    Train status tracker
    22 Posts 6 Posters 19.0k Views 6 Watching
    • nwoottonN
      nwootton Module Developer @yawns
      @yawns Thanks. Now to tidy the bus version.
      • nwoottonN
        I’ve now added this to the Modules > Showcase >Transport section of the forum.
          jamielola @nwootton
          @nwootton sorry for the lack of response I have been away. Wow it looks great! I am going to install the updated module on my mirror tonight. Also thanks for the above ^^ explaining the late and early issue, this has been a good learning experience. @Reggiejagger it looks like @nwootton has set the columns in the same order as my screenshot so I wont post that old code.
          nwoottonN 1 Reply Last reply Reply Quote 0
          • nwoottonN
            nwootton Module Developer @jamielola
            @jamielola Just an update. I looked at the RealTimeTrains API and it gives the same information, but allows for less filtering of your request. For example you can’t filter to only show trains that have stopped at station X or are going through station Y. While this is something that might be of no use to the majority of users, there are bound to be some people who could make good use of this.
            It’s also much easier to sign up for an account at the TransportAPI.com that at RealTimeTrains (rtt.api.io).
            I’ll keep the module based on the TransportAPI unless we come up with a good reason to migrate.
            locationDetail: {
            realtimeActivated: true,
            tiploc: "SURBITN",
            crs: "SUR",
            description: "Surbiton",
            gbttBookedArrival: "1526",
            gbttBookedDeparture: "1527",
            origin: [
            tiploc: "WATRLMN",
            description: "London Waterloo",
            workingTime: "150300",
            publicTime: "1503"
            destination: [
            tiploc: "GUILDFD",
            description: "Guildford",
            workingTime: "160200",
            publicTime: "1604"
            isCall: true,
            isPublicCall: true,
            realtimeArrival: "1526",
            realtimeArrivalActual: false,
            realtimeDeparture: "1527",
            realtimeDepartureActual: false,
            platform: "4",
            platformConfirmed: false,
            platformChanged: false,
            displayAs: "CALL"
            serviceUid: "W36325",
            runDate: "2017-03-29",
            trainIdentity: "2G41",
            runningIdentity: "2G41",
            atocCode: "SW",
            atocName: "South West Trains",
            serviceType: "train",
            isPassenger: true
              jamielola
              Thanks @nwootton from that explanation what you are saying makes sense.
              I imported the module and it looks great! I thought the platform would be good (in my case anyway) so added it in
              first row of table in JS script-
              			var trainplatCell = document.createElement("td");
              			trainplatCell.innerHTML = trains.platform;
              			trainplatCell.className = "align-left bright platform";
              			row.appendChild(trainplatCell);
              added this in the getprams function
              params += "&platform=" + this.config.platform;
              and this to the css
              .platform {
              color:Green;
              padding:5px;
              https://imgur.com/a/nHDhs
              With Platform
              I have ambitions to try and calculate how many minutes late it is from its planned departure to its estimated departure, so its say “x minutes late”.I will let you know how I progress if I manage to figure JS out properly, think I have to create a function somewhere then do the calcualtion and save it in a var
              • nwoottonN
                @jamielola Nice. As our station only has an In and an out platform I never considered it!
                If you want I can try to add you code to the repo and make it an option to display the platform via the config.
                Something like:
                showPlatform: true
                If you want real time delay calculations have a look at my Bus Stop module here. That does deltas between time tabled and actual times.
                N
                • nwoottonN
                  Added platform as an option to the module.
                  Defaults to showing the platform, but can be turned off via config if not needed. If no platform specified, it will just display a -
                    Reggiejagger
                    this looks great, i cant wait to update
                      callum8004
                      Hi
                      I’m really struggling to add a secondary CRS station, is there any documentation on how to show multiple stations?
                      • nwoottonN
                        nwootton Module Developer @callum8004
                        @callum8004 You have to add a separate set of configs for each station that you want to track.
                          callum8004 @nwootton
                          @nwootton sso if i wanted to replicate for ‘BSC’ station too how would do this in the below code?
                          			module: 		'MMM-UKNationalRail',
                          			position: 		'bottom_left',
                          			header:			'Walsall Live Departures',		/Optional - delete this line to turn OFF the header completely
                          			config:
                          					stationCode: 		'WSL',	// CRS code for station
                          					app_id: 			'fe0f5d14', 		// TransportAPI App ID
                          					app_key: 			'7de7aa1439665fef7ad6eb151190a6a1', 		// TransportAPI App Key
                          					maxResults: 		3,  		//Optional - Maximum results to display.
                          					showOrigin: 		false,   	//Optional - Show the origin of the train in the table
                          					calling_at:			'BHM',
                          					showPlatform:		true,
                          complete newbie with any type of coding.
                          Callum
                          • nwoottonN
                            @callum8004 copy and paste the same module config with the information for the other station
                                config:
                             		stationCode: 	'WSL',
                             		app_id: 			'fe0f5d14',
                             		maxResults: 		3,
                             		showOrigin: 		false,
                             		calling_at:		'BHM',
                             		showPlatform:	true,
                                header:		'Another Station Departures',
                                config:
                             		stationCode: 	'BSC',
                             		app_id: 			'fe0f5d14'
                             		maxResults: 		3,
                             		showOrigin: 		false,
                             		calling_at:		'BHM',
                             		showPlatform:	true,
                              bachoo786
                              Guys
                              i have the UK transport (Rail) working however this module does not update as required. It shows say 5 trains and after the time of the 5th train has elapsed it doesn’t update to the next 5 trains.
                              Can anyone help please?
                              thanks.
