    MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures)
    84 Posts 25 Posters 120.0k Views 25 Watching
    • KlerikerK Offline
      Kleriker
      this is a very nice module! One thing though: Is there a way to make the text stop scrolling from right to left, if it’s a realy long station name?
        Beh @Kleriker
        @Kleriker Yes, you can set the marqueeLongDirections option to false`.
        It’s described in the “Configuration” section here: https://github.com/deg0nz/MMM-PublicTransportBerlin
        KlerikerK 1 Reply Last reply Reply Quote 0
        • KlerikerK Offline
          Kleriker @Beh
          @Beh OH how did I fail to see that… Thank you!
            PaulB
            this is an awesome module. Thank you for that!
            Unfortunately, HVV does not support the API Key anymore.
            Does anyone of you guys know a different way of getting the API key?
            Thanks in advance :)
            • I Offline
              Iseknutz @rudibarani
              @rudibarani @olexs Did you solve the problem with the delay-calculation?
                Beh
                Attention:
                Due to changes in the API, the stationId must be a string now. If you experience errors, please check the updated readme and change your configuration to use a string for the ID.
                This is also true for the directionStationId is you use this feature.
                • N Offline
                  nem1
                  I get the following error using this module for about 2 days:
                  “Fehler bei Daten abrufen; {ifHafasError”:true,“message”:“Gateaway Time-out”,“statusCode”:504}
                  Das könnte heißen, dass VBB-Daten gerade nicht verfügbar sind.
                  I already updated the stationID and it was working correctly after the change. But now, I get this error.
                  Can anybody help?
                  Thanks a lot.
                    Beh @nem1
                    @nem1
                    This actually means what it says. VBB Data is currently not available. The API is down for some days now… The error has been reported.
                    You can check the status at https://status.transport.rest
                      AgP42 Project Sponsor Module Developer
                      It is my first installation of this module and I also have the same error message.
                      Is the VBB data still out of order or did I wrongly configure my module ?
                      Thank you in advance,
                      • N Offline
                        nem1 @AgP42
                        @agp42 said in MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures):
                        The API is live again. So I think you did something wrong. Can you post the part of your config?
                          @nem1 said in MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures):
                          Thank you for your answer and your help, in fact I initially copy-paste the official example of config, just to try the module before doing more configuration :
                              module: "MMM-PublicTransportBerlin",
                                  stationId: "90000010000",
                                  hidden: false,
                                  ignoredStations: [900000100003,2342,1337],
                                  ignoredLines: ["U5", "U8", "S75" "Bus 100"],
                                  excludedTransportationTypes: "bus,suburban,subway",
                                  travelTimeToStation: 10,
                                  interval: 120000,
                                  departureMinutes: 10,
                                  maxDepartures: 15,
                                  marqueeLongDirections: true,
                                  showColoredLineSymbols: true,
                                  useColorForRealtimeInfo: true,
                                  showTableHeaders: true,
                                  showTableHeadersAsSymbols: true,
                                  maxUnreachableDepartures: 3,
                                  maxReachableDepartures: 7,
                                  fadeUnreachableDepartures: true,
                                  fadeReachableDepartures: true,
                                  fadePointForReachableDepartures: 0.25,
                                  excludeDelayFromTimeLabel: true
                          but it didn’t work at all, the MagicMirror display the error that the config file is not valid :“Please create a config file”.
                          So to debug that I remove all the non-required parameters, and keep only :
                          Then the Mirror is starting again but this module display this error :
                          Any idea of the origin of the problem ?
                          Can you maybe send me a valid config to try it ?
                          (My Mirror was in 2.4.0 and now updated in 2.4.1, but same issue, the Module is updated at its last version)
                          Thanks in advance,
                          AgP42
                            Dicous
                            by me the same here =/ . since 2 days
                              AgP42 Project Sponsor Module Developer @Dicous
                              @dicous said in MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures):
                              I personnaly never succeded to make that module work, but I use this one instead that is really cool and powerfull :
                              MMM-PublicTransportHafas
                                Beh
                                The API is live again. Let’s see how long the new method is working… I have antoher solution on my roadmap to make this more reliable (hopefully :D)
                                @AgP42 The Problem was not your configuration, but the data source the module is getting it’s data from. When you get the shown error, the module was configured right.
                                For future readers: Please look into the GitHub issues of the module when problems occur!
                                You can find them here: https://github.com/deg0nz/MMM-PublicTransportBerlin/issues/
                                Additionally, you can check the avialability of the data source here: https://status.transport.rest
                                  Beh
                                  I changed the module to use vbb-hafas directly instead of using the unavailabe endpoint 2.vbb.transport.rest. If you update your module, you should be able to see departures again (let’s see how long this will work…).
                                  @AgP42: Note, that MMM-PublictransportBerlin parses VBB/Berlin-specific changes in the HAFAS-API, as @derhuerst described them here: https://github.com/public-transport/hafas-client/blob/master/p/vbb/readme.md.
                                  If they don’t matter to you, you can leave it as it is and continue using MMM-PublicTransportHafas :)
                                  • N Offline
                                    nem1
                                    After navigation to the folder MMM-PublicTransportBerlin, I used the commands:
                                    sudo git pull
                                    sudo npm install
                                    to update the module, because of this API problem.
                                    After rebooting my mirror, the browser automatically starts (as it should), but it shows nothing. Nothing is displayed and I don´t get any SSH connection? Any ideas what happend? (Just before I start to take the mirror of the wall and put the SD-Card into my Laptop.)
                                    B 1 Reply Last reply Reply Quote -1
                                      Beh @nem1
                                      @nem1 Try to make the git pull and npm install without sudo.
                                      You can also try to completely remove the module folder and clone it again. Sometimes this solves such problems.
                                        Migdon
                                        @Beh
                                        Hi Beh, I have some troubles with this module.
                                        I installed it correctly with the given commands and I can also see the Folder.
                                        Then I copied the example (alexander Platz) into the Magic mirror config where all the other modules are.
                                        When I start MM nothing happens, all other modules load smoothly, but not the transportation module, not even an error message. It’s just like the code of this module isn’t there but I double checked everything.
                                        Did I something wrong?
                                        thank already for the replys!
                                        • MZ-BERM Offline
                                          MZ-BER
                                          It works like a charm! Thank you very much for establishing. I have only one question. I there a way to adjust the colors for the transportation Bus? It is always in pink. For Tram and S-Bahn the color changed based on line. But Bus doesn’t change at all.
                                          Again, thank you for this nice module.
                                            Beh @MZ-BER
                                            @MZ-BER Hey! Thanks a lot! I’m happy you like it :)
                                            If I remember correctly, the bus lines in Berlin have no colors. Maybe @derhuerst can verify that?!
                                            If you can give me a source where to find the colors for each bus line, I can add this.
                                            What we could do though, is distinguishing normal buses, Metro-Bus and X-Bus.
                                            • 4 / 5
