    • MagicMirrorΒ² Repository
    Two Instances in PM2
    19 Posts 6 Posters 14.8k Views 5 Watching
      paul.calladine
      I’m sure there’s a really simple fix for this, it looks like somehow I’ve managed to get 2 instances of MagicMirror to start on boot up
      β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
      β”‚ Name        β”‚ mode β”‚ status β”‚ β†Ί β”‚ cpu β”‚ memory   β”‚
      β”œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€
      β”‚ MagicMirror β”‚ fork β”‚ online β”‚ 0 β”‚ 0%  β”‚ 2.3 MB   β”‚
      β”‚ mm          β”‚ fork β”‚ online β”‚ 0 β”‚ 0%  β”‚ 2.3 MB   β”‚
      β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
      Is there a simple way I can remove the mm process altogether? Or simply just disable it from booting up?
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @paul.calladine
        @paul.calladine
        pm2 stop mm
        pm2 delete mm
        pm2 save
        rm ~/mm.sh
        Then check your instances again. :-)
        P S 2 Replies Last reply
        Reply Quote 5
          paul.calladine @Mykle1
          @Mykle1 Worked perfectly, thanks!!
          • Mykle1M
            @paul.calladine
            Cheers, mate! :-)
            • A
              AliAS
              Had exactly the same issue. Thought I’d resolved it and then it came back after reboot. Following these instructions worked.
                janth
                Hello:)
                I run it on a Pi ZeroW and I know that’s not the common way. I use PM2 since I could not find any other working solution for Jessie or Stretch. Though it starts MM and chromium and everything looks well, the CPU is at 100 % all the time. When checking the active processes, the β€œnode server only” is listed four times and chromium twice. Each node instance eats up to 20 % of CPU time.
                Any idea how to stop that?
                  shazglass @Mykle1
                  @mykle1 hi again☺️. Hope u are well. I had this same problem. I ran your suggestions and now I only have MagicMirror and not mm. However. When I pm2 start MagicMirror. It shows it’s β€œonline” yet fails to go onto mirror mode. Please help. I don’t want to start from scratch. Also how do I stop the screen going into sleep mode? Thnx @Mykle1 you have been my MM life support thus far!!!
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @shazglass
                    @shazglass
                    Hey shaz. I’m well, thanks. How are things down under? :-)
                    Sounds like you might be in node server only mode, perhaps.
                    What happens if you navigate to the MagicMirror folder in your terminal and type npm start? Does the mirror run as expected then?
                    Worst case scenario (I think) is you would have to delete PM2 altogether and re-install using the guide from the MM repo. Unless someone has a better idea. (They usually do) :-)
                      shazglass @Mykle1
                      @mykle1 hi. So glad to hear you are doing well. Bit chilly here in SA but all good thnx.
                      Ok so I went into the MagicMirror module in terminal as you suggested and ran npm start. It ran a whole bunch of lines then went into Mirror mode. Everything is there. Then to stop it I held control + q to stop. It stops it and puts me back to the terminal I started in. How for demo purposes would I go in and out of the mirror now? How do I get it back to easy access? And what did I do wrong? On install when it asked do u want to use pm2 I said Y. Then is new clean terminal I did pm2 startup. I copied and pasted the line required. I rebooted. Then typed nano mm.sh and added ~/MagicMirror
                      DISPLAY=:0 npm start
                      Saved then typed
                      Chmod +x mm.sh
                      Then typed pm2 save
                      That’s where I get two instances one MagicMirror that won’t respond until ur way
                      And the other is mm which I deleted with your thread instructions.
                      So how do I get easy in and out of mirror mode? Thanx my life saver once again!
                      Also. I can’t disable the screen saver with the new version. How do I stop it now?
                      Thnx. Look forward to hearing from youπŸ˜‰
                        shazglass @Mykle1
                        @mykle1 ok. Don’t worry about screen saver. Sorted that out. But not sure how I did it. LOL!
                          shazglass
                          Hi everyone.
                          Please help. I have two instances of mm starting on boot up. I don’t know what I did wrong. When pi starts the cpu is showing movement but doesn’t boot into mm. I have to type is pi pm2 stop mm. Then pm2 stop MagicMirror to stop the cpu usage. I go into cd MagicMirror and type npm start and my mirror starts. Control q and quits. But this isn’t the right way to do it. How and in what directory do I go into to delete pm2 as I have two instances. Thnx everyone. Appreciate all help.
                          • Mykle1M
                            @shazglass
                            About 9 posts up from here are the directions on how to delete one instance on autostarting MM
                              shazglass @Mykle1
                              @mykle1 hi againπŸ˜‰. Yep. I did do that and that’s when both run in the background but none go to mirror mode. Then u suggested going into cd MagicMirror and running npm start and then it goes into mirror mode. I use control q to quit but I still have two instances. I need to delete both and reinstall but without losing my mirror and that’s what I don’t know how to do. I want it back to boot up going straight to mirror mode and then just control q to quit then pm2 stop MagicMirror and pm2 start MagicMirror. Right now I have mm and MagicMirror. I’m just at a loss☹️
                              bheplerB 1 Reply Last reply
                              • bheplerB
                                bhepler Module Developer @shazglass
                                @shazglass All right, we’ll get you through it.
                                pm2 runs on Pi startup and will start your mirror process for you. There should be only one listing. If you ran the installation script and said β€œyes” to using pm2, there should be only one process called MagicMirror in pm2.
                                To remove the mm process from pm2, enter the following:
                                cd ~
                                pm2 stop all
                                pm2 delete mm
                                pm2 save
                                rm mm.sh
                                pm2 flush
                                At this point, your Magic Mirror interface should appear after a minute or so. You can press ctrl-q to exit the Magic Mirror interface, but pm2 should bring it back up in short order.
                                Reply Quote 2
                                  shazglass @bhepler
                                  @bhepler hi there.
                                  Thank you for the instructions. I did exactly as you said. It has taken away the β€œmm” instance. I am left with only the MagicMirror one now. However. It will not boot Into mirror mode on start up, although I can see the CPU is being used, so I type pm2 stop MagicMirror and it shows that it has stopped. Only way I can get the mirror to show is by typing cd MagicMirror
                                  Then in that directory I type npm start. It does a small load thing and then my mirror shows. How can I get it to how it should be without having to go into the mirror directory?
                                  Thank you for your patience. Most appreciated!
                                  • bheplerB
                                    @shazglass - Hmm. I don’t know. It should be working normally at this point. Let’s try switching to the previous process. We’ll delete the one that the installer created, then add the one to your script.
                                    First, we remove the existing process:
                                    cd ~
                                    pm2 delete MagicMirror
                                    pm2 save
                                    Then we use your mm.sh script that you had earlier.
                                    pm2 flush
                                    pm2 start mm.sh
                                    pm2 save
                                    At this point, your mirror should come up in about 30 seconds. If it does not, enter pm2 log mm and copy the results here. Be sure to use the forum markup tools to help format your log messages.
                                      shazglass @bhepler
                                      @bhepler hithere
                                      I did as per your instructions - except I dont know how to use the forum markup tool…so just copied and pasted.
                                      I now dont have any instances running? I can only access my mirror if i go ino cd MagicMirror and then type npm install.
                                      pi@raspberrypi:~ $ pm2 stop all
                                      [PM2] Applying action stopProcessId on app [all](ids: 0)
                                      [PM2] MagicMirror βœ“
                                      β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”
                                      β”œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”Όβ”€β”€β”€β”€β”€β”€β”€β”€β”€
                                      β”‚ MagicMirror β”‚ fork β”‚ stopped β”‚ 6 β”‚ 0% β”‚ 0 B β”‚
                                      β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”˜
                                      Use pm2 show <id|name> to get more details about an app
                                      pi@raspberrypi:~ $ pm2 delete MagicMirror
                                      [PM2] Applying action deleteProcessId on app [MagicMirror](ids: 0)
                                      β”Œβ”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”
                                      β””β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”˜
                                      pi@raspberrypi:~ $ pm2 save
                                      [PM2] Saving current process list…
                                      [PM2] Nothing to save !!!
                                      [PM2] In this case we keep old dump file. To clear dump file you can delete it manually !
                                      pi@raspberrypi:~ $ pm2 flush
                                      [PM2] Flushing /home/pi/.pm2/pm2.log
                                      [PM2] Logs flushed
                                      pi@raspberrypi:~ $ pm2 start mm.sh
                                      [PM2][ERROR] script not found : /home/pi/mm.sh
                                      pi@raspberrypi:~ $ pm2 log mm
                                      [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                                      [PM2][ERROR] No file to stream for app [mm], exiting.
                                      pi@raspberrypi:~ $ pm2 log MagicMirror
                                      [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
                                      [PM2][ERROR] No file to stream for app [MagicMirror], exiting.
                                      pi@raspberrypi:~ $
                                        shazglass
                                        I did find this in the cd MagicMirror???
                                        pi@raspberrypi:~/MagicMirror $ pm2 log MagicMirror
                                        /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                                        /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                                        0|MagicMir | at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
                                        0|MagicMir | at Function.Module._load (internal/modules/cjs/loader.js:498:3)
                                        0|MagicMir | at Module.require (internal/modules/cjs/loader.js:598:17)
                                        0|MagicMir | at require (internal/modules/cjs/helpers.js:11:18)
                                        0|MagicMir | Error: ENOENT: no such file or directory, open β€˜package.json’
                                        0|MagicMir | at Object.fs.openSync (fs.js:660:18)
                                        0|MagicMir | at Object.fs.readFileSync (fs.js:565:33)
                                        0|MagicMir | at Object. (/home/pi/MagicMirror/js/app.js:15:32)
                                        0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:654:30)
                                        0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:665:10)
                                        0|MagicMir | at Module.load (internal/modules/cjs/loader.js:566:32)
                                        • bheplerB
                                          @shazglass - Ah. Okay, easy enough.
                                          You’re missing the mm.sh script. I’m not sure how you had this registered in pm2 earlier, but we can fix it. We’ll use nano to create a new mm.sh file:
                                          cd ~
                                          nano mm.sh
                                          This will give you a blank screen with the nano options at the bottom. Enter the following lines:
                                          When you’re done, hit ctl+o to save the file and then ctl+x to exit nano. Then just like you did earlier, make your script executable by entering chmod +x mm.sh
                                          Before we go any further, we need to test your script. From the command line, enter ./mm.sh
                                          Your mirror should start after 30 seconds or so. Try this and report back with any errors and behaviors. Also, please use the markup commands when posting code and logs (follow this link for a quick tutorial).
                                          With your input, this post could be even better πŸ’—
