    Applied change to config.txt, MM fails to boot.
    13 Posts 5 Posters 6.9k Views 6 Watching
      Richard238
      display_rotate = 1 - is commented out (I’m happy with MM in landscape mode)
      avoid_warnings = 1 - line doesn’t exist.
      • mochmanM Offline
        mochman Module Developer
        I had the same issue. I changed dtoverlay=vc4-kms-v3d to dtoverlay=vc4-fkms-v3d and was able to boot up again.
          Richard238
          That doesn’t work for me, MM boots to a few lines about blocks, then nothing else.
          • MichMichM Offline
            MichMich
            Did you try the rasps-config tool to configure the GL driver?
              Richard238
              No, because if that kills it, I don’t know how to bring it back - what file to edit etc…?
              MichMichM 1 Reply Last reply Reply Quote 0
              • MichMichM Offline
                MichMich @Richard238
                @richard238 It just modifies the config.txt for you in a save way. There is a bigger chance of you killing your pi doing it manually than using the config tool.
                  Richard238
                  Ok, when I get time, I’ll create a backup of the MM SD card first, and then try the GUI config tool.
                  Thanks.
                    Sun
                    Mine installation was successful.
                    First I update rp3
                    #sudo apt-get update
                    #sudo apt-get upgrade
                    #cd MagicMirror/
                    #git pull && npm install
                    #cd
                    #sudo nano /boot/config.txt (add in config.txt and save)
                    display_rotate=1
                    #sudo raspi-config
                    Advanced Options
                    GL Driver
                    G1 GL (Full KMS) OpenGL desktop driver with full KMS
                    #sudo reboot
                    ***I cannot remeber if I did this process or not
                    #sudo nano ~/.config/lxsession/LXDE-pi/autostart
                    @xrandr --output HDMI-1 --rotate right (add to autostart)
                      Richard238
                      Done through raspi-config, seems ok, boots and runs fine.
                      sudo vcgencmd measure_temp
                      shows 56.9C
