    Kalliope assistant + MM
    Scheduled Pinned Locked Moved Fun & Games
    58 Posts 10 Posters 55.8k Views 12 Watching
      sispheor @marcnlx
      @marcnlx take a look to starter kits. It contains example. Also there is an example of usage of each neuron on the website.
      Have fun !
      M 1 Reply Last reply
        marcnlx @sispheor
        @sispheor said in Kalliope assistant + MM:
        Have fun !
        I will! I’m going to check everything out later today, thanks!
          marcnlx
          I tested Kalliope yesterday night and once you know how it works, it’s pretty sweet! ;)
          Unfortunately I noticed some bugs/issues which are discussed multiple times on Github, so for now I think I will wait until a later release since I need to restart Kalliope multiple times after 2-3 phrases because of pulseaudio issues which I can’t seem to fix:
          2018-03-18 12:42:27 :: kalliope-0.5.1b :: File found in /home/pi/kalliope_starter_en/trigger/kalliope-EN-12samples.pmdl
          Exception in thread Thread-2:
            File "/usr/lib/python2.7/threading.py", line 810, in __bootstrap_inner
              self.run()
            File "/usr/local/lib/python2.7/dist-packages/kalliope-0.5.1b0-py2.7.egg/kalliope/trigger/snowboy/snowboydecoder.py", line 98, in __init__
              stream_callback=audio_callback)
            File "build/bdist.linux-armv7l/egg/pyaudio.py", line 750, in open
              stream = Stream(self, *args, **kwargs)
            File "build/bdist.linux-armv7l/egg/pyaudio.py", line 441, in __init__
              self._stream = pa.open(**arguments)
          IOError: [Errno -9985] Device unavailable
            sispheor @marcnlx
            @marcnlx Uninstall pulse audio and work only with alsa.
            We’ve remove pulseaudio from our doc.
              sispheor
              Kalliope v0.5.1 has been released with all stuff needed to integrate Magic Mirror.
                maxbachmann
                @sispheor kalliope uses the Google Speech recognition?
                strawberry 3.141S S 2 Replies Last reply
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @maxbachmann
                  @maxbachmann google is the default, but you can select others https://kalliope-project.github.io/kalliope/settings/settings/#speech-to-text-configuration
                    sispheor @maxbachmann
                    @maxbachmann Yes you can choose your STT and TTS engine. Some are cloud based and some can be self hosted.
                      dmwilsonkc
                      @sispheor I am interested in duplicating your work for a different AI. So I figured the best place to start is to install your module and get it working before I make changes to suit my needs with the other AI. I have installed the MMM-Kalliope module, but the curl commands do not display on my mirror. I am not sure what I am doing wrong. Here’s my entry in config.js
                          module: "MMM-kalliope",
                          position: "upper_third",
                                                      max: "5",
                                                      keep_seconds: "8",
                                                      title: "Kalliope"
                      I do receive a json response indicating success, however, nothing gets displayed on the mirror.
                      Here’s the curl command:
                      curl -H "Content-Type: application/json" -X POST -d '{"notification":"KALLIOPE", "payload": "my message"}' http://localhost:8080/kalliope
                      Here’s the response:
                      {"status": "success"}
                      Yet nothing gets displayed. Do you have any suggestions?
                        sispheor @dmwilsonkc
                        @dmwilsonkc seems good anyway.
                        I don’t see any errors. Maybe test another position. This one is not already used by another module?
                        D S 2 Replies Last reply
                          dmwilsonkc @sispheor
                          @sispheor I’ve tried multiple positions for the module, still nothing gets displayed. Not sure why though. I’ve tried refresh, reboot etc. still nothing. Maybe I should delete the module and try a fresh install. The curl should work with just the module installed right?
                            sdetweil @sispheor
                            @sispheor trying to help, I installed the module on my mirror… but… curl notifications don’t work…
                            is there an install step missing? or a package.json that defines the install process for the dependencies?
                            cut paste from the module readme…
                            ~/MagicMirror/modules$ curl -H "Content-Type: application/json" -X POST -d '{"notification":"KALLIOPE", "payload": "my message"}' http://localhost:8080/kalliope
                            curl: (7) Failed to connect to localhost port 8080: Connection refused
                            netstat shows nothing listening on 8080
                            so, my mirror is NOT on 8080, but 8086, due to other components on the normal MM ports…
                            you should update the instructions to say use the MM port on the curl…
                            now… I got the notification, and see the debug log (ctrl-shft-i) say
                            MMM-kalliope received a socket notification: KALLIOPE Payload: my message
                            and the content shows for the configured amount of time (8 seconds per the above config settings)
                              dmwilsonkc
                              @sispheor So using the ctrl-shift-i I was able to find the error that it is throwing.
                              Uncaught TypeError: console.log is not a function
                              This error is repeated in the log each time it receives the post request.
                              What are your suggestions?
                                sdetweil @dmwilsonkc
                                @dmwilsonkc edit the MM/modules/MMM-kalliope/MMM-kalliope.js and change all console. to Log.
                                console.log is ONLY allowed in the node_helper.js and Log.log is ONLY allowed in the module.js
                                D 1 Reply Last reply
                                  dmwilsonkc
                                  @sispheor So… I figured out how to get rid of the error. I deleted line 86 of MMM-kalliope.js .
                                  console.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                                  Everything works fine for now. Not sure why this is, but I’m assuming the chromium browser does not like the console.log code, but I could be wrong.
                                    sispheor @sdetweil
                                    @sdetweil huumm… yes it is obvious that you have to call your magic mirror url. Including the port if you changed it.
                                      @dmwilsonkc indeed it’s weird, I use this code as it in prod on my mirror without any issue.
                                      Maybe a recent update of chromium or MM.
                                        dmwilsonkc @sdetweil
                                        @sdetweil Thanks for the info, I didn’t see it in time. I deleted the entire line of code. It worked after that. I will replace the line with your suggestion this evening.
                                          i have 5 lines of console.log on my MMM-kalliope.js
                                            sdetweil @sispheor
                                            @sispheor well, as a new MM user, obvious is not so…
                                            • 2 / 3
