    Kalliope assistant + MM
    Scheduled Pinned Locked Moved Fun & Games
    58 Posts 10 Posters 49.9k Views 12 Watching
      maxbachmann
      @sispheor kalliope uses the Google Speech recognition?
      strawberry 3.141S S 2 Replies Last reply Reply Quote 0
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @maxbachmann
        @maxbachmann google is the default, but you can select others https://kalliope-project.github.io/kalliope/settings/settings/#speech-to-text-configuration
          sispheor @maxbachmann
          @maxbachmann Yes you can choose your STT and TTS engine. Some are cloud based and some can be self hosted.
            dmwilsonkc
            @sispheor I am interested in duplicating your work for a different AI. So I figured the best place to start is to install your module and get it working before I make changes to suit my needs with the other AI. I have installed the MMM-Kalliope module, but the curl commands do not display on my mirror. I am not sure what I am doing wrong. Here’s my entry in config.js
                module: "MMM-kalliope",
                position: "upper_third",
                                            max: "5",
                                            keep_seconds: "8",
                                            title: "Kalliope"
            I do receive a json response indicating success, however, nothing gets displayed on the mirror.
            Here’s the curl command:
            curl -H "Content-Type: application/json" -X POST -d '{"notification":"KALLIOPE", "payload": "my message"}' http://localhost:8080/kalliope
            Here’s the response:
            {"status": "success"}
            Yet nothing gets displayed. Do you have any suggestions?
              sispheor @dmwilsonkc
              @dmwilsonkc seems good anyway.
              I don’t see any errors. Maybe test another position. This one is not already used by another module?
              D S 2 Replies Last reply Reply Quote 0
                dmwilsonkc @sispheor
                @sispheor I’ve tried multiple positions for the module, still nothing gets displayed. Not sure why though. I’ve tried refresh, reboot etc. still nothing. Maybe I should delete the module and try a fresh install. The curl should work with just the module installed right?
                  sdetweil @sispheor
                  @sispheor trying to help, I installed the module on my mirror… but… curl notifications don’t work…
                  is there an install step missing? or a package.json that defines the install process for the dependencies?
                  cut paste from the module readme…
                  ~/MagicMirror/modules$ curl -H "Content-Type: application/json" -X POST -d '{"notification":"KALLIOPE", "payload": "my message"}' http://localhost:8080/kalliope
                  curl: (7) Failed to connect to localhost port 8080: Connection refused
                  netstat shows nothing listening on 8080
                  so, my mirror is NOT on 8080, but 8086, due to other components on the normal MM ports…
                  you should update the instructions to say use the MM port on the curl…
                  now… I got the notification, and see the debug log (ctrl-shft-i) say
                  MMM-kalliope received a socket notification: KALLIOPE Payload: my message
                  and the content shows for the configured amount of time (8 seconds per the above config settings)
                    dmwilsonkc
                    @sispheor So using the ctrl-shift-i I was able to find the error that it is throwing.
                    Uncaught TypeError: console.log is not a function
                    This error is repeated in the log each time it receives the post request.
                    What are your suggestions?
                      sdetweil @dmwilsonkc
                      @dmwilsonkc edit the MM/modules/MMM-kalliope/MMM-kalliope.js and change all console. to Log.
                      console.log is ONLY allowed in the node_helper.js and Log.log is ONLY allowed in the module.js
                        dmwilsonkc
                        @sispheor So… I figured out how to get rid of the error. I deleted line 86 of MMM-kalliope.js .
                        console.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                        Everything works fine for now. Not sure why this is, but I’m assuming the chromium browser does not like the console.log code, but I could be wrong.
                          sispheor @sdetweil
                          @sdetweil huumm… yes it is obvious that you have to call your magic mirror url. Including the port if you changed it.
                            @dmwilsonkc indeed it’s weird, I use this code as it in prod on my mirror without any issue.
                            Maybe a recent update of chromium or MM.
                              dmwilsonkc @sdetweil
                              @sdetweil Thanks for the info, I didn’t see it in time. I deleted the entire line of code. It worked after that. I will replace the line with your suggestion this evening.
                                i have 5 lines of console.log on my MMM-kalliope.js
                                  sdetweil @sispheor
                                  @sispheor well, as a new MM user, obvious is not so…
                                    sispheor
                                    Guys, don’t hesitate to send a pull request to the project with your update. Including the “port” documentation part.
                                      dmwilsonkc
                                      @sispheor @sdetweil Hey guys, thanks for your help! I got things working over the weekend.
                                      Here’s a short video.
                                      Cheers!
                                        dmwilsonkc
                                        @sispheor I have made a minor tweak in your code on my fork to display the mycroft icon just above the title, which in my case I have changed to Mycroft. But I was wondering, any ideas on how I could tweak your code to display the message for an interval based on how long the message is? I played with it a little bit, but I think I’m missing exactly how it works. I tried to add an if statement for example:
                                        for(var i = 0; i < this.messages.length; i++){
                                                    var dif = currentDate.getTime() - this.messages[i].timestamp.getTime();
                                                    if (this.message.length > 30){
                                                      var secondsFromCurrentDateToMessageDate = dif / 1500;
                                                      }else{
                                                        var secondsFromCurrentDateToMessageDate = dif / 1000;
                                                    var secondsBetweenDates = Math.abs(secondsFromCurrentDateToMessageDate);
                                                    // delete the message if to old
                                                    if (secondsBetweenDates > this.config.keep_seconds){
                                                        this.messages.splice(i, 1);
                                        But the old messages never get cleaned off the mirror.
                                        Any thoughts about how to increase the time interval that the message is displayed based on the length of the message?
                                        Any help would be much appreciated!
                                        Edit:
                                        Nevermind, I see what I’m doing wrong here. I will work on getting messages to display for different intervals based on how long they are and let you know what I come up with.:face_savouring_delicious_food:
                                          jchenaud
                                          Hello , I want to use Kalliope on my MM but I Have installed Kalliope (and its work i can say “hello” ) i Have MMM-kalliope on my modules.
                                          i have made config.js but nothing display on my MM :(
                                          what i suppose to do ?
                                          my Englishis is not good so don’t blame me please
                                          have a nice day !
                                            sispheor @jchenaud
                                            @jchenaud delete the line 86
                                            I need to update this part.
                                            • 3 / 3
