    Applied change to config.txt, MM fails to boot.
    13 Posts 5 Posters 7.5k Views 6 Watching
      JoeFranz
      Did you remove these entries in the config.txt?
      display_rotate = 1
      avoid_warnings = 1
        Richard238
        display_rotate = 1 - is commented out (I’m happy with MM in landscape mode)
        avoid_warnings = 1 - line doesn’t exist.
          mochman Module Developer
          I had the same issue. I changed dtoverlay=vc4-kms-v3d to dtoverlay=vc4-fkms-v3d and was able to boot up again.
            Richard238
            That doesn’t work for me, MM boots to a few lines about blocks, then nothing else.
            • MichMichM Offline
              MichMich
              Did you try the rasps-config tool to configure the GL driver?
                Richard238
                No, because if that kills it, I don’t know how to bring it back - what file to edit etc…?
                MichMichM 1 Reply Last reply Reply Quote 0
                • MichMichM Offline
                  MichMich @Richard238
                  @richard238 It just modifies the config.txt for you in a save way. There is a bigger chance of you killing your pi doing it manually than using the config tool.
                    Richard238
                    Ok, when I get time, I’ll create a backup of the MM SD card first, and then try the GUI config tool.
                    Thanks.
                      Sun
                      Mine installation was successful.
                      First I update rp3
                      #sudo apt-get update
                      #sudo apt-get upgrade
                      #cd MagicMirror/
                      #git pull && npm install
                      #cd
                      #sudo nano /boot/config.txt (add in config.txt and save)
                      display_rotate=1
                      #sudo raspi-config
                      Advanced Options
                      GL Driver
                      G1 GL (Full KMS) OpenGL desktop driver with full KMS
                      #sudo reboot
                      ***I cannot remeber if I did this process or not
                      #sudo nano ~/.config/lxsession/LXDE-pi/autostart
                      @xrandr --output HDMI-1 --rotate right (add to autostart)
                        Richard238
                        Done through raspi-config, seems ok, boots and runs fine.
                        sudo vcgencmd measure_temp
                        shows 56.9C
