    MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures)
    84 Posts 25 Posters 115.7k Views 25 Watching
    • BehB Offline
      Beh
      Hey guys, I have good news for you:
      Commit 8c5e69f in the GitHub repo implements the one direction feature feature via the directionStationId variable. You just enter the next station on your line for the direction you want the departures to be shown.
      Some words about that:
      After some tests, the data delivery of this feature seems not to be as reliable as the normal version. Also, please make sure you actually have the right stationId for the direction station.
      Additionally, more request results take more time for the request. So please make sure to keep your maxUnreachableDepartures and maxReachabledepartures low when using this feature.
      If you encounter any issues with that, please open an issue on GitHub.
      I also mentioned this in the readme. Thanks again to @derhuerst for implementing the feature in his service!
      /cc @M1dn8 @gekberlin @ROMSY
      • KlerikerK Offline
        Kleriker
        this is a very nice module! One thing though: Is there a way to make the text stop scrolling from right to left, if it’s a realy long station name?
        BehB 1 Reply Last reply Reply Quote 0
        • BehB Offline
          Beh @Kleriker
          @Kleriker Yes, you can set the marqueeLongDirections option to false`.
          It’s described in the “Configuration” section here: https://github.com/deg0nz/MMM-PublicTransportBerlin
          KlerikerK 1 Reply Last reply Reply Quote 0
          • KlerikerK Offline
            Kleriker @Beh
            @Beh OH how did I fail to see that… Thank you!
              PaulB
              this is an awesome module. Thank you for that!
              Unfortunately, HVV does not support the API Key anymore.
              Does anyone of you guys know a different way of getting the API key?
              Thanks in advance :)
              • I Offline
                Iseknutz @rudibarani
                @rudibarani @olexs Did you solve the problem with the delay-calculation?
                • BehB Offline
                  Beh
                  Attention:
                  Due to changes in the API, the stationId must be a string now. If you experience errors, please check the updated readme and change your configuration to use a string for the ID.
                  This is also true for the directionStationId is you use this feature.
                  • N Offline
                    nem1
                    I get the following error using this module for about 2 days:
                    “Fehler bei Daten abrufen; {ifHafasError”:true,“message”:“Gateaway Time-out”,“statusCode”:504}
                    Das könnte heißen, dass VBB-Daten gerade nicht verfügbar sind.
                    I already updated the stationID and it was working correctly after the change. But now, I get this error.
                    Can anybody help?
                    Thanks a lot.
                    • BehB Offline
                      Beh @nem1
                      @nem1
                      This actually means what it says. VBB Data is currently not available. The API is down for some days now… The error has been reported.
                      You can check the status at https://status.transport.rest
                        AgP42 Project Sponsor Module Developer
                        It is my first installation of this module and I also have the same error message.
                        Is the VBB data still out of order or did I wrongly configure my module ?
                        Thank you in advance,
                        • N Offline
                          nem1 @AgP42
                          @agp42 said in MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures):
                          The API is live again. So I think you did something wrong. Can you post the part of your config?
                            @nem1 said in MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures):
                            Thank you for your answer and your help, in fact I initially copy-paste the official example of config, just to try the module before doing more configuration :
                                module: "MMM-PublicTransportBerlin",
                                    stationId: "90000010000",
                                    hidden: false,
                                    ignoredStations: [900000100003,2342,1337],
                                    ignoredLines: ["U5", "U8", "S75" "Bus 100"],
                                    excludedTransportationTypes: "bus,suburban,subway",
                                    travelTimeToStation: 10,
                                    interval: 120000,
                                    departureMinutes: 10,
                                    maxDepartures: 15,
                                    marqueeLongDirections: true,
                                    showColoredLineSymbols: true,
                                    useColorForRealtimeInfo: true,
                                    showTableHeaders: true,
                                    showTableHeadersAsSymbols: true,
                                    maxUnreachableDepartures: 3,
                                    maxReachableDepartures: 7,
                                    fadeUnreachableDepartures: true,
                                    fadeReachableDepartures: true,
                                    fadePointForReachableDepartures: 0.25,
                                    excludeDelayFromTimeLabel: true
                            but it didn’t work at all, the MagicMirror display the error that the config file is not valid :“Please create a config file”.
                            So to debug that I remove all the non-required parameters, and keep only :
                            Then the Mirror is starting again but this module display this error :
                            Any idea of the origin of the problem ?
                            Can you maybe send me a valid config to try it ?
                            (My Mirror was in 2.4.0 and now updated in 2.4.1, but same issue, the Module is updated at its last version)
                            Thanks in advance,
                            AgP42
                              Dicous
                              by me the same here =/ . since 2 days
                                AgP42 Project Sponsor Module Developer @Dicous
                                @dicous said in MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures):
                                I personnaly never succeded to make that module work, but I use this one instead that is really cool and powerfull :
                                MMM-PublicTransportHafas
                                • BehB Offline
                                  Beh
                                  The API is live again. Let’s see how long the new method is working… I have antoher solution on my roadmap to make this more reliable (hopefully :D)
                                  @AgP42 The Problem was not your configuration, but the data source the module is getting it’s data from. When you get the shown error, the module was configured right.
                                  For future readers: Please look into the GitHub issues of the module when problems occur!
                                  You can find them here: https://github.com/deg0nz/MMM-PublicTransportBerlin/issues/
                                  Additionally, you can check the avialability of the data source here: https://status.transport.rest
                                  • BehB Offline
                                    Beh
                                    I changed the module to use vbb-hafas directly instead of using the unavailabe endpoint 2.vbb.transport.rest. If you update your module, you should be able to see departures again (let’s see how long this will work…).
                                    @AgP42: Note, that MMM-PublictransportBerlin parses VBB/Berlin-specific changes in the HAFAS-API, as @derhuerst described them here: https://github.com/public-transport/hafas-client/blob/master/p/vbb/readme.md.
                                    If they don’t matter to you, you can leave it as it is and continue using MMM-PublicTransportHafas :)
                                    • N Offline
                                      nem1
                                      After navigation to the folder MMM-PublicTransportBerlin, I used the commands:
                                      sudo git pull
                                      sudo npm install
                                      to update the module, because of this API problem.
                                      After rebooting my mirror, the browser automatically starts (as it should), but it shows nothing. Nothing is displayed and I don´t get any SSH connection? Any ideas what happend? (Just before I start to take the mirror of the wall and put the SD-Card into my Laptop.)
                                      BehB 1 Reply Last reply Reply Quote -1
                                      • BehB Offline
                                        Beh @nem1
                                        @nem1 Try to make the git pull and npm install without sudo.
                                        You can also try to completely remove the module folder and clone it again. Sometimes this solves such problems.
                                          Migdon
                                          @Beh
                                          Hi Beh, I have some troubles with this module.
                                          I installed it correctly with the given commands and I can also see the Folder.
                                          Then I copied the example (alexander Platz) into the Magic mirror config where all the other modules are.
                                          When I start MM nothing happens, all other modules load smoothly, but not the transportation module, not even an error message. It’s just like the code of this module isn’t there but I double checked everything.
                                          Did I something wrong?
                                          thank already for the replys!
                                          • MZ-BERM Offline
                                            MZ-BER
                                            It works like a charm! Thank you very much for establishing. I have only one question. I there a way to adjust the colors for the transportation Bus? It is always in pink. For Tram and S-Bahn the color changed based on line. But Bus doesn’t change at all.
                                            Again, thank you for this nice module.
                                            • 4 / 5
