    Autostart woes
    7 Posts 3 Posters 2.9k Views 3 Watching
      i have a 2.4.1 instance of MM running just fine… now to set to start on boot…
      install pm2…
      the doc for ‘pm2 startup’ doesn’t help me…
      ‘will give you the command u need to execute’
      execute when, how? if unattended, who is ‘you’?
      anyhow…from the pi home directory
      pm2 start mm.sh
      doesn’t
      now what?
      i have a startup script, which checks for and starts other dependencies…
      called run
      it doesn’t work either
      and, so… IF I wanted pm2 to start at boot… how do I do THAT??
      execute that ‘command’…
      done that too… and well, pm2 doesn’t start at boot… (no running process with pm2 in it anywhere)
      now what?
        I see this in the pi/.pm2/pm2.log, after service pm2-pi start
        internal/modules/cjs/loader.js:583
            throw err;
        Error: Cannot find module './lib/eventemitter2'
        and the systemctl status pm2-pi.service command produces
        ● pm2-pi.service - PM2 process manager
           Loaded: loaded (/etc/systemd/system/pm2-pi.service; enabled; vendor preset: enabled)
           Active: failed (Result: resources) since Tue 2018-07-10 10:36:25 CDT; 7s ago
             Docs: https://pm2.keymetrics.io/
          Process: 2899 ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect (code=exited, status=0/SUCCESS)
        Jul 10 10:36:23 raspberrypi systemd[1]: Starting PM2 process manager...
        Jul 10 10:36:24 raspberrypi pm2[2899]: [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
        Jul 10 10:36:25 raspberrypi systemd[1]: pm2-pi.service: PID file /home/pi/.pm2/pm2.pid not readable (yet?) after start: No such file or directory
        Jul 10 10:36:25 raspberrypi systemd[1]: Failed to start PM2 process manager.
        Jul 10 10:36:25 raspberrypi systemd[1]: pm2-pi.service: Unit entered failed state.
        Jul 10 10:36:25 raspberrypi systemd[1]: pm2-pi.service: Failed with result 'resources'.
        so, it looks like some pm2 install problem
          I see this error/warning during
          sudo npm pm2 install -g
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/pm2/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
            i gave up on pm2, edited /etc/rc.local
              Did you try installing it without sudo? Just a guess
                sdetweil @Mykle1
                @mykle1 yes, cut and paste from the mm doc
                • lavolp3L Offline
                  lavolp3 Module Developer
                  I’d recommend trying to do it again using the description by MichMich
                  https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                  It is crystal clear from what I see, also describes what to do.
                  "the doc for ‘pm2 startup’ doesn’t help me…
                  execute when, how? if unattended, who is ‘you’?"
                  No offense, but btoh the doc and your terminal will show you exactly what to do. Copy a line of text the terminal throws out and execute it again.
                  That’s the reason I’d suggest to do it again with a bit more patience. :-)
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
