    Sensor behind glass, PIR or not.
    3 Posts 3 Posters 2.5k Views 2 Watching
      duraturk
      Re: PIR sensor behind glass?
      Trying to summarize and double check on what I learned from the above, old topic.
      @yo-less
      Is this HC-SR501 the sensor you used? I believe you removed the white dome, which happens to be the Fresnel Lens. Removing it might lower the detection zone and sensibility but it would be still good enough to do what you (we) need. That is how you manage to make it work through a hole as small as 2mm wide. Which wouldn’t be possible without removing the white dome.
      Is that about right?
      @dmcinnes
      So, the microwave sensor is not directional but it detects in a radius manner; left, right, front and back. You were trying to lower the number of unwanted detection by using an aluminum foil around it. How well it did work for you? Does it still detects motion more than you want it to do?
      Oh well, I wouldn’t mind a 2-3mm hole on the bottom of the frame if the microware sensor gives me too many false positives.
      Thanks…
      • cowboysdudeC Offline
        cowboysdude Module Developer @duraturk
        @duraturk Far as I know the pir sensor will not work behind the mirror.
        • kruemelK Offline
          kruemel
          Cowboysdude is right, you have to use, for example a RCWL0516 (radar sensor) instead.
