    NPM install is giving Error.
    18 Posts 11 Posters 31.1k Views 11 Watching
    • N Offline
      NoNameRo @merceg100
      @merceg100
      please try the following
      sudo apt-get remove nodejs nodejs-legacy nodered
      after that
      curl -sL https://deb.nodesource.com/setup_$NODE_STABLE_BRANCH | sudo -E bash -
      sudo apt-get install -y nodejs
      npm install -g npm@latest
      after that enter in the repository with
      cd MagicMirror
      then install and run the app with
      npm install && npm start
      in case of errors please post here.
      why do not you use the automatic installation for the RPi 3 b +
      bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
      D D 2 Replies Last reply Reply Quote 0
      • F Offline
        fire1ce
        @nonamero
        won’t install npm. getting command not found: npm
        • N Offline
          NoNameRo @fire1ce
          @fire1ce
          try
          curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
          • F Offline
            fire1ce @NoNameRo
            @nonamero said in NPM install is giving Error.:
            @fire1ce
            try
            thanks. that helps.
              dnwmhaha @NoNameRo
              @nonamero
              Hi, Thank you for your help. I have been trying to install MM. At first, I had a trouble installing electron and node. Now I got dependencies error.
              I’ve tried what you suggested and I got the following error.
              During the installation of MM, I got Unable to install dependencies!.
              Could you please help?
              //your code here
              pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
              $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
              $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
              $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
              $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
              $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
              $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
              \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                      \______/
              Updating packages ...
              Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
              Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.3 kB]
              Hit:3 https://deb.nodesource.com/node_8.x stretch InRelease
              Fetched 25.3 kB in 1s (13.7 kB/s)
              Reading package lists... Done
              Installing helper tools ...
              Building dependency tree
              build-essential is already the newest version (12.3).
              curl is already the newest version (7.52.1-5+deb9u6).
              git is already the newest version (1:2.11.0-3+deb9u3).
              unzip is already the newest version (6.0-21).
              wget is already the newest version (1.18-5+deb9u2).
              Minimum Node version: v5.1.0
              Installed Node version: v5.7.0
              No Node.js upgrade necessary.
              Cloning MagicMirror ...
              Cloning into 'MagicMirror'...
              remote: Counting objects: 276, done.
              remote: Compressing objects: 100% (245/245), done.
              remote: Total 276 (delta 34), reused 129 (delta 21), pack-reused 0
              Receiving objects: 100% (276/276), 383.32 KiB | 688.00 KiB/s, done.
              Resolving deltas: 100% (34/34), done.
              Cloning MagicMirror Done!
              Installing dependencies ...
              /home/pi/.nvm/versions/node/v5.7.0/lib/node_modules/npm/bin/npm-cli.js:82
                    let notifier = require('update-notifier')({pkg})
              SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode
                  at exports.runInThisContext (vm.js:53:16)
                  at Module._compile (module.js:387:25)
                  at Object.Module._extensions..js (module.js:422:10)
                  at Module.load (module.js:357:32)
                  at Function.Module._load (module.js:314:12)
                  at Function.Module.runMain (module.js:447:10)
                  at startup (node.js:141:18)
                  at node.js:933:3
              pi@raspberrypi:~ $
                Alex_
                @postremalone said in NPM install is giving Error.:
                NPM install is giving error.
                alt text
                Help please.
                I meet the same issue than you and I solved it by uninstalling nodejs
                and reinstall nodejs by using the MagicMirror install script
                During the installation, npm install -g npm@latest give me this error
                npm ERR! path /usr/lib/node_modules/npm/node_modules/ansi-regex
                npm ERR! code EACCES
                npm ERR! errno -13
                npm ERR! syscall access
                npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/ansi-regex'
                npm ERR!  { Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/ansi-regex'
                npm ERR!   stack: 'Error: EACCES: permission denied, access \'/usr/lib/node_modules/npm/node_modules/ansi-regex\'',
                npm ERR!   errno: -13,
                npm ERR!   code: 'EACCES',
                npm ERR!   syscall: 'access',
                npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/ansi-regex' }
                npm ERR!
                npm ERR! Please try running this command again as root/Administrator.
                and I run same command as root to solved this
                sudo npm install -g npm@latest
                Here is version of nodejs install by MagicMirror script :
                Installed Node version: v9.11.2
                • E Offline
                  epi
                  > magicmirror@2.4.1 start /home/pi/MagicMirror
                  > sh run-start.sh
                  /home/pi/MagicMirror/node_modules/electron/index.js:1
                  (function (exports, require, module, __filename, __dirname) {
                  SyntaxError: Invalid or unexpected token
                      at new Script (vm.js:51:7)
                      at createScript (vm.js:136:10)
                      at Object.runInThisContext (vm.js:197:10)
                      at Module._compile (internal/modules/cjs/loader.js:618:28)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
                      at Module.load (internal/modules/cjs/loader.js:566:32)
                      at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
                      at Function.Module._load (internal/modules/cjs/loader.js:498:3)
                      at Module.require (internal/modules/cjs/loader.js:598:17)
                      at require (internal/modules/cjs/helpers.js:11:18)
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! magicmirror@2.4.1 start: `sh run-start.sh`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.4.1 start script.
                  npm ERR!     /home/pi/.npm/_logs/2018-09-13T10_40_56_673Z-debug.log
                    devinhedge @NoNameRo
                    @nonamero I’ve brought this up on another thread, but I’ll mention here so that it is captured in context: for the last couple months Node.js and npm are currently BROKEN on RaspberryPi.
                    I just tried a test this morning using the started Electron app at https://electronjs.org/docs/tutorial/first-app
                    Running the automated install is a Red Herring. It is inappropriate to suggest it.
                    We have to figure out how to fix the bugs in the Node.js installation for Raspberry Pi before anything else. I’m wondering if installing an older version of Node.js is the solution. If so, then what version would we start with?
                      paddyhughes @postremalone
                      @postremalone
                      I just installed a module and it asked me to update NPM think i did it in the root directory not MagicMirror one can be sure.
                      This is what worked for me
                      sudo npm i -g npm
                        rmeskill
                        Aha-got it!
                        sudo rm -rf ~/.nvm
                        sudo rm /usr/local/bin/node
                        sudo rm /usr/local/bin/nvm
                        pm2 stop mm (not sure if I missed this earlier)
                        This installed fine, but gave me an error of an out-of-date npm version, so I ran:
                        sudo npm i -g npm
                        Then moved all my old modules and config file over to the new install and checked my node/npm versions:
                        pi@raspberrypi:~/MagicMirrorBackup/modules $ node -v
                        v9.11.2
                        pi@raspberrypi:~/MagicMirrorBackup/modules $ npm -v
                        6.5.0
                        So they’re not as up-to-date as my previous ones, but MagicMirror is working fine!
                        Thanks everyone for the input, turns out just a bit of manual removal and persistence sorted me out!
