    NPM install is giving Error.
    18 Posts 11 Posters 30.7k Views 11 Watching
      alessandroiacovella
      same with me :pouting_face:
        merceg100
        Same here:
        Same here:
        pi@raspberrypi:~/MagicMirror $ npm install
        (node:4024) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
        npm ERR! Error: Method Not Allowed
        npm ERR! at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
        npm ERR! at /usr/share/npm/lib/cache/add-named.js:203:12
        npm ERR! at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
        npm ERR! at FSReqWrap.oncomplete (fs.js:135:15)
        npm ERR! If you need help, you may report this entire log,
        npm ERR! including the npm and node versions, at:
        npm ERR! http://github.com/npm/npm/issues
        npm ERR! System Linux 4.14.52-v7+
        npm ERR! command “/usr/bin/node” “/usr/bin/npm” “install”
        npm ERR! cwd /home/pi/MagicMirror
        npm ERR! node -v v8.11.1
        npm ERR! npm -v 1.4.21
        npm ERR! code E405
        npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
        electron-chromedriver@1.7.1 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
        node ./download-chromedriver.js
        npm ERR! fetch failed https://registry.npmjs.org/lodash.isobject/-/lodash.isobject-3.0.2.tgz
        npm WARN engine rxjs@5.5.11: wanted: {“npm”:“>=2.0.0”} (current: {“node”:“8.11.1”,“npm”:“1.4.21”})
        npm WARN deprecated browserslist@2.11.3: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
        npm ERR! fetch failed https://registry.npmjs.org/nomnom/-/nomnom-1.8.1.tgz
        npm ERR!
        npm ERR! Additional logging details can be found in:
        npm ERR! /home/pi/MagicMirror/npm-debug.log
        npm ERR! not ok code 0
        • N Offline
          NoNameRo @merceg100
          @postremalone @alessandroiacovella @merceg100
          Upgrade npm with
          npm install -g npm@latest
            alessandroiacovella
            What command do you type to upgrade npm?
              merceg100 @NoNameRo
              @nonamero said in NPM install is giving Error.:
              Upgrade npm with
              Tried it… doesn’t help either…
                postremalone
                Bump… Anyone help please.
                  merceg100
                  @alessandroiacovella said in NPM install is giving Error.:
                  After I installed MM using this command:
                  git clone https://github.com/MichMich/MagicMirror
                  then I ran:
                  sudo apt-get install npm
                  afterwards:
                  cd MagicMirror
                  npm install
                  Then I tried
                  but it didnt work also.
                  I am running latest updated Raspbian on RPi 3 b+
                  • N Offline
                    NoNameRo @merceg100
                    @merceg100
                    please try the following
                    sudo apt-get remove nodejs nodejs-legacy nodered
                    after that
                    curl -sL https://deb.nodesource.com/setup_$NODE_STABLE_BRANCH | sudo -E bash -
                    sudo apt-get install -y nodejs
                    after that enter in the repository with
                    cd MagicMirror
                    then install and run the app with
                    npm install && npm start
                    in case of errors please post here.
                    why do not you use the automatic installation for the RPi 3 b +
                    bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                    D D 2 Replies Last reply Reply Quote 0
                    • F Offline
                      fire1ce
                      @nonamero
                      won’t install npm. getting command not found: npm
                      • N Offline
                        NoNameRo @fire1ce
                        @fire1ce
                        try
                        curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                        • F Offline
                          fire1ce @NoNameRo
                          @fire1ce
                          try
                          thanks. that helps.
                            dnwmhaha @NoNameRo
                            @nonamero
                            Hi, Thank you for your help. I have been trying to install MM. At first, I had a trouble installing electron and node. Now I got dependencies error.
                            I’ve tried what you suggested and I got the following error.
                            During the installation of MM, I got Unable to install dependencies!.
                            Could you please help?
                            //your code here
                            pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                            $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                            $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                            $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                            $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                            $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                            $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                            \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                                    \______/
                            Updating packages ...
                            Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                            Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.3 kB]
                            Hit:3 https://deb.nodesource.com/node_8.x stretch InRelease
                            Fetched 25.3 kB in 1s (13.7 kB/s)
                            Reading package lists... Done
                            Installing helper tools ...
                            Building dependency tree
                            build-essential is already the newest version (12.3).
                            curl is already the newest version (7.52.1-5+deb9u6).
                            git is already the newest version (1:2.11.0-3+deb9u3).
                            unzip is already the newest version (6.0-21).
                            wget is already the newest version (1.18-5+deb9u2).
                            Minimum Node version: v5.1.0
                            Installed Node version: v5.7.0
                            No Node.js upgrade necessary.
                            Cloning MagicMirror ...
                            Cloning into 'MagicMirror'...
                            remote: Counting objects: 276, done.
                            remote: Compressing objects: 100% (245/245), done.
                            remote: Total 276 (delta 34), reused 129 (delta 21), pack-reused 0
                            Receiving objects: 100% (276/276), 383.32 KiB | 688.00 KiB/s, done.
                            Resolving deltas: 100% (34/34), done.
                            Cloning MagicMirror Done!
                            Installing dependencies ...
                            /home/pi/.nvm/versions/node/v5.7.0/lib/node_modules/npm/bin/npm-cli.js:82
                                  let notifier = require('update-notifier')({pkg})
                            SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode
                                at exports.runInThisContext (vm.js:53:16)
                                at Module._compile (module.js:387:25)
                                at Object.Module._extensions..js (module.js:422:10)
                                at Module.load (module.js:357:32)
                                at Function.Module._load (module.js:314:12)
                                at Function.Module.runMain (module.js:447:10)
                                at startup (node.js:141:18)
                                at node.js:933:3
                            pi@raspberrypi:~ $
                              Alex_
                              @postremalone said in NPM install is giving Error.:
                              NPM install is giving error.
                              alt text
                              Help please.
                              I meet the same issue than you and I solved it by uninstalling nodejs
                              and reinstall nodejs by using the MagicMirror install script
                              During the installation, npm install -g npm@latest give me this error
                              npm ERR! path /usr/lib/node_modules/npm/node_modules/ansi-regex
                              npm ERR! code EACCES
                              npm ERR! errno -13
                              npm ERR! syscall access
                              npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/ansi-regex'
                              npm ERR!  { Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/ansi-regex'
                              npm ERR!   stack: 'Error: EACCES: permission denied, access \'/usr/lib/node_modules/npm/node_modules/ansi-regex\'',
                              npm ERR!   errno: -13,
                              npm ERR!   code: 'EACCES',
                              npm ERR!   syscall: 'access',
                              npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/ansi-regex' }
                              npm ERR!
                              npm ERR! Please try running this command again as root/Administrator.
                              and I run same command as root to solved this
                              sudo npm install -g npm@latest
                              Here is version of nodejs install by MagicMirror script :
                              Installed Node version: v9.11.2
                              • E Offline
                                epi
                                > magicmirror@2.4.1 start /home/pi/MagicMirror
                                > sh run-start.sh
                                /home/pi/MagicMirror/node_modules/electron/index.js:1
                                (function (exports, require, module, __filename, __dirname) {
                                SyntaxError: Invalid or unexpected token
                                    at new Script (vm.js:51:7)
                                    at createScript (vm.js:136:10)
                                    at Object.runInThisContext (vm.js:197:10)
                                    at Module._compile (internal/modules/cjs/loader.js:618:28)
                                    at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
                                    at Module.load (internal/modules/cjs/loader.js:566:32)
                                    at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
                                    at Function.Module._load (internal/modules/cjs/loader.js:498:3)
                                    at Module.require (internal/modules/cjs/loader.js:598:17)
                                    at require (internal/modules/cjs/helpers.js:11:18)
                                npm ERR! code ELIFECYCLE
                                npm ERR! errno 1
                                npm ERR! magicmirror@2.4.1 start: `sh run-start.sh`
                                npm ERR! Exit status 1
                                npm ERR!
                                npm ERR! Failed at the magicmirror@2.4.1 start script.
                                npm ERR!     /home/pi/.npm/_logs/2018-09-13T10_40_56_673Z-debug.log
                                  devinhedge @NoNameRo
                                  @nonamero I’ve brought this up on another thread, but I’ll mention here so that it is captured in context: for the last couple months Node.js and npm are currently BROKEN on RaspberryPi.
                                  I just tried a test this morning using the started Electron app at https://electronjs.org/docs/tutorial/first-app
                                  Running the automated install is a Red Herring. It is inappropriate to suggest it.
                                  We have to figure out how to fix the bugs in the Node.js installation for Raspberry Pi before anything else. I’m wondering if installing an older version of Node.js is the solution. If so, then what version would we start with?
                                    paddyhughes @postremalone
                                    @postremalone
                                    I just installed a module and it asked me to update NPM think i did it in the root directory not MagicMirror one can be sure.
                                    This is what worked for me
                                    sudo npm i -g npm
                                      rmeskill
                                      Aha-got it!
                                      sudo rm -rf ~/.nvm
                                      sudo rm /usr/local/bin/node
                                      sudo rm /usr/local/bin/nvm
                                      pm2 stop mm (not sure if I missed this earlier)
                                      This installed fine, but gave me an error of an out-of-date npm version, so I ran:
                                      sudo npm i -g npm
                                      Then moved all my old modules and config file over to the new install and checked my node/npm versions:
                                      pi@raspberrypi:~/MagicMirrorBackup/modules $ node -v
                                      v9.11.2
                                      pi@raspberrypi:~/MagicMirrorBackup/modules $ npm -v
                                      6.5.0
                                      So they’re not as up-to-date as my previous ones, but MagicMirror is working fine!
                                      Thanks everyone for the input, turns out just a bit of manual removal and persistence sorted me out!
