    Changing Custom Font Type Within Magic Mirror
    Scheduled Pinned Locked Moved Solved Custom CSS
    magic mirrorfontcustom
    7 Posts 2 Posters 7.4k Views 1 Watching
    • brobergB Offline
      broberg Project Sponsor
      Yes, only the custom.css (anything written in the custom.css will override the same values in main.css)
      And if you edit the main.css and update your mirror the update will overwrite the main.css and your changes within. This doesn’t happen with custom.css.
      To see where you went wrong, pleas post your custom.css file.
      But common things to adress, search path to the font file, the font file sets the format, what does your files end with?
      place new css-code after body{}
      • W Offline
        Winter
        Hello Broberg,
        I have attached the code for both my custom.css and main.css files below:
        Also, addressing your mention of an “update”, is that an update in terms of the software or an edit by the user to the default main.css?
        Custom.css file:
         * Magic Mirror                                      *
         * Custom CSS                                        *
         * By Michael Teeuw http://michaelteeuw.nl           *
         * MIT Licensed.                                     *
         * Add any custom CSS below.                         *
         * Changes to this files will be ignored by GIT. *
        body {
        	@font-face {
        	  font-family: Alcubierre;
        	  font-style: normal;
        	  font-weight: 100;
        	  src: url("/home/pi/MagicMirror/fonts/Alcubierre.ttf") format("truetype");
        	  src: url("/home/pi/MagicMirror/fonts/Alcubierre.woff") format("woff");
        	@font-face{
        	  font-family: Luxia;
        	  src: url("/home/pi/MagicMirror/fonts/Luxia-Display.ttf") format("truetype");
        	  font-weight: normal;
        	  font-style: normal;
        	.calendar {
        	   font-family: Luxia;
        When I run the mirror, I keep either the Luxia or the Alcubierre section commented so only one runs. Though, as you can see here, I have the Luxia font in “.ttf” format and the Alcubierre font in both “.ttf” and “.woff” format, yet when I run the program neither file seems to achieve the desired result of changing my font to either “Luxia” or “Alcubierre”.
        I have also attached my main.css file because I may have unknowingly made a few edits to it which might’ve caused the custom.css file to not run properly.
        Main.css:
        html {
          cursor: none;
          overflow: hidden;
          background: #000;
        ::-webkit-scrollbar {
          display: none;
        body {
          margin: 60px;
          position: absolute;
          height: calc(100% - 120px);
          width: calc(100% - 120px);
          background: #000;
          color: #aaa;
          //font-family: "Roboto Thin", sans-serif;
          //font-family: "Montserrat", sans-serif;
          //font-family: Luxia;
          font-style: normal;
          font-weight: 400;
          font-size: 2em;
          line-height: 1.5em;
          -webkit-font-smoothing: antialiased;
         * Default styles.
        .dimmed {
          //color: #666;
          color: #fff;
        .normal {
          //color: #999;
          color: #fff;
        .bright {
          color: #fff;
        .xsmall {
          font-size: 15px;
          line-height: 20px;
        .small {
          font-size: 20px;
          line-height: 25px;
        .medium {
          font-size: 30px;
          line-height: 35px;
        .large {
          font-size: 65px;
          line-height: 65px;
        .xlarge {
          font-size: 75px;
          line-height: 75px;
          letter-spacing: -3px;
        .thin {
          //font-family: Roboto, sans-serif;
          font-weight: 100;
        .light {
          //font-family: "Roboto Condensed", sans-serif;
          font-weight: 300;
        .regular {
          font-weight: 400;
        .bold {
          font-weight: 700;
        .align-right {
          text-align: right;
        .align-left {
          text-align: left;
        header {
          //text-transform: uppercase;
          font-size: 25px;
          //font-family: "Roboto Condensed", Arial, Helvetica, sans-serif;
          //font-family: "Roboto Condensed";
          font-weight: 400;
          border-bottom: 1px solid #999;
          line-height: 15px;
          padding-bottom: 5px;
          margin-bottom: 10px;
          //color: #999;
          color: #fff;
        sup {
          font-size: 50%;
          line-height: 50%;
         * Module styles.
        .module {
          margin-bottom: 30px;
        .region.bottom .module {
          margin-top: 30px;
          margin-bottom: 0;
        .no-wrap {
          white-space: nowrap;
          overflow: hidden;
          text-overflow: ellipsis;
         * Region Definitions.
        .region {
          position: absolute;
        .region.fullscreen {
          position: absolute;
          top: -60px;
          left: -60px;
          right: -60px;
          bottom: -60px;
          pointer-events: none;
        .region.fullscreen * {
          pointer-events: auto;
        .region.right {
          right: 0;
          text-align: right;
        .region.top {
          top: 0;
        .region.top .container {
          margin-bottom: 25px;
        .region.bottom .container {
          margin-top: 25px;
        .region.top .container:empty {
          margin-bottom: 0;
        .region.top.center,
        .region.bottom.center {
          left: 50%;
          -moz-transform: translateX(-50%);
          -o-transform: translateX(-50%);
          -webkit-transform: translateX(-50%);
          -ms-transform: translateX(-50%);
        .region.top.right,
        .region.top.left,
        .region.top.center {
          top: 100%;
        .region.bottom {
          bottom: 0;
        .region.bottom .container:empty {
          margin-top: 0;
        .region.bottom.right,
        .region.bottom.center,
        .region.bottom.left {
          bottom: 100%;
        .region.bar {
          width: 100%;
          text-align: center;
        .region.third,
        .region.middle.center {
          width: 100%;
          text-align: center;
          -moz-transform: translateY(-50%);
          -o-transform: translateY(-50%);
          -webkit-transform: translateY(-50%);
          -ms-transform: translateY(-50%);
        .region.upper.third {
          top: 33%;
          top: 50%;
        .region.lower.third {
          top: 66%;
        .region.left {
          text-align: left;
        .region table {
          width: 100%;
          border-spacing: 0;
          border-collapse: separate;
        • brobergB Offline
          broberg Project Sponsor @Winter
          @winter
          Updates to the magicmirror software.
          You can keep the changes in the main.css, but you will get an error the day you try to update the magicmirror to a newer version.
          Try using this :
          	@font-face{
          	  font-family: Luxia;
          	  src: url("../fonts/Luxia-Display.ttf") format("truetype");
          Note that the file path is based on where your css files is and where the fonts are.
          You can place the fonts directly in to the css folder, if you do that the file path (url) would be like this :
           	@font-face{
          	  font-family: Luxia;
          	  src: url("Luxia-Display.ttf") format("truetype");
          • W Offline
            Winter
            Hey @broberg, I tried your edits and it seems that “Luxia” is now working, though when I try the exact setup for “Alcubierre”, it defaults back to the font shown in the first image I attached. Would you suggest trying to reinstall the font for Alcubierre and seeing if that works or would you have any further recommendations?
            • brobergB Offline
              @winter
              check you have the spelling correct for the filename, and use only the ttf file (I don’t know why there is two different format files for the same font anyways)
              • W Offline
                Winter
                @broberg Ah, that seems to be what the problem was. Thank you so much for your help in solving this issue!
                As for the two different files I went ahead and removed the .woff file from the program.
