest it will update to). The iPad2 gets the black screen when I go to MM http://ip-address:8080. My iphone 7 renders the page perfectly as do all of my Mac and PC laptops. I had an issue on an older laptop but updated the browser and that fixed it. I can’t update the browser on the iPad as the newer versions need iOS 10+. Any suggestions? Thanks!!
                                        sdetweil @spoonek
                                        @spoonek did u try chrome browser on the iPad?
                                          spoonek @sdetweil
                                          @sdetweil Yes, that is my default browser. I tried Safari as well, no luck. I then tried to install Firefox and got the same issue, needs version 10+. Thanks!! :clinking_beer_mugs:
                                            sdetweil @spoonek
                                            @spoonek if u have the black screen using chrome, open the dev window (see the menu) and select the console tab and scroll up to see any errors
