    NPM install is giving Error.
    18 Posts 11 Posters 31.2k Views 11 Watching
    • A
      alessandroiacovella
      What command do you type to upgrade npm?
        merceg100 @NoNameRo
        @nonamero said in NPM install is giving Error.:
        @postremalone @alessandroiacovella @merceg100
        Upgrade npm with
        npm install -g npm@latest
        Tried it… doesn’t help either…
          postremalone
          Bump… Anyone help please.
            merceg100
            @alessandroiacovella said in NPM install is giving Error.:
            After I installed MM using this command:
            git clone https://github.com/MichMich/MagicMirror
            then I ran:
            sudo apt-get install npm
            afterwards:
            cd MagicMirror
            npm install
            Then I tried
            but it didnt work also.
            I am running latest updated Raspbian on RPi 3 b+
            N 1 Reply Last reply
            • N
              NoNameRo @merceg100
              @merceg100
              please try the following
              sudo apt-get remove nodejs nodejs-legacy nodered
              after that
              curl -sL https://deb.nodesource.com/setup_$NODE_STABLE_BRANCH | sudo -E bash -
              sudo apt-get install -y nodejs
              after that enter in the repository with
              cd MagicMirror
              then install and run the app with
              npm install && npm start
              in case of errors please post here.
              why do not you use the automatic installation for the RPi 3 b +
              bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
              D D 2 Replies Last reply
              • F
                fire1ce
                @nonamero
                won’t install npm. getting command not found: npm
                • N
                  NoNameRo @fire1ce
                  @fire1ce
                  try
                  curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
                  F 1 Reply Last reply
                  • F
                    fire1ce @NoNameRo
                    @fire1ce
                    try
                    thanks. that helps.
                      dnwmhaha @NoNameRo
                      @nonamero
                      Hi, Thank you for your help. I have been trying to install MM. At first, I had a trouble installing electron and node. Now I got dependencies error.
                      I’ve tried what you suggested and I got the following error.
                      During the installation of MM, I got Unable to install dependencies!.
                      Could you please help?
                      //your code here
                      pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                      $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                      $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                      $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                      $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                      $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                      $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                      \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                              \______/
                      Updating packages ...
                      Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                      Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.3 kB]
                      Hit:3 https://deb.nodesource.com/node_8.x stretch InRelease
                      Fetched 25.3 kB in 1s (13.7 kB/s)
                      Reading package lists... Done
                      Installing helper tools ...
                      Building dependency tree
                      build-essential is already the newest version (12.3).
                      curl is already the newest version (7.52.1-5+deb9u6).
                      git is already the newest version (1:2.11.0-3+deb9u3).
                      unzip is already the newest version (6.0-21).
                      wget is already the newest version (1.18-5+deb9u2).
                      Minimum Node version: v5.1.0
                      Installed Node version: v5.7.0
                      No Node.js upgrade necessary.
                      Cloning MagicMirror ...
                      Cloning into 'MagicMirror'...
                      remote: Counting objects: 276, done.
                      remote: Compressing objects: 100% (245/245), done.
                      remote: Total 276 (delta 34), reused 129 (delta 21), pack-reused 0
                      Receiving objects: 100% (276/276), 383.32 KiB | 688.00 KiB/s, done.
                      Resolving deltas: 100% (34/34), done.
                      Cloning MagicMirror Done!
                      Installing dependencies ...
                      /home/pi/.nvm/versions/node/v5.7.0/lib/node_modules/npm/bin/npm-cli.js:82
                            let notifier = require('update-notifier')({pkg})
                      SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode
                          at exports.runInThisContext (vm.js:53:16)
                          at Module._compile (module.js:387:25)
                          at Object.Module._extensions..js (module.js:422:10)
                          at Module.load (module.js:357:32)
                          at Function.Module._load (module.js:314:12)
                          at Function.Module.runMain (module.js:447:10)
                          at startup (node.js:141:18)
                          at node.js:933:3
                      pi@raspberrypi:~ $
                      • A
                        Alex_
                        @postremalone said in NPM install is giving Error.:
                        NPM install is giving error.
                        alt text
                        Help please.
                        I meet the same issue than you and I solved it by uninstalling nodejs
                        and reinstall nodejs by using the MagicMirror install script
                        During the installation, npm install -g npm@latest give me this error
                        npm ERR! path /usr/lib/node_modules/npm/node_modules/ansi-regex
                        npm ERR! code EACCES
                        npm ERR! errno -13
                        npm ERR! syscall access
                        npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/ansi-regex'
                        npm ERR!  { Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/ansi-regex'
                        npm ERR!   stack: 'Error: EACCES: permission denied, access \'/usr/lib/node_modules/npm/node_modules/ansi-regex\'',
                        npm ERR!   errno: -13,
                        npm ERR!   code: 'EACCES',
                        npm ERR!   syscall: 'access',
                        npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/ansi-regex' }
                        npm ERR!
                        npm ERR! Please try running this command again as root/Administrator.
                        and I run same command as root to solved this
                        sudo npm install -g npm@latest
                        Here is version of nodejs install by MagicMirror script :
                        Installed Node version: v9.11.2
                        • E
                          epi
                          > magicmirror@2.4.1 start /home/pi/MagicMirror
                          > sh run-start.sh
                          /home/pi/MagicMirror/node_modules/electron/index.js:1
                          (function (exports, require, module, __filename, __dirname) {
                          SyntaxError: Invalid or unexpected token
                              at new Script (vm.js:51:7)
                              at createScript (vm.js:136:10)
                              at Object.runInThisContext (vm.js:197:10)
                              at Module._compile (internal/modules/cjs/loader.js:618:28)
                              at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
                              at Module.load (internal/modules/cjs/loader.js:566:32)
                              at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
                              at Function.Module._load (internal/modules/cjs/loader.js:498:3)
                              at Module.require (internal/modules/cjs/loader.js:598:17)
                              at require (internal/modules/cjs/helpers.js:11:18)
                          npm ERR! code ELIFECYCLE
                          npm ERR! errno 1
                          npm ERR! magicmirror@2.4.1 start: `sh run-start.sh`
                          npm ERR! Exit status 1
                          npm ERR!
                          npm ERR! Failed at the magicmirror@2.4.1 start script.
                          npm ERR!     /home/pi/.npm/_logs/2018-09-13T10_40_56_673Z-debug.log
                            devinhedge @NoNameRo
                            @nonamero I’ve brought this up on another thread, but I’ll mention here so that it is captured in context: for the last couple months Node.js and npm are currently BROKEN on RaspberryPi.
                            I just tried a test this morning using the started Electron app at https://electronjs.org/docs/tutorial/first-app
                            Running the automated install is a Red Herring. It is inappropriate to suggest it.
                            We have to figure out how to fix the bugs in the Node.js installation for Raspberry Pi before anything else. I’m wondering if installing an older version of Node.js is the solution. If so, then what version would we start with?
                              paddyhughes @postremalone
                              @postremalone
                              I just installed a module and it asked me to update NPM think i did it in the root directory not MagicMirror one can be sure.
                              This is what worked for me
                              sudo npm i -g npm
                                rmeskill
                                Aha-got it!
                                sudo rm -rf ~/.nvm
                                sudo rm /usr/local/bin/node
                                sudo rm /usr/local/bin/nvm
                                pm2 stop mm (not sure if I missed this earlier)
                                This installed fine, but gave me an error of an out-of-date npm version, so I ran:
                                sudo npm i -g npm
                                Then moved all my old modules and config file over to the new install and checked my node/npm versions:
                                pi@raspberrypi:~/MagicMirrorBackup/modules $ node -v
                                v9.11.2
                                pi@raspberrypi:~/MagicMirrorBackup/modules $ npm -v
                                6.5.0
                                So they’re not as up-to-date as my previous ones, but MagicMirror is working fine!
                                Thanks everyone for the input, turns out just a bit of manual removal and persistence sorted me out!
