Autostart woes
7 Posts 3 Posters 2.5k Views 3 Watching
  • S Online
    i have a 2.4.1 instance of MM running just fine… now to set to start on boot…
    install pm2…
    the doc for ‘pm2 startup’ doesn’t help me…
    ‘will give you the command u need to execute’
    execute when, how? if unattended, who is ‘you’?
    anyhow…from the pi home directory
    pm2 start mm.sh
    doesn’t
    now what?
    i have a startup script, which checks for and starts other dependencies…
    called run
    it doesn’t work either
    and, so… IF I wanted pm2 to start at boot… how do I do THAT??
    execute that ‘command’…
    done that too… and well, pm2 doesn’t start at boot… (no running process with pm2 in it anywhere)
    now what?
    • S Online
      I see this in the pi/.pm2/pm2.log, after service pm2-pi start
      internal/modules/cjs/loader.js:583
          throw err;
      Error: Cannot find module './lib/eventemitter2'
      and the systemctl status pm2-pi.service command produces
      ● pm2-pi.service - PM2 process manager
         Loaded: loaded (/etc/systemd/system/pm2-pi.service; enabled; vendor preset: enabled)
         Active: failed (Result: resources) since Tue 2018-07-10 10:36:25 CDT; 7s ago
           Docs: https://pm2.keymetrics.io/
        Process: 2899 ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect (code=exited, status=0/SUCCESS)
      Jul 10 10:36:23 raspberrypi systemd[1]: Starting PM2 process manager...
      Jul 10 10:36:24 raspberrypi pm2[2899]: [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
      Jul 10 10:36:25 raspberrypi systemd[1]: pm2-pi.service: PID file /home/pi/.pm2/pm2.pid not readable (yet?) after start: No such file or directory
      Jul 10 10:36:25 raspberrypi systemd[1]: Failed to start PM2 process manager.
      Jul 10 10:36:25 raspberrypi systemd[1]: pm2-pi.service: Unit entered failed state.
      Jul 10 10:36:25 raspberrypi systemd[1]: pm2-pi.service: Failed with result 'resources'.
      so, it looks like some pm2 install problem
      • S Online
        I see this error/warning during
        sudo npm pm2 install -g
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/pm2/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
        • S Online
          i gave up on pm2, edited /etc/rc.local
          M 1 Reply Last reply Jul 11, 2018, 12:06 AM Reply Quote 0
            Did you try installing it without sudo? Just a guess
            S 1 Reply Last reply Jul 11, 2018, 1:01 AM Reply Quote 0
            • S Online
              sdetweil @Mykle1
              @mykle1 yes, cut and paste from the mm doc
              • L Offline
                lavolp3 Module Developer
                I’d recommend trying to do it again using the description by MichMich
                https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                It is crystal clear from what I see, also describes what to do.
                "the doc for ‘pm2 startup’ doesn’t help me…
                execute when, how? if unattended, who is ‘you’?"
                No offense, but btoh the doc and your terminal will show you exactly what to do. Copy a line of text the terminal throws out and execute it again.
                That’s the reason I’d suggest to do it again with a bit more patience. :-)
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
